ARC - Authenticated Received Chain
Antiloop
Post by Antiloop »
any chance the new (to be) defined ARC specification will make it into EFAv4 as well?
http://arc-spec.org/
Re: ARC - Authenticated Received Chain
thewomble
Post by thewomble »
Currently having a play with this.
Compile the OpenARC package:
cd
git clone https://github.com/trusteddomainproject/OpenARC
cd OpenARC
autoreconf -fvi
./configure
make
make install
ldconfig
And check if the libs are found with:
Verify that the package can be run:
openarc -V
openarc: OpenARC Filter v0.1.0
Compiled with OpenSSL 1.0.1f 6 Jan 2014
SMFI_VERSION 0x1000001
libopenarc 0.1.0:
Set up configs:
mkdir -p /etc/openarc
cp openarc.conf.sample /etc/openarc/openarc.conf
Configure OpenARC as you want in the openarc.conf file
Launch openarc:
openarc -c /etc/openarc/openarc.conf
Added has a milter on port 8895, openarc.conf is similar to configure has DKIM.
