ClamAV Vulnerabilities
Re: ClamAV Vulnerabilities
Post by henk » 14 Mar 2018 19:03
Besides go to church or start praying? :pray:
You did put the # on the start of the exclude line in /etc/yum.conf?
Can you post the result
yum list clamav
Post by pdwalker » 15 Mar 2018 06:49
henk wrote:
14 Mar 2018 09:43
clamav-db.x86_64 0.99.4-1.el6 has landed :D
yep, just updated mine and got 99.4-1.
dwmp, if you are still having a problem, check your /etc/yum.conf as henk suggests.
Also, since it is being pulled from the epel repo, check your /etc/yum.repos.d/epel.repo file.
Is the "Extra Packages for Enterprise Linux 6 - $basearch" "enabled = 1"?
dwmp
Post by dwmp » 19 Mar 2018 08:41
Hi!
Thank you very much. I was totally at a loss, I didn't see that the line in yum.conf was NOT comment (I have added # now).
Now I get clamav updates, but also updates for kernel, kernel-firmware and so on. So my (hopefully) last two questions:
- is it safe to install them as well?
- shall I remove the # from the yum.conf-file after I installed updates?
Thanks for your patience!
Post by henk » 19 Mar 2018 09:28
I've got bad days on a regular basis :lol:
- is it safe to install them as well? Yes
- shall I remove the # from the yum.conf-file after I installed updates? I always restore the original situation. (incl the #)
Make snapshot or backup.
Stop mail flow
stop crond.
service crond stop
and reboot after the update. (updates for kernel, kernel-firmware)
check the logs :!:
enjoy E.F.A ;)
dwmp
Post by dwmp » 19 Mar 2018 10:05
I will do that, thank you! :)
Post by pdwalker » 19 Mar 2018 11:37
henk wrote:
19 Mar 2018 09:28
[snip]
[snip]
You don't have to make a snapshot or backup, if you're supremely confident that can can solve any kind of problem that results from a bad update (like myself).
However, I can tell you that some of my worst days were because I didn't take a snapshot or backup.
dwmp
Post by dwmp » 21 Mar 2018 06:17
Worked! Thank you for your help again.
After update installations I added the "#" in yum.conf again to restore original state
budy
Post by budy » 28 Mar 2018 09:36
I actually don't see the need for that. Afair, this change had been introduced when updating to the latest or some other newer versions of eFa.
I did not comment this line, since I also want the next updates to ClamAv to make it onto my eFa automatically.
Post by pdwalker » 28 Mar 2018 09:53
budy is right I believe.
Would shawniverson care to comment?
Post by shawniverson » 28 Mar 2018 13:52
You may leave the exclusions commented out. No more updates are pending for v3, and I am working daily on v4.
dwmp
Post by dwmp » 04 Apr 2018 12:29
Alright, thanks for the information/support, guys!
Re: ClamAV Vulnerabilities version: 0.100.0
Post by henk » 11 Apr 2018 21:31
ClamAV reached the 100 mark :ugeek:
Software version from DNS: 0.100.0
WARNING: Local version: 0.99.4 Recommended version: 0.100.0
It's not available in the repo yet. Just wait for it. :hand:
Re: ClamAV 0.100.0 available
Post by henk » 14 Jul 2018 21:38
As there is already version 0.100.1, upgrading to 0.100.0 is still recommended. It contains many code submissions from the ClamAV community.
https://github.com/Cisco-Talos/clamav-d ... 1/NEWS.md
My upgrade steps.
Check for updates
yum check-update
Make backup :lol:
As I dont like cronjobs during the upgrade ( stop the mailflow) and stop clam
service crond stop
service clamd stop
upgrade
yum upgrade
Remove old database
rm /var/lib/clamav/daily.cld
Get new dbs
freshclam -v
sa-update -v
To get rid of yara related errors. ( you can always enable it again)
/etc/clamav-unofficial-sigs/master.conf
yararulesproject_enabled="no"
enable_yararules="no"
And delete or move to backup dir from /var/lib/clamav/
rm /var/lib/clamav/*yar
rm /var/lib/clamav/*yara
Check clamd.conf and freshclam.conf for custom and depricated settings
warning: /etc/clamd.conf created as /etc/clamd.conf.rpmnew
warning: /etc/freshclam.conf created as /etc/freshclam.conf.rpmnew
service clamd start
reboot to check it all ( new kernel?)
check the logs :violin:
Clamav 100.1-1 - ClamAV Vulnerabilities
Post by henk » 25 Jul 2018 07:26
Clamav 100.1-1 available.
yum list clamav
Installed Packages
clamav.x86_64 0.100.0-1.el6 @epel
Available Packages
clamav.i686 0.100.1-1.el6 epel
clamav.x86_64 0.100.1-1.el6 epel
after update: run
freshclam -v
and
sa-update -v
check clamav
service clamd restart
Stopping Clam AntiVirus Daemon:                            [  OK  ]
Starting Clam AntiVirus Daemon:                            [  OK  ]
dwmp
Post by dwmp » 30 Jul 2018 08:32
I tried to install the updates without success, what I did:
- disable mail income, create backup
- comment the line
#exclude=kernel* postfix* mailscanner* MailScanner* clamav* clamd* open-vm-tools*
service crond stop
sudo yum update
- Reboot
- Installing Webmin update
- Reboot
=> While booting I saw some ClamAV-related erros, also I got some error notifications "service <postfix/httpd/mysql/clamd> down and restarted..." (the notification for clamd came 3 times). So I did the following:
service crond stop
service clamd stop
freshclam -v
sa-update –v
service clamd start
- Reboot
- Everything seemed fine, boot errors regarding clamav were still there but I "realized" they have been there before the updates without making problems
- I enabled mail income + wrote some test mails
=> the first came properly through, the second (and also another incoming mail) one appeared in in MailWatch but didn't come to my Outlook. After a moment the message appeared again in the MailWatch-list, that went on every few seconds so after a few minutes I had great list in MailWatch including those two emails appearing again and again (but without releasing them to the mailboxes in the mailserver)
=> So I shut down EFA again and restored the backup/snapshot, so now it is running again (but old versions of course).
I saved the corrupt state and now I am trying to find out what the problem was, to execute the update again (and this time properly).
I viewed some logs but I didn't get a hint what the reason might be. Wenn I shut it down it says FAILED when trying to stop the Clamav service.
Has someone an idea what to do?
BR
dwmp
Post by henk » 30 Jul 2018 08:37
Seems you missed some steps in this post
to get rid of yara related errors. ( you can always enable it again)
dwmp
Post by dwmp » 08 Aug 2018 05:43
Thank you! I will try that.
Do you think that the problem (that mails are not coming through Outlook and reappearing in Mailwatch list) will also be resolved with your recommendation?
Or is it only for the boot-error-messages?
Post by henk » 08 Aug 2018 08:48
I quess you will find the answer in this post viewtopic.php?f=14&p=12615#p12615 :)
dwmp
Post by dwmp » 23 Oct 2018 05:25
Thank you very much, it worked!
