Relay access denied
Posted: 26 Mar 2018 02:13
Been trying to figure this out for a few weeks, I have my Network Firewalled with PfSense, zimbra mail server behind it as well as EFA on a different IP addresses. Everything works fine with zimbra but when I enable EFA I can't send any mail to external domains unless I send from zimbra web client. Any other mail client errors out.
I am basically changing my NAT rule to point port 25 to the EFA server instead of zimbra, when I do that I see mail being filtered and everything seems fine with incoming mail. However, trying to send mail with various clients gives: Message not sent. Server replied:
Temporary authentication failure 454 4.7.1 <user@destination.com>: Relay access denied
I wouldnt think outbound mail would be affected by EFA because its not even supposed to be in the loop for outbound?
I'm guessing the receiving server is trying to do some kind of authentication or communication with zimbra but when it tries accessing it on port 25 its actually connecting to EFA?
