You did put the # on the start of the exclude line in /etc/yum.conf?
Can you post the result
yum list clamav
yum list clamav
yep, just updated mine and got 99.4-1.
service crond stop
You don't have to make a snapshot or backup, if you're supremely confident that can can solve any kind of problem that results from a bad update (like myself).
yum check-update
service crond stop
service clamd stop
yum upgrade
rm /var/lib/clamav/daily.cld
freshclam -v
sa-update -v
yararulesproject_enabled="no"
enable_yararules="no"
rm /var/lib/clamav/*yar
rm /var/lib/clamav/*yara
service clamd start
yum list clamav
freshclam -v
sa-update -v
service clamd restart
Stopping Clam AntiVirus Daemon: [ OK ]
Starting Clam AntiVirus Daemon: [ OK ]
#exclude=kernel* postfix* mailscanner* MailScanner* clamav* clamd* open-vm-tools*
service crond stop
sudo yum update
service crond stop
service clamd stop
freshclam -v
sa-update –v
service clamd start
