Cloud Platforms and Providers
What are some cloud platforms/providers that you would like to see eFa as a template option for?
Re: Cloud Platforms and Providers
Can you expand a bit upon your question? are you referring to "scripts" when you say templates to i.e. install on Digitalocean?
I'm a big fan of Proxmox and Proxmox can use appliances from here: https://www.turnkeylinux.org/ and since Proxmox can now use LXC - would that be possible? Although, there are limitations on linux containers which true KVMs don't have but still, publishing and maintaining containers on turnkeylinux would tremendously boost EFA's usage as they support a variety of platforms like vmware, openstack, docker, XEN, LXC
I hope I didn't completely missunderstand your question though
