Only 66mb in VAR !!
Posted: 05 Oct 2017 14:31
by bas60
How do I clear used up space in VAR
I changed the message retention from 60 > 30 and now to 7
I 've run mailwatch_db_clean.php twice and rebooted
still around 60mb
What am i doing wrong ???
Re: Only 66mb in VAR !!
Posted: 05 Oct 2017 14:42
by TheGr8Wonder
While logged into MailWatch, can you take a snippet of the "Free Disk Space" at the top-center of the page and post here? We want to see how your system was carved up.
Posted: 05 Oct 2017 15:13
by bas60
2 children
postfix 4 proc
1min 0.00
5min 0.03
15min : 0.02
Inbound :0
Outbound: 5
/ 4.66Gb [60%]
/boot 312.47Mb [65%]
/tmp 913.59 [94%
/var 61.47MB [0%]
Posted: 05 Oct 2017 16:19
What's your MailScanner quarantine retention in /etc/MailScanner/defaults ?
What happens when you run this?
/usr/local/bin/mailwatch/tools/Cron_jobs/mailwatch_quarantine_maint.php --clean
Posted: 05 Oct 2017 16:28
by bas60
only thing obvious is q_days=0
does that mean it not going to delete any !!??
Posted: 05 Oct 2017 16:30
No, actually, it should be 0. Just wanted to double check. eFa uses MailWatch instead to handle this....
MailWatch should be purging items based on QUARANTINE_DAYS_TO_KEEP. How far back can you see in /var/spool/MailScanner/quarantine folders?
Posted: 05 Oct 2017 16:39
by bas60
Ok
that seems have freed up 13Gb
I forgot I set q_days=7 before I run the command !
THANK YOU
Posted: 11 Jan 2019 09:51
by Justin
I'm having the same issue at the moment.
44mb left on /var
/var/lib/mysql/mailscanner has a file name maillog.ibd which is 23.6 GB
Is there a way to shrink this?
Posted: 11 Jan 2019 22:18
Justin wrote: 11 Jan 2019 09:51
44mb left on /var
Reduce this number here...
// Define how many days of emails to keep.
define('RECORD_DAYS_TO_KEEP', 60);
