Project HoneyPot
Project HoneyPot
Post by nicola.piazzi »
It can be useful to weite a plugin that query for this database using the given key
https://www.projecthoneypot.org/httpbl_api.php
efa-user
Re: Project HoneyPot
Post by efa-user »
Would this be for the web interface, to prevent potentially malicious scripts from being able to attempt to log in?
Or are you suggesting that hosts which appear to be crawling websites are probably also going to be sending spam, and thus this data should be fed into SA?
wilbourne
Post by wilbourne »
Put a reverse proxy in front of your web application
like this : https://www.vultureproject.org/ and this is a waf server
efa-user, no it's a tool used to recognize the IP of spam harvesters, so mail coming from these addresses are more likely to be spam.
It's yet another tool to add weighting to help determine if mail is junk or not.
efa-user
Post by efa-user »
so basically "that hosts which appear to be crawling websites are probably also going to be sending spam, and thus this data should be fed into SA" ?
ovizii
Post by ovizii »
not sure that projecthoneypot fits in here, apparently is does report 4 categories of IPs. Email Spammers specifically are not in there.
Value Meaning
0 Search Engine
1 Suspicious
2 Harvester
4 Comment Spammer
