ClamAV Vulnerabilities
sebastian.savard
Re: ClamAV Vulnerabilities
Post by sebastian.savard » 29 Jan 2018 15:10
I'm assuming this is an update that we'll have to perform on our own systems, as 3.0.2.6 is the last of version 3. Has any successfully upgraded?
Post by shawniverson » 29 Jan 2018 20:02
eFa uses the clamav from epel, so hopefully it'll get updated soon and all you will need to do is run a yum update.
Version 3.0.2.6 released! Update now to keep your eFa secure!
dwmp
Post by dwmp » 06 Feb 2018 09:32
how can I check if the update is available?
Post by pdwalker » 06 Feb 2018 11:08
from the efa command prompt:
sudo yum update
dwmp
Post by dwmp » 08 Feb 2018 07:33
Thanks. But is that really only the check for updates? Or will there be updates installed via the command?
Post by pdwalker » 08 Feb 2018 09:56
That command will check for updates, and if there are any, will ask you to confirm before updating. If you say "n", then nothing further will happen.
dwmp
Post by dwmp » 08 Feb 2018 10:48
Alright, thank you!
dwmp
Post by dwmp » 02 Mar 2018 06:23
Somebody an idea why there is still no update?
Post by pdwalker » 05 Mar 2018 03:26
updated
 clamav                       x86_64               0.99.3-8.el6                      epel                     4.3 M
 clamav-db                    x86_64               0.99.3-8.el6                      epel                     155 M
All good things come to those who wait.
dwmp
Post by dwmp » 05 Mar 2018 07:35
Do I need to reboot the system after clamav-update?
Post by henk » 05 Mar 2018 13:41
Run
freshclam -v
Software version from DNS: 0.99.4
WARNING: Local version: 0.99.3 Recommended version: 0.99.4 :whistle:
Sometimes good things come to those who wait a bit longer.... ;)
Post by pdwalker » 05 Mar 2018 16:20
dwmp: no. the necessary services will be restarted.
henk: :lol:
budy
Post by budy » 05 Mar 2018 18:15
Hmmm… my clamav is still on 0.99.2 but yum update won't server a newer one:
[root@efa yum.repos.d]# yum list clamav
 * EFA: dl.efa-project.org
 * base: ftp.rz.uni-frankfurt.de
 * epel: mirror.de.leaseweb.net
 * extras: ftp.rz.uni-frankfurt.de
 * remi-php72: rpms.remirepo.net
 * remi-safe: rpms.remirepo.net
 * updates: mirror.checkdomain.de
Installed Packages
clamav.x86_64                                           0.99.2-3.el6                                           @epel
Trying to yum update, also doesn't work:
[root@efa yum.repos.d]# yum update clamav clamav-db
Setting up Update Process
 * extras: artfiles.org
 * updates: centosmirror.netcup.net
No Packages marked for Update
I tried without mirrors, clean yum's cache and DB, but to no avail. Any other idea, anyone?
Post by henk » 05 Mar 2018 20:04
What is your EFA version?
on versions below 3.0.26 yum.conf will exclude several packages from updating.
If you are on the latest version, remove them and run: yum check-update
dwmp
Post by dwmp » 06 Mar 2018 06:29
same problem here, clamav is 0.99.2 but "No Packages marked for Update" (EFA 3.0.2.6)
Post by henk » 06 Mar 2018 08:56
Seems related to the epel repo used. Did you check /etc/yum.conf?
#exclude=kernel* postfix* mailscanner* MailScanner* clamav* clamd* open-vm-tools*
Otherwise just wait a bit longer till they update the repo. I don't know if switching the epel repo is a good idea.
[root@sansspam ~]# yum list clamav
* base: mirror.widexs.nl
* epel: fedora.cu.be
* extras: centos.mirror1.spango.com
* mariadb: ftp.nluug.nl
* remi-php72: mirror.netweaver.uk
* remi-safe: mirror.netweaver.uk
* updates: mirror.yourwebhoster.eu
Installed Packages
clamav.x86_64 0.99.3-8.el6
Available Packages
clamav.i686 0.99.3-8.el6
budy
Post by budy » 06 Mar 2018 10:23
Hi henk,
thanks, that solved it.
Thanks,
budy
dwmp
Post by dwmp » 13 Mar 2018 07:58
so that means, if we don't want to switch epel repo, we still have to wait?
Or is it necessary to delete "clamav*" and/or "clamd" entries from the yum.conf file?
BR
dwmp
Post by henk » 13 Mar 2018 08:39
Hi dwmp.
Forget the remark about switching repos.
yum check-update
dwmp
Post by dwmp » 13 Mar 2018 10:25
hi henk,
thanks for your reply! Sorry for asking silly questions, but by removing, you mean deleting the entries for clamav and clamd from the yum.conf file?
So that the config file looks like that:
#exclude=kernel* postfix* mailscanner* MailScanner* open-vm-tools*
Post by henk » 13 Mar 2018 14:17
the # on the start of the line already means : this line is comment. The rest of the line is ignored.
Running yum check-update will show you the packages to be updated.
No result means: packages already up to date.
Do not change yum.conf if you are not on E.F.A. 3.0.2.6. And always make backups/snapshots before you update.....
Post by henk » 14 Mar 2018 09:43
clamav-db.x86_64 0.99.4-1.el6 has landed :D
dwmp
Post by dwmp » 14 Mar 2018 11:10
Hi henk,
thank you!
Im running on EFA 3.0.2.6. When executing "yum check-update" I get no clamav-package.
Still version ClamAV 0.99.2 is installed.
What do I have to do?
BR
dwmp
