Interesting email based blacklist
Post by nicola.piazzi » 24 Nov 2017 13:20
Take a look to this
https://msbl.org
here 2 config files to put in /etc/mail/spamassassin
http://msbl.org/tools/sa-hashbl.tar.gz
I installed it 1 hour ago and i have no hits at the moment
Re: Interesting email based blacklist
Post by pdwalker » 24 Nov 2017 18:10
Can’t hurt to try. I’ll implement it tomorrow and see what happens.
Post by nicola.piazzi » 27 Nov 2017 07:43
Only 11 hits in the weekend but absolutely no false positive, i ' ll increase score to 3.00
Post by pdwalker » 27 Nov 2017 07:50
I just turned it on less than three hours ago, and I've already gotten three hits.
Excellent.
Post by nicola.piazzi » 27 Nov 2017 07:59
yes,
there are not a lot of hits because this is non a rbl
this is email address based so it have few entries but these are sure that is spam
Post by pdwalker » 27 Nov 2017 08:20
Every little bit helps.
Post by pdwalker » 12 Jan 2018 07:51
So far, I've gotten 242 messages to trigger this rule. 100% spam. Increasing the spam score to 4.0
Post by nicola.piazzi » 12 Jan 2018 08:22
yes, they are based on real case so hit is 100%
Alleyviper
Post by Alleyviper » 08 Jan 2019 02:57
Hi there,
Where to put pm file included?
Post by nicola.piazzi » 08 Jan 2019 07:27
same dir where local.cf
Alleyviper
Post by Alleyviper » 22 Jan 2019 23:17
Hi Nicola,
Works like a charm :)
Check the custom phishing.bad.sites.custom to enhance event more blocking bad stuff
https://forum.efa-project.org/viewtopic.php?f=14&t=3334
ovizii
Post by ovizii » 05 Mar 2019 12:09
Alleyviper wrote:
08 Jan 2019 02:57
Hi there,
I don't think its necessary to do anything. as of Sa 3.4.2 if you have /etc/mail/spamassassin/hashbl.cf look inside, mine says:
loadplugin Mail::SpamAssassin::Plugin::HashBL   HashBL.pm
ifplugin Mail::SpamAssassin::Plugin::HashBL
    header   HASHBL_EMAIL       eval:check_hashbl_emails('ebl.msbl.org')
    describe HASHBL_EMAIL       Message contains email address found on the EBL
    score    HASHBL_EMAIL       1.0
endif
then go to your EFA dashboard => Tools and Links => Spamassassin Lin (Test) then check if HASHBL_EMAIL was loaded.
