viewtopic.php?f=19&t=3342
Translations Topic for eFa v4
This is the topic for submitting eFa4 translations. Please check back periodically for new words and phrases to translate
Re: Translations Topic for eFa v4
To submit a translation, simply reply to this topic or fork and create a pull request on github (and be sure to mention the language to which you are translating!)
fferraro87
i can translate it in italian but i don't know how can i create a new pull request on github.
No worriesfferraro87 wrote: 20 Mar 2018 13:35 i can translate it in italian but i don't know how can i create a new pull request on github.
Hi Shawn,
You need any translations in Swedish ? I will help you with that .
// Fredrik
// Fredrik
That would be great!rekkan wrote: 23 Mar 2018 22:16 Hi Shawn,
// Fredrik
Will dowoundride wrote: 28 Mar 2018 11:32 Hi,
Here is complete French Translation from git corrected.
shawniverson, please, when you add news words or phrases to translate, can you tag what's news with date or in a new post ?
Changed some of the Dutch (NL) translations. Please PM me if you need more Dutch (NL) translations
shawniverson,
I'm currently updating the simplified chinese translations so I'll send that once I have something decent.
I do have a suggestion, your yml language entries come in two formats
and
Might I suggest you change them all to former? It may help avoid future problems and it'll make automated parsing of this information easier in the future.
'text with spaces': 'translation with spaces'Code: Select all
textWithOutSpaces: TranslationWithoutSpacesRe: Translations Topic for eFa v4
Question:
What's the difference between 'Set IP Netmask' and 'Set IP Mask'?
As far as I can see, those are both the same so should be replaced with just one translation entry.
[OCD Alert]
You are using "mask" and "netmask" interchangeably. Would it be better to just consistently use one term?
e.g.:
'Please enter a valid IPv4 netmask'
vs
'Please enter a valid IPv6 mask'
[edit 2]
'IANA Code' vs 'IANA Country Code' ?
[edit 3]
'Local Mail Server' -> is that 'Local Mail Server address or hostname'?
What's the difference between 'IANA country code' and 'IANA Code'?
[edit 4]
'Host is UTC' -> What does that mean exactly? Does it mean ''The host is set to UTC time'?
(Wow! who knew that translation was such hard work!)
[OCD Alert]
e.g.:
vs
[edit 2]
[edit 3]
[edit 4]
Actually, I am not. In fact, I was struggling at the time to remember the ipv6 term. ipv6 does not have a netmask, so i simply used "mask." I recalled since then it is called the prefix, so we will need to change all instances of "mask" to "prefix."pdwalker wrote: 05 Apr 2018 12:30 Question:
[OCD Alert]
e.g.:
vs
This can be consolidated.[edit 2]
Yes, we can extend that one.[edit 3]
Correct.[edit 4]
IPv6 Prefix. Yes, that makes more sense. I'm going to have to see what the proper translation for that is and revise.
anyone still needed for German ? If yes is there a small how to for the Repository login/pull/push ?
e.g. how to get logged in and the translation down/uploaded ?
Thx
I just looked into the repository and saw German at least some of the line shown in the other post. So is this from the eFa v3 i assume.
And the process would be translate and post the translation. Correct ?
Thx
Yep, translations are welcome. If you are not comfortable with Git/Github, feel free to post them here, and I can merge them for youtesme33 wrote: 11 Apr 2018 19:05 Hi
Thx
I can make the Portuguese PT/PT, not PT/BR.
I just fork on Github?
I see that there are allready some translated.
Are those all that are needed?
I've made a fork for the German translation. If required I am happy to translate more...
I can translate, Arabic, Frans, Dutch
Norway / Norwegian:
(merged)
(merged)
(merged)
- CZtranslate.zip
- (1.61 KiB) Downloaded 11509 times
Dutch
(merged)
Completed the last 2 translations.
(merged)
(merged)
looking into the github some entries would look like the following in German:
(assuming that the ones starting with __ still need translation)
(merged)
The rest seems already correctly translated.
Yours
Wieland
(merged)
Yours
Wieland
either i overlooked it or it wasnt there when i checked last time in messages.de.yml:
'German': 'Deutsche' should be --> 'German': 'Deutsch'
so no e at the end.
Yours
so no e at the end.
Yours
Simplified Chinese
'Passwords do not match': '两个密码不一致' (literally: two password not identical, or the two passwords are not identical)
