Single Target Domain and Langage File
Posted: 27 Oct 2017 08:12
by yugawa806
My questions are two.
1. eFa works for only Single Target Domain?
2. After uploading another Langage Translation File of eFa,
what part of and How to modify the code of eFa system?
Regards.
Re: Single Target Domain and Langage File
Posted: 27 Oct 2017 21:05
1) You can add many domains to eFa
2) What did you modify? Can you share the path? That will help me point you to the right place.
Posted: 28 Oct 2017 07:04
by yugawa806
1) That is a wonderful software.
2) Since I have only 2 days from installatin success,
My understanding may not be accurate.
Lang control: /var/www/html/mailscanner/conf.php
English translation file I downloaded:
/var/www/html/mailscanner/languages/en.php
Posted: 28 Oct 2017 12:26
Open an issue with MailWatch and tell them you want to contribute a translation
https://github.com/mailwatch/MailWatch
They are always looking for translators, so you may want to follow this project. Sometimes they request things to be translated, and you could help them
If you need help, or need someone to send the changes to them, let me know
Posted: 01 Nov 2017 03:55
by yugawa806
Thank you very much.
Posted: 08 Nov 2017 07:30
by yugawa806
Today I sent the Japanese Langage File to Manuel (MailWatch support), thank you.
I hope it will be reflected in next version.
