spamassassin daemon
spamassassin daemon
Question:
I just noticed that by default, the spamassassin daemon is set to "off" for all the runlevels.
Is this correct? Is the spamassassin daemon not supposed to be running, but is invoked message by message basis?
Can someone run a "chkconfig --list spamassassin" command and tell me what results they get?
I've very curious now.
Re: spamassassin daemon
[root@spammy log]# chkconfig --list spamassassin
spamassassin    0:off   1:off   2:off   3:off   4:off   5:off   6:off
I'm using the latest E.F.A. version
huh.
I guess that's the way the system is set to run.
Thanks for the confirmation.
MailScanner calls SA directly, so this is correct.
