let ip bypass RBL
Posted: 24 Jul 2017 23:10
i'm new, hi... Thans for the awesome project.. I've been experimenting with the efa and had some tweaks to do like after setting my zarafa mailserver to let it relay via the external hosted efa to add iptables rules. Also to deliver mail i had to adjust the transport files to deliver on alternate ports ( the bash menu does not accept a port ) . it works great.. But... The problem is when i sent e-mail trough relay it rejects it based on a RBL policy ( i have a dynamic ip ) . How can i set efa to not check my ip on a RBL ? I tried whitelist in the mailwatch interface but it does nog work ( tried restarting mailscanner and rebooted. ) . Alternate i tried manually adding my ip as a /32 in the postfix main.cf mynetworks but nogo..
Any thoughts / usggestions ?
thanks a zillion..
greets
Mayk
thanks a zillion..
greets
Mayk
