Double spam report EFA 3.0.2.4
Posted: 14 Sep 2017 18:17
by largo
I have one user that get 2 spam report ewery day.
I havent fond a way fix that.
Any suggestions?
/Largo
Re: Double spam report EFA 3.0.2.4
Posted: 15 Sep 2017 13:41
by xenos1983
Is it possible that you have set a filter for that user with the same mail/domain as his username?
In this case you will receive 2 reports.
Posted: 15 Sep 2017 18:32
by largo
Thanks for your answer but thats not the situation.
/Largo
Posted: 20 Sep 2017 17:41
by budy
Well… I had this issue as well. It turned out, that I had entered my user manually into the user database for testing that spam report feature. That worked very well and I went forth to setup the AD binding. After that had been successfully been done and i verified my AD account, I received a double report each following night.
I chose to remove my user account from the user database manually and as if since, I am only receiving one report per day. Maybe worth checking…
Cheers,
budy
