Clamav not Updating -EFA Version 3.0.2.6
global
Post by global »
it is safe to download clamav from Clamav site and install it manually? or there is another way to do it.
ClamAV 0.99.2/24271/Wed Jan 31 02:25:10 2018
the new Version is 0.99.3
Re: Clamav not Updating -EFA Version 3.0.2.6
Unless you are having the problems fixed by this patch, I'd wait for it to appear in the yum repository; otherwise you might be creating a problem for yourself on future updates.
global
Post by global »
Okay , i will wait then,
thank you
global
Post by global »
:o I did it anyway but on Test System, i will see then what happens on the next Update.
1- download latest Version from Clamav Site
2- ./configure --with-user=clam --with-group=clamav --with-dbdir=/var/lib/clamav --prefix=/usr --sysconfdir=/etc
3- make
4- make install
# clamd -V
ClamAV 0.99.3/24271/Wed Jan 31 02:25:10 2018
jamerson
Post by jamerson »
global wrote: 31 Jan 2018 11:39 :o I did it anyway but on Test System, i will see then what happens on the next Update.
3- make
4- make install
# clamd -V
i just test this as well, and its appear to work. but i wont have it on production untill the yum is availble .
thank you
global
Post by global »
the inconvinient of a Manually Update.
[root@mail ~]# /etc/init.d/clamd restart
Stopping Clam AntiVirus Daemon: [ OK ]
LibClamAV Error: cli_loadyara: failed to parse rules file /var/lib/clamav/antidebug_antivm.yar, error count 7
LibClamAV Error: yyerror(): /var/lib/clamav/EMAIL_Cryptowall.yar line 34 duplicate identifier "CryptoWall_Resume_phish"
LibClamAV Error: cli_loadyara: failed to parse rules file /var/lib/clamav/EMAIL_Cryptowall.yar, error count 1
[ OK ]
global
Post by global »
Conclusion:
it is better to wait of an efa Update instead of a manually Clamav upgrade. as pdwalker already said.
Those errors are well known. You can search the forums about them. Short answer? You can ignore them.
