blacklist - adding address not working
bostjanc
Post by bostjanc »
Hi guys.
We had efa 3.0.2.4 with problem, that if you added an address to blacklist and clicked save, nothing really happened.
Then we have upgraded to EFA 3.0.2.5 and it's a same behavour.
How to find the root of the problems?
I also take a look inside folder /var/log/httpd; error_log file but there is nothing useful (appologize for my linux noob knowledge).
Please advise.
bostjanc
Re: blacklist - adding address not working
Post by bostjanc »
Even if I try to add domain name like this (see printscreen bellow), still nothing happens when I click ADD:
bostjanc
Post by bostjanc »
OMG it was browser related.
This thing does not work in IE, but in FIREFOX does...
Pure luck I have found the solution...
Sharing if anyone has the same issues... :shock:
People still use IE?
bostjanc
Post by bostjanc »
How will you install/download other browser then if you must install Windows? ;)
budy
Post by budy »
Downloading the current version of FF ist amlost the first thing I do, when I need to do any work on any Windows installation… :lol:
bostjanc wrote: 20 Oct 2017 12:31 How will you install/download other browser then if you must install Windows? ;)
Keep the installer for a modern supported browser on a usb stick.
