ESET Paid edition
tmgfsd
ESET Paid edition
Post by tmgfsd » 08 Mar 2018 07:44
Hi there I have installed ESET File / Mail Security on EFA 3.0.2.6 but when i run the following command its giving me the error as:
MailScanner --lint
Trying to setlogsock(unix)
Reading configuration file /etc/MailScanner/MailScanner.conf
Reading configuration file /etc/MailScanner/conf.d/README
Read 1500 hostnames from the phishing whitelist
Read 16062 hostnames from the phishing blacklists
Config: calling custom init function SQLBlacklist
MailWatch: Starting up MailWatch SQL Blacklist
MailWatch: Read 0 blacklist entries
Config: calling custom init function MailWatchLogging
MailWatch: Started MailWatch SQL Logging child
Config: calling custom init function SQLWhitelist
MailWatch: Starting up MailWatch SQL Whitelist
MailWatch: Read 1 whitelist entries
Checking version numbers...
Version number in MailScanner.conf (5.0.6) is correct.
Your envelope_sender_header in spamassassin.conf is correct.
MailScanner setting GID to (89)
MailScanner setting UID to (89)
Checking for SpamAssassin errors (if you use it)...
Using SpamAssassin results cache
Connected to SpamAssassin cache database
SpamAssassin reported no errors.
Connected to Processing Attempts Database
Created Processing Attempts Database successfully
There are 0 messages in the Processing Attempts Database
Using locktype = posix
MailScanner.conf says "Virus Scanners = esets"
Found these virus scanners installed: clamavmodule, esets, clamd
Filename Checks: Windows/DOS Executable (1 eicar.com)
Other Checks: Found 1 problems
Scanner initialization failed.
If any of your virus scanners (clamavmodule,esets,clamd)
Config: calling custom end function SQLBlacklist
MailWatch: Closing down MailWatch SQL Blacklist
Config: calling custom end function MailWatchLogging
Config: calling custom end function SQLWhitelist
MailWatch: Closing down MailWatch SQL Whitelist
while its working fine on manual scanning as following:
/usr/lib/MailScanner/wrapper/esets-wrapper /opt/eset/esets/sbin /root
ESET Command-line scanner, version 4.5.3, (C) 1992-2015 ESET, spol. s r.o.
Using license: Mxxxxxx Mxxxxx (/etc/opt/eset/esets/license/esets_xxxxxx.lic)
Module loader, version 1060 (20150617), build 1092
Module perseus, version 1474 (20151111), build 1715
Module scanner, version 12635 (20151127), build 26932
Module archiver, version 1239 (20150929), build 1252
Module advheur, version 1162 (20150923), build 1128
Module cleaner, version 1114 (20151004), build 1145
Command line: /root
Scan started at: Thu 08 Mar 2018 12:43:06 PM PKT
Scan completed at: Thu 08 Mar 2018 12:43:06 PM PKT
Scan time: 0 sec (0:00:00)
Total: files - 12, objects 12
Infected: files - 0, objects 0
Cleaned: files - 0, objects 0
Please me in this matter urgently
gonzalezroda
Re: ESET Paid edition
Post by gonzalezroda » 09 Nov 2018 17:17
Hi tmgfsd
I'm stuck in the exact same point, according to this thread http://lists.mailscanner.info/pipermail ... 04201.html is a permissions matter, but I don't know how to resolve it, as I understand MailScanner runs via postfix user and the problem is that ESET only can be run via esets or root user. I already try to give postfix permissions on wheel grupo or visudo but without success.
Maybe someone can help us with this info.
