Hello community,
is there any way how to clean/delete the audit log from time to time?
Thank you in advance!
Alexander
Clear Audit Log
Re: Clear Audit Log
Hello Alexandeerbrix,
There is housekeeping on the audit log, so why clear it?
You can control the days to keep for your audit log in
/var/www/html/mailscanner/conf.phpCode: Select all
// Define how many days to audit logs to keep.
define('AUDIT_DAYS_TO_KEEP', 60);“We are stuck with technology when what we really want is just stuff that works.” -Douglas Adams
alexanderbrix
Re: Clear Audit Log
thank you! I've changed the value
Alleyviper
Re: Clear Audit Log
Hi there,
You can go to https://<server>:10000
Login to webmin with your root account
Search mysqlserver
Go mailscanner Database and select audit_log
Select view data and you can delete what you want
Search mysqlserver
alexanderbrix
Re: Clear Audit Log
I just logged in to my webmin and went to Server - MySQL Database Server. But after that I need to login and my root/pw does not work. I can't log in to the MySQL...
Alleyviper
Re: Clear Audit Log
Hi there,
Weird, can you show a printscreen ?
