KAM.cf exception
hiandras
KAM.cf exception
Post by hiandras »
In the /etc/mail/spamassassin/KAM.cf file, there is a rule:
#NetWeaver
header KAM_NW X-Mailer =~ /SAP NetWeaver/i
score KAM_NW 3.0
describe KAM_NW Spam Indicator
Since SAP NetWeaver mails are sent from SAP, and we receive this kind of mails, I want to disable this rule.
I found in another thread, that I should add an exception to /etc/mail/spamassassin/local.cf file,
creating a rule to KAM_NW and set the score to 0.
How to create a rule like this?
I tried adding
score KAM_NW 0 at the end of the file, but it does not mike any effect.
Regards,
Andras
Re: KAM.cf exception
/etc/mail/spamassassin/local.cf?
That's where I've placed my KAM_ adjustments and it works for me. Maybe there is another problem in your file?
hiandras
Post by hiandras »
Can you post me an example?
Do you need to restart MailScanner and/or Spamassassin after editing local.cf?
Regards, Andras
hiandras
Post by hiandras »
I got it working.
You just have to put the following (just an example):
# KAM.cf exceptions
score KAM_NW 0.01
at the end of local.cf and wait.
I tried to restart Mailscanner/spamassassin, but it did not help.
Regards, Andras
