I run an Mdaemon (altn.com) Mail Server and in need of a low cost anti-spam solution.
Seems that all open source requires extra effort and hand holding. Tried ScrollOutF1 and automatic ISO installation failed.
Tried to install the EFA OVF file on VMWare 5.0 and script fails.
I will scan and post to look for solutions.
Just frustrated in the general lack of QA testing and very thin instructions along with zero in the way of troubleshooting.
I am keeping and open mind and will continue to try to get anyone of these projects up and running.
Hello from NY
Re: Hello from NY
I'm not sure what you mean when you say the script fails, can you post the error message you are receiving?Tried to install the EFA OVF file on VMWare 5.0 and script fails.
Re: Hello from NY
There are some random XML errors when you run the original OVF via the VMWare Client. However, when I clicked "continue" it installed correctly.
