Access denied to clamd after expanding TNEF archive
ovizii
Post by ovizii » 19 May 2017 14:16
Saw this in my logs:
May 19 12:06:57 efa MailScanner[29760]: Expanding TNEF archive at /var/spool/MailScanner/incoming/29760/8B26610005E.AC361/winmail.dat
May 19 12:06:57 efa MailScanner[29760]: Clamd::ERROR:: image001.png/Access denied. ERROR :: ./8B26610005E.AC361/tnef4n4EdZ
May 19 12:06:57 efa MailScanner[29760]: Clamd::ERROR:: ErweiterteAnsichtTimeline.pdf/Access denied. ERROR :: ./8B26610005E.AC361/tnef4n4EdZ
May 19 12:06:57 efa MailScanner[29760]: Clamd::ERROR:: UserGuide_short.pdf/Access denied. ERROR :: ./8B26610005E.AC361/tnef4n4EdZ
gogling only found one relevant result pointing to a similar but unresolved issue: http://lists.mailscanner.info/pipermail ... 03959.html
any ideas? btw. there is no "problem" here, EFA worked, analyzed and correctly let this message through without any hiccups.
