interesting reporting tool: sendmailanalyzer
Posted: 21 Mar 2018 04:44
I just came across this tool while looking for a postfix log analyzer
http://sareport.darold.net/
Installs easily and seems to work. I'm having a play with it to see if it gives me any more useful functionality.
(oh, and the tool I was looking for was
https://jimsun.linxnet.com/postfix_contrib.html)
Re: interesting reporting tool: sendmailanalyzer
Posted: 28 Mar 2018 07:53
by budy
I have been using sendmailanalyzer for years and I always found it to be a good tool to have.
Posted: 28 Mar 2018 08:27
by jogomes
budy wrote: 28 Mar 2018 07:53
Hi, do you integrate it with the EFA appliance itself or just use another server to do it?
Regards.
JG
Posted: 28 Mar 2018 09:33
by budy
I have always used it only on our gateway MXs and I didn't bother with integrating it into our eFa.
Posted: 28 Mar 2018 09:55
since I only have one mx gateway (my efa box), I installed it on the machine directly. the changes were very minimal and shouldn't affect efa in anyway.
Posted: 28 Mar 2018 10:12
by jogomes
pdwalker wrote: 28 Mar 2018 09:55
Thank you all,
installing it on the EFA Box is my goal, let's see.
JG
