Hi, I upgraded from 3.0.1.5 to 3.0.2.5 by using EFA-Update .. It looked finished successfully ..
However, when I login to mailwatch home page, there is only the header section display on the page, content or menu does not display.
any suggestions?
Thanks,
Upgrade from 3.0.1.5 to 3.0.2.5 mailwatch
kingramon0
Re: Upgrade from 3.0.1.5 to 3.0.2.5 mailwatch
I don't know if you are seeing the same problem that I was, but I solved my issue. If they are similar this might help: viewtopic.php?f=13&t=2808
Thanks.. I looked at the posts , but could not come up with a solution. So, I boot up my backup VM and revert back to 3.0.1.5 for now.
Will try to upgrade later again or configure a new box with latest version..
The EFA update log will tell you if and where things went off the rails. Use that to diagnose the problem next time.
