permissions and ownership of /var/spool/MailScanner/incoming correct?
Posted: 09 Feb 2018 06:48
by doggy101
the following error is is my logs and the spool fills up
Cannot create temporary Work Dir /var/spool/MailScanner/incoming/16497. Are the permissions and ownership of /var/spool/MailScanner/incoming correct?
i recently updated to the final release before that I had no problems?
Re: permissions and ownership of /var/spool/MailScanner/incoming correct?
Posted: 09 Feb 2018 07:25
by doggy101
changed group and owner to Postfix and it start working again,
very weird...
Posted: 10 Feb 2018 23:35
by carlocomp
Just wondering how and where do you change the ownership /var/spool/MailScanner/incoming.
im having an issue with mine randomly stopping and not receiving emails until reboot it and sometimes have to do the MariaDB Recovery option
thanks Carlo
Posted: 28 Feb 2018 16:51
by doggy101
just changed ownership on the command line or you can use a tool like WinSCP
