EFA - Mailwatch is painfully slow opening reports
Posted: 02 Feb 2018 09:19
Versions: MailWatch for MailScanner v1.2.7-dev running on EFA-3.0.2.5
VMware hosts runnign 6.0.
Before Christmas this problem definitely didn't exist, and even until min January I am fairly sure it wasn't an issue, and we were returning lists of 7000+ emails
However, recently then using the Mailwatch inteface, then using the Search and Reports feature to look at an emails or find a blocked one to release, it is painfully slow. It can take upto a minute to even complete one variable. Then when clicking on the mail list, can be upto say 5000 emails, it takes minutes to open, and initally only returns half the list anyway, you have to wait for the rest of the emails to appear. If you want to then go to page 2 of the returned list you might as well go and get a brew!
Anyway I digress.
We also had some further issues recently with the clamav stopping running, having searched through the forums this was likely caused by a lack of RAM, so I increased the RAM from 4Gb to 8Gb, while doing this I also opted to go from 2 cores to 4 cores, since the box (well VM appliance) was on original setting from when it was installed.
The VAR folder was also small and almost full, showing on 10% space which meant we couldn't update but that has also been resolved now, there is 20GB free instead of 2GB!
All of te above has made no difference and finding mail to release is enfuriating and that is ignoring the issues of someone having a quick spot check for false positives (not everyone gets quarantine report).
Running top on the EFA box returns generally mysql at the top, for CPU usage as oppose to Mailscanner but still aroudn 70% idle.
In the time it has taken me to write this post, clicking mail listing on a filter I did still hasn't loaded.
Anyway I digress.
