block deny extension in .zip or .rar file
junaidakhan
Post by junaidakhan »
I need to know how to block deny extension like \.src$, \.exe$, \.jar$ in zip or rar files simple duny extension blocked but then some try to send .src file in ZIP format EFA not blocked it i alos change the Maximum Processing Attempts 0 to 2,3 or 8 but stll not blocked deny ext. in zip/rar file.
Re: block deny extension in .zip or .rar file
Hi junaidakhan,
There are a couple of settings you need to check:
in /etc/MailScanner is a file called archives.filename.rules.conf and this controls what files are allowed in archives.
In my system, there is one rule to deny executables in archive files, specifically:
# These 2 added by popular demand - Very often used by viruses
deny    \.com$    Windows/DOS Executable                    Executable DOS/Windows programs are dangerous in email
deny    \.exe$    Windows/DOS Executable                    Executable DOS/Windows programs are dangerous in email
# These are very dangerous and have been used to hide viruses
deny    \.scr$    Possible virus hidden in a screensaver    Windows Screensavers are often used to hide viruses
Next, I need to make sure that MailScanner is checking archive files. Look in /etc/MailScanner/MailScanner.conf for
Maximum Archive Depth = 0
In my case, I have disabled archive checking, so I let these extensions through as I rely on my antivirus checking to look for actual bad attachments. However, you'll need to change it to 1, 2 or more, depending on your desired result.
Give this a try and let us know if it works for you.
Also, does anyone know how MailScanner knows which configuration files to use for the allowed file extensions? - maybe there is a problem in the configuration and MailScanner doesn't know to use the archives.filename.rules.conf and archives.filetype.rules.conf configuration files for archives.
junaidakhan
i already do all these step but block extension like .scr not block in .zip or .rar file
What is your maximum archive depth setting?
junaidakhan
current depth setting is 2
Can you show me the contents of your archives.filename.rules.conf file?
jamerson
Post by jamerson »
Make sure you do have the below on the mailscanner config file.
Allow Password-Protected Archives = %rules-dir%/password-archives.rule
flaitsman
Post by flaitsman »
Sorry for my bad English. I have same problem. EFA not found executable files in rar archives (.exe, .com etc)
My archives.filename.rules.conf contains
but .com and .exe files don't blocked in rar and 7z archives...
I'll run a test with this information and see if I can reproduce.
flaitsman
Post by flaitsman »
Any suggestions to solve the problem? I block RAR in filename.rules.conf and analyze files manually in quarantine...
The problem occurs after the update EFA.
So far I am unable to reproduce, but I am on a natively built appliance. Which version did you upgrade from, so that I can follow the same path?
benscha
Post by benscha »
Hey Guys
i have the same issues here... EFA-3.0.2.6.
Maximum Archive Depth = 4
Find Archives By Content = yes
in /etc/archive.filetype.rules.conf i have the following line:
Also Sophos will detect the File but not block. this report will be generated by Mail:
A threat classified as 'Mal/FareitVB-N' was detected in the file '/var/spool/MailScanner/incoming/63033/0915B100F51.A0508/nQuotation $ Specification.zip' when attempting to open it at Fri Jul 12 15:05:26 2019 CEST +0300 (2019-07-12 13:05:26 UTC).  Access to the infected file was not allowed.
i'm a bit amazed about the following text in the Mail Access to the infected file was not allowed.
savd is running as root
root      1761  0.0  0.0 592508  5284 ?        Sl   Jul15   0:04 savd etc/savd.cfg
anyone any idea?
always happy for any hints and tipps! :clap: | EFA 3.0.2.6
