Send Email with Zimbra To Efa
Posted: 09 Oct 2017 20:48
by amanfredini
can i send email with zimbra through Efa?
When I Try, the error in efa are .. Client Host Rejected, cannot find your reverse hostname (192.168.1.45) from
mymail@domain.it to
mymail2@gmail.com
Re: Send Email with Zimbra To Efa
Posted: 13 Oct 2017 17:24
by budy
This error isn't related to Zimbra in any way, but to the fact, that the efa wants to reverse lookup the IP of your Zimbra MTA. You seem to run on an internal network without a proper DNS setup - well at least from efa's perspective.
You can configure postfix to not perform this lookup, or you can setup a fully internal DNS to statisfy efa.
Posted: 13 Oct 2017 18:15
by amanfredini
How can I setup postfix for not perform lookup?
Posted: 14 Oct 2017 06:53
by budy
Login to Mailscanner and chose the WebMin link from the "Tools and Links" menu. Then chose Servers -> Postfix Mail Server -> "General Options". Find the "Local networks" setting and add the IP of your Zimbra 192.168.1.45/32 into the input field and hit "Save and Apply". Then bounce postfix by hitting "Reload Configuration" on the Webmin page.
Posted: 14 Oct 2017 08:36
by amanfredini
I have done this configuration but the error still present. Rcpt from unknown (192.168.1.45) client hodt rejected: cannot find your reverse hostname (192.168.1.45)
Posted: 14 Oct 2017 10:14
by budy
Well… as some kind of a last ressort, you could install dnsmasq on your eFa box and setup it's host file to contain your Zimbra's internal hostname and IP.
Then you'd insert an entry for your local dnsmasq service into the eFa's resolv.conf to have it check it's internal dns resolver before reaching out to any other.
Posted: 14 Oct 2017 11:59
You can try simply adding an entry to /etc/hosts.
Posted: 14 Oct 2017 12:31
by budy
I actually don't know, if this will work for reverse lookups, but it he will have to add this entry to /etc/hosts anyway.
Posted: 18 Sep 2018 05:59
by Richard Shaffer
You know data convertion from one platform to another seemed a drudgery for me until I found a program to import eml to outlook
read more. I thought I had a nasty and long task ahead of me, (3000 e-mails individually saved as .eml), but this simple tool did the job quite well! No complications, no fuss; Just open outlook, run the application and you’re done. Hope this utility will be helpful for you too!
Posted: 20 Sep 2018 10:40
Richard, if you are going to spam forums with a shill for your product, the very least you could do is be honest about it and tell everyone that you're recommending a commercial program.
