After an upgrade from 3.0.1.x to latest EFA 3.0.2.5 the training/tuning feature enabling users to tune SA is gone missing from the MailScanner GUI (details.php), so it not possible to train, release, deleted or view the message.
The Release, Deleted and pulldown menu witht the Ham, Spam, Ham+Revoke, Spam+Report pulldown and View message options is gone.
Se attached picture.
At the same time we got this message in the ssl_error.log which aparantly is related:
[Tue Nov 14 02:12:22 2017] [error] [client zz.zz.zz.zz] PHP Fatal error: Uncaught exception 'mysqli_sql_exception' with message 'Unknown column 'released' in 'field list'' in /var/www/html/mailscanner/functions.php:975\nStack trace:\n#0 /var/www/html/mailscanner/functions.php(975): mysqli->query('SELECT released...')\n#1 /var/www/html/mailscanner/detail.php(480): dbquery('SELECT released...')\n#2 {main}\n thrown in /var/www/html/mailscanner/functions.php on line 975
After Upgrade to 3.0.2.5 Learn/training missing in footer
- Footer with Qurantine options is missing in GUI
- snapshot.JPG (154.06 KiB) Viewed 7202 times
Re: After Upgrade to 3.0.2.5 Learn/training missing in footer
Check your link. It points at a non existent topic.
Useful pointer to a solution. Thanks.
