Today, I noticed my virtual machines time was 50 minutes off.
(Intresting information: System Time on mailwatch showed the correct time, but in console and webmin
the system time was incorrect.)
I checked and there was no time server set.
I suggest to put a time server on webmin:
Just press the current time on system information and set a "Time server sync"
and give a timeserver hostname (ie: 0.pool.ntp.org )
Regards,
Andras
PS: Probably it would be useful to have it set at install.
time sync
TheGr8Wonder
Re: time sync
NTP is configured at time of build. What version of eFa did you start off with and have upgraded over the years?
Re: time sync
I started with 3.0.2.3 -> 3.0.2.4 -> 3.0.2.5
Regards,
Andras
Regards,
Andras
