In my setup I have a local Mail Spool that stores emails if my Exchange server is down.
When the Exchange comes back up, the mailspool delivers any mails it has received to my Exchange on Port 25.
This works fine
However when I introduce eFa to the setup so MailSpool -> eFa -> Exchange it does not work as eFa cannot perform a reverse lookup on my Mail spool. I have worked around this by pointing the spool directly to the exchange but this is obviously not ideal.
Is there anything I can do to make eFa accept the mails from the MailSpool even though it hasn't got a reverse lookup?
If it helps my addresses are:
MailSpool - 10.0.0.4
eFa - 10.0.0.1
Exchange - 10.0.0.8
Thanks for any help.
PJ
Mail Relay
Re: Mail Relay
Can you add an entry to /etc/hosts?
Re: Mail Relay
Thanks for the quick reply.
An entry for what?
The Spooler on eFa or something else?
Re: Mail Relay
eFa
Re: Mail Relay
Will try tomorrow and feedback
Re: Mail Relay
Got impatient and changed it from bed. Works perfectly. Thanks for your help
PJ
