3.0.2.5 - letsencrypt
Posted: 04 Oct 2017 15:32
by hiandras
I previously added a letsencrypt certificate to mailwatch.
Now, I updated to 3.0.2.5. which has this option built in.
I tried to disable and enable the certificate.
It works fine with mailwatch, but not with webmin.
Should the certificate work with webmin, as well?
Regards,
Andras
Re: 3.0.2.5 - letsencrypt
Posted: 04 Oct 2017 15:49
by TheGr8Wonder
Does your hostname or domainname have any uppercase characters in it?
Posted: 04 Oct 2017 17:21
by TheGr8Wonder
Actually, the restart for webmin was not included in the code. You can either reboot the appliance after enabling Let's Encrypt for the fixing of Webmin or run the below
The script will be updated to reflect the webmin service restart, as will the monthly renewal script, in an upcoming release.
Thanks for the report!!
Posted: 05 Oct 2017 06:34
by hiandras
(No upercase in hostname.)
The service restart fixed it.
Thank you!
Regards,
Andras
Posted: 05 Oct 2017 17:49
by jogomes
Hi to everyone,
How does this affects a manual installation of letsencrypt on the EFA?
Since I have it manually installed since several releases back.
Regards.
JG
Posted: 05 Oct 2017 17:54
by TheGr8Wonder
You have 2 options
1 - Continue using your self implemented solution, and do not enable the new built-in feature. No impact to your current installs.
2 - Undo your self implemented solution, and enable the new built-in feature.
Posted: 06 Oct 2017 03:09
and I'd recommend that you undo and let EFA handle it in the future - as long as you have a backup and are up to the task.
