Maximum number of domains
hiandras
Post by hiandras »
Sorry for the obvious question, but is there a limit of number of domains eFa can handle?
I am plannig to use it for around 400-500 domains.
(I saw in the forum, that there was problems editing the transport settings with more than a 100 domains.
https://github.com/E-F-A/v3/issues/222 , which has been fixed.)
Regards,
hiandras
darky83
Site Admin
Re: Maximum number of domains
Post by darky83 »
There is no limitation in the software, only in resource/throughput based on the performance of the box you run eFa.
hiandras
Post by hiandras »
Thank you for the information.
Regards, hiandras
