While trying to allow certain file extensions like xxx.avis.png that is blocked as bad content due to scanner setting, I modified /etc/MailScanner/filename.rules.conf.
Then all messages started to be quarantined, and marked with
Other Infection = Y
Report: MailScanner: Message attempted to kill MailScanner
I removed the modification to filename.rules.conf, and returned back to normal mail flow.
However, There are around 50 email quarantined and I cannot be able to release them by selecting release checkbox and submitting on the quarantine detail page..
My mailscanner.conf settings has following
As I understand because mesages are not quarantined as Queue Files, I cannot release them.
Is there a way to release there type of messages..
Thanks,
levent
How to release messages from quarantine marked with "Other Infection" YES
Re: How to release messages from quarantine marked with "Other Infection" YES
I have tackled this issue before by feeding the emails to the sendmail script and letting it queue them back into postfix.
Thanks for the idea.. (because there are not so many messages), as a workaround I downloaded the quarantined message files via webmin file manager ; renamed to xxx.eml and emailed as an attachment.
Instructions? This would be a useful thing to know.shawniverson wrote: 15 Nov 2017 23:35 I have tackled this issue before by feeding the emails to the sendmail script and letting it queue them back into postfix.
The basic idea is to do this:
sudo /usr/sbin/sendmail.postfix -t < /var/spool/MailScanner/quarantine/<somedate>/<somefolder>/<somemsgid>
This saved my bacon today. This tip should be in the wiki.
