Special thanks to TheGr8Wonder for his generous coding contributions!
We would also like to thank everyone for their support and contributions to this project.
The following issues have been fixed (hopefully) in 3.0.2.4:
Issue #372 Bug - viewmail.php ampersand bug
Issue #373 Bug - SA Rule Hits Report Issues
Issue #375 Bug - Postfix Relay Info Missing
Issue #376 Bug - Secure loopback access to mysql
Issue #378 Enhancement - Disable mod_security
Issue #379 Enhancement - Update Pyzor to latest version
Issue #380 Enhancement - Update DCC to latest version
Updated Webmin versions
Update MailWatch from 1.2.3-dev to 1.2.7-dev
Update MailScanner to 5.0.6-4.2 (eFa fork)
Update SGWI to 1.1.9-2
###################### How To Update ##################################
3) If the update fails for any reason, collect relevant logs or screen
outputs/screenshots and revert to your snapshot
Launch EFA-Configure from console or secure shell
(sudo /usr/local/sbin/EFA-Configure)
Choose option 14) Update Now
continue the update process to 3.0.2.4.
if present.
