After a fesh install of the latest efa version (eFa 3.0.2.3 VMware OVF), I noticed the massive number of files in /var/dcc/log.
In the previous versions there was a daily cronjob in:
[root@efa cron.daily]# ls -l
total 56
lrwxrwxrwx. 1 root root 26 May 25 2015 cron-dccd -> /var/dcc/libexec/cron-dccd
In the latest version, this job is moved to a monthly cron job:
[root@efa cron.monthly]# ls -l
total 8
lrwxrwxrwx. 1 root root 26 May 24 12:15 cron-dccd -> /var/dcc/libexec/cron-dccd
-rwx------. 1 root root 1151 May 24 12:16 EFA-Monthly-cron
-rwxr-xr-x. 1 root root 111 Nov 23 2013 readahead-monthly.cron
Should I move this job to the daily cron or is there a specific reason to do this on a monthly basis?
Housekeeping DCC 3.0.2.3
Re: Housekeeping DCC 3.0.2.3
I'd imagine it should be okay to do that.
