BliXem
Post
by BliXem »
imageupload
Why can't I see the description? See this pic:
Is there something wrong with my setup?
Also, I see bayes_99, it's always -1.90...
Post
by henk »
Try: Tools AND Links-> Update SpamAssassin Rule Descriptions
In your example there is Bayes_00, giving the correct value.
In Tools AND LINKS there is also the Spamassassin Lint test. Run this and check the results
BliXem
Post
by BliXem »
Yes, that fixed it!
everything was green on the spamassassin lint test.
