SEO Expiration spam
hiandras
SEO Expiration spam
Post by hiandras »
I got a lot of spams for my registered domains, about seo expiration.
So, I made a rule in /etc/mail/spamassassin/local.cf:
header BAD_WORD_SEO Subject =~ /(SEO|Expiration)/i
score BAD_WORD_SEO 4.0
Then you need to run "sa-compile" and "/etc/init.d/mailscanner restart".
Now, if subject contains SEO and Expiration it will get a score of 4.0.
(Similar works for other keywords as well.)
Regards,
Andras
budy
Re: SEO Expiration spam
Post by budy »
Ahh great - just what I needed… ;)
Thanks,
budy
I've never had to do an sa-compile to add new rules into my local.cf, so (and someone please correct me if I am wrong) I don't think it is necessary.
hiandras
Post by hiandras »
You are right. sa-compile is not required.
I also modified the rule:
header BAD_WORD_SEO Subject =~ /(Expiration SEO)/i
The original one filtered out everything with either expiration or SEO in it.
The new one just filters out if "Expiration SEO" is in the subject.
Regards,
Andras
There is a way to specify (A and B) rather then (A or B) or (A B) which may be more useful.
Have a look through the existing rule sets and you should be able to find the syntax.
