Upgrade from v1.2.1-dev Stuck
Posted: 29 Jan 2018 11:20
by d.henning@kerbl.info
The update process stuck at the folowing step:
"- Check for missing tokens in `maillog` table........................"
is there a possibility to clear the table manually or skip the step in the auto update script ?
Thank you!
Re: Upgrade from v1.2.1-dev Stuck
Posted: 29 Jan 2018 20:34
Give it enough time, this can take a while...
