Google Alerts getting Mangled
mmcnally
Post by mmcnally »
Hi!
Having a problem with Google Alerts getting the formatting messed up when going through the gateway. I'm on 3.0.2.3, but it's been like this for several versions.
I attached a screencap from Mailwatch, where the bottom pane shows the problem. Also one email without the EFA gateway and one with the gateway.
When I removed the gateway and went direct to the mail server, the email formatting was normal.
I turned off HTML signitures and several other options in mailwatch.conf, even renamed the inline sig files.
Any ideas?
Mark
No EFA Gateway
No EFA Gateway
No EFA Gateway.PNG (36.29 KiB) Viewed 6959 times
With Gateway
With Gateway
EFA Gateway.PNG (61.75 KiB) Viewed 6959 times
Mailwatch View
Mailwatch View
Re: Google Alerts getting Mangled
Look in /etc/MailScanner/MailScanner.conf:
# Do you want to allow <IFrame> tags in email messages? This is not a good
# idea as it allows various Microsoft Outlook security vulnerabilities to
# remain unprotected, but if you have a load of mailing lists sending them,
# then you will want to allow them to keep your users happy.
# Value: yes     => Allow these tags to be in the message
#        no      => Ban messages containing these tags
#        disarm  => Allow these tags, but stop these tags from working
# This can also be the filename of a ruleset, so you can allow them from
# known mailing lists but ban them from everywhere else.
Allow IFrame Tags = disarm
# Do you want to allow <Form> tags in email messages? This is a bad idea
# as these are used as scams to pursuade people to part with credit card
# information and other personal data.
#                   Note: Disarming can be defeated, it is not 100% safe!
Allow Form Tags = disarm
# Do you want to allow <Script> tags in email messages? This is a bad idea
# as these are used to exploit vulnerabilities in email applications and
# web browsers.
Allow Script Tags = disarm
# Do you want to allow <Img> tags with very small images in email messages?
# This is a bad idea as these are used as 'web bugs' to find out if a message
# has been read. It is not dangerous, it is just used to make you give away
# information.
# Note: You cannot block messages containing web bugs as their detection
#       is very vulnerable to false alarms.
Allow WebBugs = disarm
# Do you want to allow <Object Codebase=...> or <Object Data=...> tags
# in email messages?
# This is a bad idea as it leaves you unprotected against various
# Microsoft-specific security vulnerabilities. But if your users demand
# it, you can do it.
# This can also be the filename of a ruleset, so you can allow them just
# for specific users or domains.
Allow Object Codebase Tags = disarm
And /var/www/html/mailscanner/conf.php:
// List of allowed tags - set as blank to strip everything
define('ALLOWED_TAGS', '<a><br><b><body><div><font><h1><h2><h3><h4><head><html><i><li><ol><p><small><span><strong><table><title><tr><td><th><u><ul>');
mmcnally
Post by mmcnally »
Thanks Shawn!
Changing the first three options from disarm to yes got it working properly!
Thanks,
Mark
Just keep in mind that disabling these lowers your security to an extent. Just be aware.
mmcnally
Post by mmcnally »
Hard to justify to users why Google Alerts get messed up for "security reasons"
Just a part of life!
Mark
unfortunately, html mail serves as a vector for malware, and less than aware users are more likely to do something stupid.
however, if the bosses fully understand the risks, then go for it.
oh, is it possible to whitelist the sending address so it avoids the checks all together?
hmmm... worth investigating.
