Hey there,
I'm trying to update to 3.0.2.5 but I always getting an error on the hyper-v part:
[EFA] Good you are root
[EFA] Starting update to EFA-3.0.2.5
Setting up Update Process
* EFA: dl7.efa-project.org
* base: mirror.infonline.de
* epel: mir01.syntis.net
* extras: centos.mirror.iphh.net
* mariadb: mirror.netcologne.de
* updates: centos.mirror.iphh.net
http://centos.mirror.iphh.net/CentOS/6. ... repomd.xml: [Errno 12] Timeout on http://centos.mirror.iphh.net/CentOS/6. ... repomd.xml: (28, 'Operation too slow. Less than 1 bytes/sec transfered the last 30 seconds')
Trying other mirror.
http://centos.mirror.iphh.net/CentOS/6. ... repomd.xml: [Errno 14] PYCURL ERROR 7 - "Failed to connect to 2001:868:0:182::13: Network is unreachable"
Resolving Dependencies
--> Running transaction check
---> Package kernel.x86_64 0:2.6.32-696.16.1.el6 will be installed
---> Package kernel-devel.x86_64 0:2.6.32-696.16.1.el6 will be installed
---> Package kernel-firmware.noarch 0:2.6.32-696.10.3.el6 will be updated
---> Package kernel-firmware.noarch 0:2.6.32-696.16.1.el6 will be an update
---> Package kernel-headers.x86_64 0:2.6.32-696.10.3.el6 will be updated
---> Package kernel-headers.x86_64 0:2.6.32-696.16.1.el6 will be an update
---> Package kernel.x86_64 0:2.6.32-642.15.1.el6 will be erased
--> Processing Dependency: kernel < 2.6.32-643 for package: kmod-microsoft-hyper-v-4.1.2-20160809.x86_64
--> Processing Dependency: kernel(__vmbus_driver_register) = 0xb1b6bc8c for package: kmod-microsoft-hyper-v-4.1.2-20160809.x86_64
--> Processing Dependency: kernel(vmbus_close) = 0x9751d826 for package: kmod-microsoft-hyper-v-4.1.2-20160809.x86_64
--> Processing Dependency: kernel(vmbus_driver_unregister) = 0xd15637a5 for package: kmod-microsoft-hyper-v-4.1.2-20160809.x86_64
--> Processing Dependency: kernel(vmbus_open) = 0xddc5c776 for package: kmod-microsoft-hyper-v-4.1.2-20160809.x86_64
--> Processing Dependency: kernel(vmbus_recvpacket_raw) = 0x4cd23ff4 for package: kmod-microsoft-hyper-v-4.1.2-20160809.x86_64
--> Processing Dependency: kernel(vmbus_sendpacket) = 0x60267c8f for package: kmod-microsoft-hyper-v-4.1.2-20160809.x86_64
---> Package kernel-devel.x86_64 0:2.6.32-642.15.1.el6 will be erased
---> Package kmod-microsoft-hyper-v.x86_64 0:4.1.2-20160809 will be erased
--> Processing Dependency: microsoft-hyper-v-kmod = 4.1.2 for package: microsoft-hyper-v-4.1.2-20160809.x86_64
---> Package microsoft-hyper-v.x86_64 0:4.1.2-20160809 will be erased
Error: Package: kmod-microsoft-hyper-v-4.1.2-20160809.x86_64 (installed)
Requires: kernel < 2.6.32-643
Removing: kernel-2.6.32-642.15.1.el6.x86_64 (@updates)
kernel = 2.6.32-642.15.1.el6
Installed: kernel-2.6.32-696.1.1.el6.x86_64 (@updates)
kernel = 2.6.32-696.1.1.el6
Installed: kernel-2.6.32-696.3.1.el6.x86_64 (@updates)
kernel = 2.6.32-696.3.1.el6
Installed: kernel-2.6.32-696.3.2.el6.x86_64 (@updates)
kernel = 2.6.32-696.3.2.el6
Installed: kernel-2.6.32-696.10.3.el6.x86_64 (@updates)
kernel = 2.6.32-696.10.3.el6
Available: kernel-2.6.32-696.el6.x86_64 (base)
kernel = 2.6.32-696.el6
Available: kernel-2.6.32-696.6.3.el6.x86_64 (updates)
kernel = 2.6.32-696.6.3.el6
Available: kernel-2.6.32-696.10.1.el6.x86_64 (updates)
kernel = 2.6.32-696.10.1.el6
Available: kernel-2.6.32-696.10.2.el6.x86_64 (updates)
kernel = 2.6.32-696.10.2.el6
Available: kernel-2.6.32-696.13.2.el6.x86_64 (updates)
kernel = 2.6.32-696.13.2.el6
Installing: kernel-2.6.32-696.16.1.el6.x86_64 (updates)
kernel = 2.6.32-696.16.1.el6
Available: kernel-debug-2.6.32-696.el6.x86_64 (base)
Available: kernel-debug-2.6.32-696.1.1.el6.x86_64 (updates)
Available: kernel-debug-2.6.32-696.3.1.el6.x86_64 (updates)
Available: kernel-debug-2.6.32-696.3.2.el6.x86_64 (updates)
Available: kernel-debug-2.6.32-696.6.3.el6.x86_64 (updates)
Available: kernel-debug-2.6.32-696.10.1.el6.x86_64 (updates)
Available: kernel-debug-2.6.32-696.10.2.el6.x86_64 (updates)
Available: kernel-debug-2.6.32-696.10.3.el6.x86_64 (updates)
Available: kernel-debug-2.6.32-696.13.2.el6.x86_64 (updates)
Available: kernel-debug-2.6.32-696.16.1.el6.x86_64 (updates)
** Found 1 pre-existing rpmdb problem(s), 'yum check' output follows:
kmod-microsoft-hyper-v-4.2.3.1-20171101.x86_64 is a duplicate with kmod-microsoft-hyper-v-4.1.2-20160809.x86_64
sendmail: warning: /etc/postfix/main.cf, line 764: overriding earlier entry: smtpd_client_restrictions=permit_sasl_authenticated, reject_rbl_client sbl.spamhaus.org, reject_rbl_client cbl.abuseat.org, reject_rbl_client all.spam-rbl.fr, reject_rbl_client bl.spamcop.net, reject_rbl_client relays.mail-abuse.org, reject_rbl_client sbl-xbl.spamhaus.org, reject_rbl_client zen.spamhaus.org, reject_rbl_client b.barracudacentral.org
postdrop: warning: /etc/postfix/main.cf, line 764: overriding earlier entry: smtpd_client_restrictions=permit_sasl_authenticated, reject_rbl_client sbl.spamhaus.org, reject_rbl_client cbl.abuseat.org, reject_rbl_client all.spam-rbl.fr, reject_rbl_client bl.spamcop.net, reject_rbl_client relays.mail-abuse.org, reject_rbl_client sbl-xbl.spamhaus.org, reject_rbl_client zen.spamhaus.org, reject_rbl_client b.barracudacentral.org
Update to Version 3.0.2.4 FAILED. Updates cancelled.
The question is, can i exclude this part from been checkt because I updated the Linux Integration Service for hyper-v already to 4.2.x so I don't want to downgrade that again.
Thanks for every helpful answer.
best regars
3.0.2.5 update failed - hyper-v problem!
Re: 3.0.2.5 update failed - hyper-v problem!
the ipv6 error can be ignored. already fixed.
Part of the problem here is that you are going to have to reapply kmod-microsoft-hyper-v anyway because it is a set of kernel modules, and the kernel update is probably going to break it anyway if you exclude it. So I would advise erasing it, upgrading the kernel, and reinstalling it, to make sure it installs the right modules for the updated kernel after restarting.
thanks for your answer already
Do you have the commands for that? Sorry I'm not a linux pro just started with it^^
thanks alot. I could uninstall the hyper stuff with the following part:
rpm -e `rpm -qa | grep hyper`
after that the update could be installed and I'm now on 3.0.2.5.
Thanks a lot for your help. Awesome project!
