Size limite of recieving emails.
Posted: 05 Jan 2018 11:18
by jamerson
Daer All,
I understand that EFA is using standarts limite of 9MB.
when i use send us a email with attachement bigger than 9MB they get this respond back.
efa.domain.com
Remote Server returned '550 5.3.4 SMTPSEND.OverAdvertisedSize; message size exceeds fixed maximum size'
Does anyone knows how can we change the limite on the EFA?
Re: Size limite of recieving emails.
Posted: 05 Jan 2018 11:37
by Zwabber
edit /etc/postfix/main.cf and change the parameter message_size_limit to what you want the limit to be. (or include the parameter if it is not there)
message_size_limit = 20480000
Posted: 05 Jan 2018 13:10
by jamerson
Thank you for your answer
i managed to do this using the
sudo postconf -e message_size_limit=50480000
sudo /etc/init.d/postfix restart
also for people who doesn't like the shell .
Also consider using the webadmin module under
- servers
- Postfix Mail Server
- General Resource Control
- Max size of a message
Posted: 11 Jan 2018 12:59
by jamerson
Hi guys,
the error has comes back
Remote Server returned '550 5.2.3 RESOLVER.RST.SendSizeLimit.Org; message too large for this organization'
Received: from EX-DKS.DKS.lan (192.168.6.3) by EX-DKS.DKS.lan (192.168.6.3)
with Microsoft SMTP Server (TLS) id 15.0.1347.2; Thu, 11 Jan 2018 13:27:46
+0100
Received: from filter.domain.com.com (192.168.6.5) by EX-DKS.DKS.lan
(192.168.6.3) with Microsoft SMTP Server (TLS) id 15.0.1347.2 via Frontend
Transport; Thu, 11 Jan 2018 13:27:46 +0100
X-Spam-Status: No
X-dks-MailScanner-EFA-Watermark: 1516278463.87526@WSO4MymhY8jv8tlPoWh+Qg
X-dks-MailScanner-EFA-From: pablo.riveiro@recieving.com
X-dks-MailScanner-EFA: Found to be clean
X-dks-MailScanner-EFA-ID: 12D99440372.A821F
X-dks-MailScanner-EFA-Information: Please contact info@domain.com for more information
X-Greylist: domain auto-whitelisted by SQLgrey-1.8.0
Received: from NAM03-BY2-obe.outbound.protection.outlook.com (mail-by2nam03on0074.outbound.protection.outlook.com [104.47.42.74])
(using TLSv1.2 with cipher ECDHE-RSA-AES256-SHA384 (256/256 bits))
by filter.domain.com.com (Postfix) with ESMTPS id 12D99440372
Posted: 11 Jan 2018 13:23
first check current setting
try this with postconf or edit /etc/postfix/main.cf
# bump up the default messagessize limit: default message_size_limit = 10240000
# big mb limit
message_size_limit = 104857600
virtual_mailbox_limit = 0
mailbox_size_limit = 0
Posted: 11 Jan 2018 14:48
by jamerson
Thank you Henk for your answer.
see below log of the postconf -n its appear to be fine with 50mb.
admin@filter ~]$ postconf -n
2bounce_notice_recipient = support@domain.com
alias_database = hash:/etc/aliases
alias_maps = hash:/etc/aliases
broken_sasl_auth_clients = yes
command_directory = /usr/sbin
compatibility_level = 2
daemon_directory = /usr/libexec/postfix
data_directory = /var/lib/postfix
debug_peer_level = 2
debugger_command = PATH=/bin:/usr/bin:/usr/local/bin:/usr/X11R6/bin ddd $daemon_ directory/$process_name $process_id & sleep 5
default_destination_recipient_limit = 1
delay_notice_recipient = support@domain.com
disable_vrfy_command = yes
error_notice_recipient = support@domain.com
header_checks = regexp:/etc/postfix/header_checks
html_directory = no
inet_interfaces = all
inet_protocols = ipv4
local_recipient_maps =
mail_owner = postfix
mailq_path = /usr/bin/mailq.postfix
manpage_directory = /usr/share/man
masquerade_domains = $mydomain
message_size_limit = 50240000
meta_directory = /etc/postfix
mydestination = $myhostname, localhost.$mydomain, localhost
mynetworks = 127.0.0.0/8 mail.company.com
myorigin = $mydomain
newaliases_path = /usr/bin/newaliases.postfix
notify_classes = resource, software, delay, bounce
queue_directory = /var/spool/postfix
readme_directory = /usr/share/doc/postfix-3.1.3/README_FILES
sample_directory = /usr/share/doc/postfix-3.1.3/samples
sendmail_path = /usr/sbin/sendmail.postfix
setgid_group = postdrop
shlib_directory = no
smtp_sasl_password_maps = hash:/etc/postfix/sasl_passwd
smtp_sasl_type = cyrus
smtp_tls_CAfile = /etc/postfix/ssl/rsa_smtpd.pem
smtp_tls_mandatory_protocols = !SSLv2,!SSLv3
smtp_tls_note_starttls_offer = yes
smtp_tls_protocols = !SSLv2,!SSLv3
smtp_tls_session_cache_database = btree:/var/lib/postfix/smtp_tls_session_cache
smtp_use_tls = yes
smtpd_client_restrictions = permit_sasl_authenticated, reject_rbl_client zen.spa mhaus.org, reject_unknown_reverse_client_hostname
smtpd_delay_reject = yes
smtpd_helo_required = yes
smtpd_helo_restrictions = check_helo_access hash:/etc/postfix/helo_access, rejec t_invalid_hostname
smtpd_recipient_restrictions = permit_sasl_authenticated, permit_mynetworks, rej ect_unauth_destination, reject_non_fqdn_recipient, reject_unknown_recipient_doma in, check_recipient_access hash:/etc/postfix/recipient_access, check_policy_serv ice inet:127.0.0.1:2501
smtpd_sasl_auth_enable = yes
smtpd_sasl_local_domain =
smtpd_sasl_path = smtpd
smtpd_sasl_security_options = noanonymous
smtpd_sender_restrictions = permit_sasl_authenticated, check_sender_access hash: /etc/postfix/sender_access, reject_non_fqdn_sender, reject_unknown_sender_domain
smtpd_tls_CAfile = /etc/postfix/ssl/rsa_smtpd.pem
smtpd_tls_cert_file = /etc/postfix/ssl/rsa_smtpd.pem
smtpd_tls_ciphers = medium
smtpd_tls_dh1024_param_file = /etc/postfix/ssl/dhparam.pem
smtpd_tls_key_file = /etc/postfix/ssl/rsa_smtpd.pem
smtpd_tls_loglevel = 1
smtpd_tls_received_header = yes
smtpd_tls_session_cache_database = btree:/var/lib/postfix/smtpd_tls_session_cach e
smtpd_tls_session_cache_timeout = 3600s
smtpd_use_tls = yes
smtputf8_enable = no
tls_medium_cipherlist = ECDSA+AESGCM:ECDH+AESGCM:DH+AESGCM:ECDSA+AES:ECDH+AES:DH +AES:ECDH+3DES:DH+3DES:RSA+AESGCM:RSA+AES:RSA+3DES:!aNULL:!MD5:!DSS
tls_preempt_cipherlist = yes
tls_random_source = dev:/dev/urandom
transport_maps = hash:/etc/postfix/transport
unknown_local_recipient_reject_code = 550
virtual_alias_maps = hash:/etc/postfix/virtual
Posted: 11 Jan 2018 15:08
by Zwabber
This looks like a Exchange warning (limited send connector?) and not EFA
Posted: 11 Jan 2018 16:17
by jamerson
Zwabber wrote: 11 Jan 2018 15:08
good catch,
thank you so much for your answer.
we managed to get this fixed with the exchange limite.
a big thank you sir.
