New SPAM or back scatter?
planetcoop
Post by planetcoop »
I have started to see about 10-20 emails like this per day. Are they NDR, SPAM or some new back scatter?
Re: New SPAM or back scatter?
Can you look at one of the messages and post the details?
booola
Post by booola »
Hi guys,
I've got probably same problem - many emails in OUTBOUND QUEUE:
D7810102039 6793 Thu Jun 21 12:45:22 MAILER-DAEMON
(connect to kidswintercoat.com[87.229.108.136]:25: Connection timed out)
edvardpywfxhpcoufal@kidswintercoat.com
AA084102018 6844 Thu Jun 21 11:58:51 MAILER-DAEMON
(connect to alhashmigroupco.com[185.207.11.245]:25: Connection timed out)
eleonoraxhstbzemach@alhashmigroupco.com
45DB910202F 6836 Thu Jun 21 12:32:50 MAILER-DAEMON
leonanykmathmoravec@alhashmigroupco.com
4F11D10066E 6662 Thu Jun 21 10:03:43 MAILER-DAEMON
(connect to sharepointsteve.com[87.229.108.136]:25: Connection timed out)
gitahgpqfbmmarek@sharepointsteve.com
E54CD100683 7655 Thu Jun 21 10:05:23 MAILER-DAEMON
ninacfdsyrwmoravec@sharepointsteve.com
E226010202B 6766 Thu Jun 21 12:31:40 MAILER-DAEMON
ivamrqgstekocourek@alhashmigroupco.com
If I try to grep for example last spam (ivamrqgstekocourek@alhashmigroupco.com) from maillog:
Jun 21 12:31:22 km postfix/cleanup[36389]: 81736102029: hold: header Received: from icy.alhashmigroupco.com (icy.chromefalgar.com [151.106.3.186])??by our.mailserver.cz (Postfix) with ESMTP id 81736102029??for <our@email.cz>; Thu, 21 Jun 2018 12:31:21 +0200 (CE from icy.chromefalgar.com[151.106.3.186]; from=<ivamrqgstekocourek@alhashmigroupco.com> to=<our@email.cz> proto=ESMTP helo=<icy.alhashmigroupco.com>
Jun 21 12:31:24 km MailScanner[8953]: <A> tag found in message 81736102029.A4268 from ivamrqgstekocourek@alhashmigroupco.com
Jun 21 12:31:24 km MailScanner[8953]: HTML Img tag found in message 81736102029.A4268 from ivamrqgstekocourek@alhashmigroupco.com
Jun 21 12:31:25 km postfix/qmgr[2575]: 2C93B10202A: from=<ivamrqgstekocourek@alhashmigroupco.com>, size=4309, nrcpt=1 (queue active)
Jun 21 12:32:10 km postfix/smtp[36406]: E226010202B: to=<ivamrqgstekocourek@alhashmigroupco.com>, relay=none, delay=30, delays=0/0/30/0, dsn=4.4.1, status=deferred (connect to alhashmigroupco.com[185.207.11.245]:25: Connection timed out)
Jun 21 12:39:00 km postfix/smtp[37782]: E226010202B: to=<ivamrqgstekocourek@alhashmigroupco.com>, relay=none, delay=440, delays=410/0.08/30/0, dsn=4.4.1, status=deferred (connect to alhashmigroupco.com[185.207.11.245]:25: Connection timed out)
Jun 21 12:49:00 km postfix/smtp[40103]: E226010202B: to=<ivamrqgstekocourek@alhashmigroupco.com>, relay=none, delay=1040, delays=1010/0.08/30/0, dsn=4.4.1, status=deferred (connect to alhashmigroupco.com[185.207.11.245]:25: Connection timed out)
Jun 21 13:09:00 km postfix/smtp[44557]: E226010202B: to=<ivamrqgstekocourek@alhashmigroupco.com>, relay=none, delay=2240, delays=2210/0.1/30/0, dsn=4.4.1, status=deferred (connect to alhashmigroupco.com[185.207.11.245]:25: Connection timed out)
There are much more automaticly generated domains.
Thank you for suggestions.
jamerson
Post by jamerson »
i remeber me having this before, there where alot of servers trying to relay.
i've configured fail2ban and i noticed it reduced now.
booola
Post by booola »
OK, that's good idea. Thank you for suggestion. So do you use configuration for example from here:
viewtopic.php?t=1875
jamerson
Post by jamerson »
yes exactly that one has been configured.
for now i am set.
in the new release AFAIK it will be build in.
if the EFA is behind a firewall, i will suggest to block GEOIP.
