View Rejected messages
cburke
Post by cburke »
Hi, I just install eFa for the first time.
I'm wondering is there's a way to view the messages that are being rejected?
Re: View Rejected messages
Sure, take a look at /var/log/maillog :D
cburke wrote: 05 Oct 2017 18:50I'm wondering is there's a way to view the messages that are being rejected?
Rejected by postfix? or rejected by EFA?
If the message is rejected by postfix, when you will only have a record in /var/log/maillog. These rejections are almost certainly spam. 99.99999% at least.
If a message is rejected by EFA because of virus/spam, then depending on your efa settings, you may have a copy of the message in the quarantine. You'll be able to view these message through the EFA web interface.
wilbourne
Post by wilbourne »
for postfix rejected messages you can activate what kind of trouble you want report to the postmaster. Configuration on webmin > Postfix Mail Server > General Options > What trouble to report to the postmaster
TheGr8Wonder
Post by TheGr8Wonder »
There is an used variable in the EFA-Init that was meant to be used for postfix alerts. Up until 3.0.2.6, it was unused.
3.0.2.6 will have the ability to set postfix alert emails via the new menus
