MailWatch Recent message empty
Phil
Post by Phil » 13 Apr 2018 20:56
Hello everyone,
I just update my system from 3.0.2.3 to 3.0.2.6. Everything is working fine, email are going in and out no problem.
The problem is, when i log to mailwatch, the recent message tab show nothing.
I try : wget https://raw.githubusercontent.com/mailw ... pgrade.php, it was the solution for this problem in another threat but it said "Not found".
Any idea why this is not working ? (was fine before the update) Or any log i should look ?
Thank you
Re: MailWatch Recent message empty
Post by shawniverson » 14 Apr 2018 13:05
Version 3.0.2.6 released! Update now to keep your eFa secure!
Phil
Post by Phil » 16 Apr 2018 14:22
Thank you so much Shawniverson, it seem to have done the trick !! :D
Phil
