My update log from 3.0.2.1 to 3.0.2.2
Posted: 15 May 2017 07:35
by DaN
[EFA] : 14
[EFA] Good you are root
[EFA] Starting update to EFA-3.0.2.2
Setting up Update Process
Determining fastest mirrors
 * EFA: dl.efa-project.org
 * base: mirror.daniel-jost.net
 * epel: ftp.nluug.nl
 * extras: mirror.23media.de
 * mariadb: ftp.nluug.nl
 * updates: mirror.23media.de
No Pcks marked for Update
--2017-05-14 06:24:15--  http://dl.efa-project.org/update/EFA-Update-3.0.2.1-3.0.2.2.tar.gz
Resolving dl.efa-project.org... 188.165.135.228, 2001:41d0:2:524b::228
Connecting to dl.efa-project.org|188.165.135.228|:80... connected.
Length: 5050312 (4.8M) [application/octet-stream]
Saving to: “/tmp/EFA-Staging/EFA-Update-3.0.2.1-3.0.2.2.tar.gz”
     0K .......... .......... .......... .......... ..........  1% 2.02M 2s
  4900K .......... .......... .......... .       100% 9.67M=0.4s
2017-05-14 06:24:16 (12.7 MB/s)-“/tmp/EFA-Staging/EFA-Update-3.0.2.1-3.0.2.2.tar.gz” saved [5050312/5050312]
--2017-05-14 06:24:16--  http://dl.efa-project.org/update/EFA-Update-3.0.2.1-3.0.2.2.tar.gz.md5
Length: 68 [application/octet-stream]
Saving to: “/tmp/EFA-Staging/EFA-Update-3.0.2.1-3.0.2.2.tar.gz.md5”
     0K             100% 10.9M=0s
2017-05-14 06:24:16 (10.9 MB/s)-“/tmp/EFA-Staging/EFA-Update-3.0.2.1-3.0.2.2.tar.gz.md5” saved [68/68]
EFA-Version-Upgrade
Files/
Files/MailWatch-develop-GIT-289c9f2.zip
Scripts/
Scripts/EFA-Configure
Scripts/lib-EFA-Configure/
Scripts/lib-EFA-Configure/func_ipsettings
Scripts/lib-EFA-Configure/func_tunables_children
Scripts/lib-EFA-Configure/func_asknonspam
Scripts/lib-EFA-Configure/func_askmalwarepatrol
Scripts/lib-EFA-Configure/func_peruser
Scripts/lib-EFA-Configure/func_sethostname
Scripts/lib-EFA-Configure/func_askmaxsizemailwatch
Scripts/lib-EFA-Configure/libraries-filelist.txt
Scripts/lib-EFA-Configure/func_autoupdates
Scripts/lib-EFA-Configure/func_systemrestore
Scripts/lib-EFA-Configure/func_virussettings
Scripts/lib-EFA-Configure/func_tunables_procdb
Scripts/lib-EFA-Configure/func_askspam
Scripts/lib-EFA-Configure/func_askrecursion
Scripts/lib-EFA-Configure/func_mailwatchsettings
Scripts/lib-EFA-Configure/func_spamsettings
Scripts/lib-EFA-Configure/func_mailsettings
Scripts/lib-EFA-Configure/func_asksigrules
Scripts/lib-EFA-Configure/func_maintenance
Scripts/lib-EFA-Configure/func_trustednetworks
Scripts/lib-EFA-Configure/func_recovermysql
Scripts/lib-EFA-Configure/func_askhighspammailwatch
Scripts/lib-EFA-Configure/func_retention
Scripts/lib-EFA-Configure/func_apachesettings
Scripts/lib-EFA-Configure/func_greylisting
Scripts/lib-EFA-Configure/func_resetadmin
Scripts/lib-EFA-Configure/func_getipsettings
Scripts/lib-EFA-Configure/func_ipv6settings
Scripts/lib-EFA-Configure/func_askcleandeliver
Scripts/lib-EFA-Configure/func_setipsettings
Starting update to E.F.A. 3.0.2.2
Beginning System Backup at 05152017 085416
Backup Completed at 05152017 085424
Cleaning repos: EFA base epel extras mariadb updates
Cleaning up Everything
 * EFA: dl2.efa-project.org
 * base: centosmirror.netcup.net
Resolving Dependencies
There are unfinished transactions remaining. You might consider running yum-complete-transaction first to finish them.
> Running transaction check
->Pck MariaDB-client.x86_64 0:10.1.22-1.el6 willbeupd
->Pck MariaDB-client.x86_64 0:10.1.23-1.el6 will be an update
->Pck MariaDB-common.x86_64 0:5.5.54-1.el6 willbeupd
->Pck MariaDB-common.x86_64 0:10.1.22-1.el6 willbeupd
->Pck MariaDB-common.x86_64 0:10.1.23-1.el6 will be an update
->Pck MariaDB-compat.x86_64 0:5.5.54-1.el6 willbeupd
->Pck MariaDB-compat.x86_64 0:10.1.22-1.el6 willbeupd
->Pck MariaDB-compat.x86_64 0:10.1.23-1.el6 will be an update
->Pck MariaDB-server.x86_64 0:10.1.22-1.el6 willbeupd
->Pck MariaDB-server.x86_64 0:10.1.23-1.el6 will be an update
->Pck bind-libs.x86_64 32:9.8.2-0.47.rc1.el6_8.4 willbeupd
->Pck bind-libs.x86_64 32:9.8.2-0.62.rc1.el6 willbeupd
->Pck bind-libs.x86_64 32:9.8.2-0.62.rc1.el6_9.2 will be an update
->Pck bind-utils.x86_64 32:9.8.2-0.47.rc1.el6_8.4 willbeupd
->Pck bind-utils.x86_64 32:9.8.2-0.62.rc1.el6 willbeupd
->Pck bind-utils.x86_64 32:9.8.2-0.62.rc1.el6_9.2 will be an update
->Pck galera.x86_64 0:25.3.19-1.rhel6.el6 willbeupd
->Pck galera.x86_64 0:25.3.20-1.rhel6.el6 will be an update
->Pck munin.noarch 0:2.0.30-5.el6 willbeupd
->Pck munin.noarch 0:2.0.33-1.el6 will be an update
->Pck munin-common.noarch 0:2.0.30-5.el6 willbeupd
->Pck munin-common.noarch 0:2.0.33-1.el6 will be an update
->Pck munin-node.noarch 0:2.0.30-5.el6 willbeupd
->Pck munin-node.noarch 0:2.0.33-1.el6 will be an update
->Pck nss.x86_64 0:3.21.3-2.el6_8 willbeupd
->Pck nss.x86_64 0:3.28.3-3.el6_9 willbeupd
->Pck nss.x86_64 0:3.28.4-1.el6_9 will be an update
->Pck nss-sysinit.x86_64 0:3.21.3-2.el6_8 willbeupd
->Pck nss-sysinit.x86_64 0:3.28.3-3.el6_9 willbeupd
->Pck nss-sysinit.x86_64 0:3.28.4-1.el6_9 will be an update
->Pck nss-tools.x86_64 0:3.21.3-2.el6_8 willbeupd
->Pck nss-tools.x86_64 0:3.28.3-3.el6_9 willbeupd
->Pck nss-tools.x86_64 0:3.28.4-1.el6_9 will be an update
->Pck nss-util.x86_64 0:3.21.3-1.el6_8 willbeupd
->Pck nss-util.x86_64 0:3.28.3-1.el6_9 willbeupd
->Pck nss-util.x86_64 0:3.28.4-1.el6_9 will be an update
> Finished Dependency Resolution
Dependencies Resolved
 Pck            Arch       Version           Repository   Size
Updating:
 MariaDB-client     x86_64     10.1.23-1.el6     mariadb      40 M
 MariaDB-common     x86_64     10.1.23-1.el6     mariadb     118 k
 MariaDB-compat     x86_64     10.1.23-1.el6     mariadb     2.7 M
 MariaDB-server     x86_64     10.1.23-1.el6     mariadb     105 M
 bind-libs          x86_64     32:9.8.2-0.62.rc1.el6_9.2      updates     891 k
 bind-utils         x86_64     32:9.8.2-0.62.rc1.el6_9.2      updates     189 k
 galera             x86_64     25.3.20-1.rhel6.el6            mariadb     8.8 M
 munin              noarch     2.0.33-1.el6      epel        201 k
 munin-common       noarch     2.0.33-1.el6      epel         94 k
 munin-node         noarch     2.0.33-1.el6      epel        406 k
 nss    x86_64     3.28.4-1.el6_9    updates     880 k
 nss-sysinit        x86_64     3.28.4-1.el6_9    updates      51 k
 nss-tools          x86_64     3.28.4-1.el6_9    updates     446 k
 nss-util           x86_64     3.28.4-1.el6_9    updates      68 k
Transaction Summary
Upgrade      14 Pck(s)
Total download size: 160 M
Downloading Pcks:
Total            7.7 MB/s | 160 MB     00:20
Running rpm_check_debug
Running Transaction Test
Transaction Test Succeeded
Running Transaction
Updatg: nss-util-3.28.4-1.el6_9.x86_64    1/36
Updatg: munin-common-2.0.33-1.el6.noarch     2/36
Updatg: munin-node-2.0.33-1.el6.noarch    3/36
Updatg: nss-sysinit-3.28.4-1.el6_9.x86_64    4/36
Updatg: nss-3.28.4-1.el6_9.x86_64    5/36
Updatg: MariaDB-common-10.1.23-1.el6.x86_64    6/36
Updatg: MariaDB-compat-10.1.23-1.el6.x86_64    7/36
Updatg: MariaDB-client-10.1.23-1.el6.x86_64    8/36
Updatg: 32:bind-libs-9.8.2-0.62.rc1.el6_9.2.x86_64     9/36
Updatg: galera-25.3.20-1.rhel6.el6.x86_64     10/36
Updatg: MariaDB-server-10.1.23-1.el6.x86_64           11/36
Updatg: 32:bind-utils-9.8.2-0.62.rc1.el6_9.2.x86_64    12/36
Updatg: nss-tools-3.28.4-1.el6_9.x86_64     13/36
Updatg: munin-2.0.33-1.el6.noarch        14/36
Clean: munin-2.0.30-5.el6.noarch        15/36
Clean: nss-tools.x86_64            16/36
Clean: MariaDB-server-10.1.22-1.el6.x86_64           17/36
Shutting down MySQL... SUCCESS!
Starting MySQL.170515 06:27:32 mysqld_safe Logging to '/var/lib/mysql/SERVERNAME.DOMAIN.local.err'.
170515 06:27:32 mysqld_safe Starting mysqld daemon with databases from /var/lib/mysql
. SUCCESS!
Clean: nss-tools.x86_64            18/36
Clean: bind-utils.x86_64           19/36
Clean: nss-sysinit.x86_64          20/36
Clean: nss.x86_64       21/36
Clean: nss.x86_64       22/36
Clean: nss-sysinit.x86_64          23/36
Clean: MariaDB-compat.x86_64       24/36
Clean: munin-node-2.0.30-5.el6.noarch      25/36
Clean: MariaDB-common.x86_64       26/36
Clean: bind-libs.x86_64            27/36
Clean: MariaDB-client-10.1.22-1.el6.x86_64           28/36
Clean: MariaDB-common.x86_64       29/36
Clean: MariaDB-compat.x86_64       30/36
Clean: bind-utils.x86_64           31/36
Clean: munin-common-2.0.30-5.el6.noarch    32/36
Clean: bind-libs.x86_64            33/36
Clean: nss-util.x86_64  34/36
Clean: nss-util.x86_64  35/36
Clean: galera-25.3.19-1.rhel6.el6.x86_64     36/36
Verify:munin-common-2.0.33-1.el6.noarch     1/36
Verify:MariaDB-compat-10.1.23-1.el6.x86_64    2/36
Verify:MariaDB-common-10.1.23-1.el6.x86_64    3/36
Verify:munin-2.0.33-1.el6.noarch    4/36
Verify:nss-util-3.28.4-1.el6_9.x86_64    5/36
Verify:nss-sysinit-3.28.4-1.el6_9.x86_64    6/36
Verify:munin-node-2.0.33-1.el6.noarch    7/36
Verify:galera-25.3.20-1.rhel6.el6.x86_64    8/36
Verify:MariaDB-client-10.1.23-1.el6.x86_64    9/36
Verify:32:bind-libs-9.8.2-0.62.rc1.el6_9.2.x86_64    10/36
Verify:nss-tools-3.28.4-1.el6_9.x86_64     11/36
Verify:nss-3.28.4-1.el6_9.x86_64        12/36
Verify:32:bind-utils-9.8.2-0.62.rc1.el6_9.2.x86_64    13/36
Verify:MariaDB-server-10.1.23-1.el6.x86_64           14/36
Verify:MariaDB-compat-10.1.22-1.el6.x86_64           15/36
Verify:MariaDB-server-10.1.22-1.el6.x86_64           16/36
Verify:MariaDB-common-10.1.22-1.el6.x86_64           17/36
Verify:32:bind-libs-9.8.2-0.47.rc1.el6_8.4.x86_64    18/36
Verify:nss-util-3.21.3-1.el6_8.x86_64      19/36
Verify:munin-common-2.0.30-5.el6.noarch    20/36
Verify:32:bind-utils-9.8.2-0.62.rc1.el6.x86_64       21/36
Verify:nss-tools-3.28.3-3.el6_9.x86_64     22/36
Verify:munin-2.0.30-5.el6.noarch        23/36
Verify:nss-3.21.3-2.el6_8.x86_64        24/36
Verify:32:bind-libs-9.8.2-0.62.rc1.el6.x86_64        25/36
Verify:nss-util-3.28.3-1.el6_9.x86_64      26/36
Verify:32:bind-utils-9.8.2-0.47.rc1.el6_8.4.x86_64    27/36
Verify:MariaDB-common-5.5.54-1.el6.x86_64    28/36
Verify:MariaDB-compat-5.5.54-1.el6.x86_64    29/36
Verify:nss-sysinit-3.28.3-3.el6_9.x86_64     30/36
Verify:nss-sysinit-3.21.3-2.el6_8.x86_64     31/36
Verify:MariaDB-client-10.1.22-1.el6.x86_64           32/36
Verify:nss-tools-3.21.3-2.el6_8.x86_64     33/36
Verify:galera-25.3.19-1.rhel6.el6.x86_64     34/36
Verify:munin-node-2.0.30-5.el6.noarch      35/36
Verify:nss-3.28.3-3.el6_9.x86_64        36/36
Updated:
Complete!
Starting installation of new mailwatch version
Stopping httpd:  [  OK  ]
MailScanner stopped
Archive:  /tmp/EFA-Staging/Files/MailWatch-develop-GIT-289c9f2.zip
creat: /u/s/E/MW-dev/.github/
inflg:/u/s/E/MW-dev/.github/ISSUE_TEMPLATE.md
inflg:/u/s/E/MW-dev/.gitignore
inflg:/u/s/E/MW-dev/.styleci.yml
inflg:/u/s/E/MW-dev/CHANGELOG.md
inflg:/u/s/E/MW-dev/CONTRIBUTING.md
inflg:/u/s/E/MW-dev/create.sql
inflg:/u/s/E/MW-dev/fix_quarantine_permissions
inflg:/u/s/E/MW-dev/INSTALL
inflg:/u/s/E/MW-dev/LICENSE.md
creat: /u/s/E/MW-dev/ms/
inflg:/u/s/E/MW-dev/ms/auto-release.php
inflg:/u/s/E/MW-dev/ms/bayes_info.php
inflg:/u/s/E/MW-dev/ms/checklogin.php
inflg:/u/s/E/MW-dev/ms/clamav.awk
inflg:/u/s/E/MW-dev/ms/clamav_status.php
inflg:/u/s/E/MW-dev/ms/conf.php.example
inflg:/u/s/E/MW-dev/ms/database.php
inflg:/u/s/E/MW-dev/ms/detail.php
inflg:/u/s/E/MW-dev/ms/do_message_ops.php
inflg:/u/s/E/MW-dev/ms/docs.php
creat: /u/s/E/MW-dev/ms/docs/
inflg:/u/s/E/MW-dev/ms/docs/howto_configure_outlook.html
inflg:/u/s/E/MW-dev/ms/docs/howto_train_spamassassin.html
 extracting: /u/s/E/MW-dev/ms/docs/index.html
inflg:/u/s/E/MW-dev/ms/favicon.ico
inflg:/u/s/E/MW-dev/ms/filter.inc.php
inflg:/u/s/E/MW-dev/ms/f-prot.awk
inflg:/u/s/E/MW-dev/ms/f-prot_status.php
inflg:/u/s/E/MW-dev/ms/f-secure.awk
inflg:/u/s/E/MW-dev/ms/f-secure_status.php
inflg:/u/s/E/MW-dev/ms/functions.php
inflg:/u/s/E/MW-dev/ms/geoip_update.php
creat: /u/s/E/MW-dev/ms/images/
creat: /u/s/E/MW-dev/ms/images/cache/
inflg:/u/s/E/MW-dev/ms/images/cache/.gitignore
 extracting: /u/s/E/MW-dev/ms/images/favicon.png
 extracting: /u/s/E/MW-dev/ms/images/index.html
inflg:/u/s/E/MW-dev/ms/images/info-circle.png
inflg:/u/s/E/MW-dev/ms/images/info-circle-hover.png
inflg:/u/s/E/MW-dev/ms/images/mailwatch-logo.png
inflg:/u/s/E/MW-dev/ms/index.php
creat: /u/s/E/MW-dev/ms/languages/
inflg:/u/s/E/MW-dev/ms/languages/de.php
inflg:/u/s/E/MW-dev/ms/languages/en.php
inflg:/u/s/E/MW-dev/ms/languages/fr.php
 extracting: /u/s/E/MW-dev/ms/languages/index.html
inflg:/u/s/E/MW-dev/ms/languages/it.php
inflg:/u/s/E/MW-dev/ms/languages/nl.php
inflg:/u/s/E/MW-dev/ms/languages/pt_br.php
creat: /u/s/E/MW-dev/ms/lib/
inflg:/u/s/E/MW-dev/ms/lib/geoip.inc
inflg:/u/s/E/MW-dev/ms/lib/hash_equals.php
creat: /u/s/E/MW-dev/ms/lib/htmlpurifier/
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/HTMLPurifier.standalone.php
creat: /u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/
creat: /u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/
creat: /u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/
creat: /u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/Builder/
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/Builder/ConfigSchema.php
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/Builder/Xml.php
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/Exception.php
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/Interchange.php
creat: /u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/Interchange/
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/Interchange/Directive.php
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/Interchange/Id.php
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/InterchangeBuilder.php
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema.ser
creat: /u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Attr.AllowedClasses.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Attr.AllowedFrameTargets.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Attr.AllowedRel.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Attr.AllowedRev.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Attr.ClassUseCDATA.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Attr.DefaultImageAlt.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Attr.DefaultInvalidImage.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Attr.DefaultInvalidImageAlt.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Attr.DefaultTextDir.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Attr.EnableID.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Attr.ForbiddenClasses.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Attr.ID.HTML5.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Attr.IDBlacklist.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Attr.IDBlacklistRegexp.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Attr.IDPrefix.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Attr.IDPrefixLocal.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/AutoFormat.AutoParagraph.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/AutoFormat.Custom.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/AutoFormat.DisplayLinkURI.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/AutoFormat.Linkify.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/AutoFormat.PurifierLinkify.DocURL.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/AutoFormat.PurifierLinkify.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/AutoFormat.RemoveEmpty.Predicate.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/AutoFormat.RemoveEmpty.RemoveNbsp.Exceptions.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/AutoFormat.RemoveEmpty.RemoveNbsp.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/AutoFormat.RemoveEmpty.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/AutoFormat.RemoveSpansWithoutAttributes.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Cache.DefinitionImpl.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Cache.SerializerPath.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Cache.SerializerPermissions.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Core.AggressivelyFixLt.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Core.AllowHostnameUnderscore.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Core.CollectErrors.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Core.ColorKeywords.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Core.ConvertDocumentToFragment.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Core.DirectLexLineNumberSyncInterval.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Core.DisableExcludes.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Core.EnableIDNA.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Core.Encoding.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Core.EscapeInvalidChildren.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Core.EscapeInvalidTags.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Core.EscapeNonASCIICharacters.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Core.HiddenElements.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Core.Language.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Core.LexerImpl.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Core.MaintainLineNumbers.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Core.NormalizeNewlines.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Core.RemoveInvalidImg.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Core.RemoveProcessingInstructions.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Core.RemoveScriptContents.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/CSS.AllowDuplicates.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/CSS.AllowedFonts.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/CSS.AllowedProperties.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/CSS.AllowImportant.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/CSS.AllowTricky.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/CSS.DefinitionRev.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/CSS.ForbiddenProperties.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/CSS.MaxImgLength.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/CSS.Proprietary.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/CSS.Trusted.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Filter.Custom.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Filter.ExtractStyleBlocks.Escaping.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Filter.ExtractStyleBlocks.Scope.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Filter.ExtractStyleBlocks.TidyImpl.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Filter.ExtractStyleBlocks.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Filter.YouTube.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/HTML.Allowed.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/HTML.AllowedAttributes.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/HTML.AllowedComments.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/HTML.AllowedCommentsRegexp.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/HTML.AllowedElements.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/HTML.AllowedModules.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/HTML.Attr.Name.UseCDATA.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/HTML.BlockWrapper.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/HTML.CoreModules.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/HTML.CustomDoctype.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/HTML.DefinitionID.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/HTML.DefinitionRev.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/HTML.Doctype.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/HTML.FlashAllowFullScreen.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/HTML.ForbiddenAttributes.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/HTML.ForbiddenElements.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/HTML.MaxImgLength.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/HTML.Nofollow.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/HTML.Parent.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/HTML.Proprietary.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/HTML.SafeEmbed.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/HTML.SafeIframe.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/HTML.SafeObject.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/HTML.SafeScripting.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/HTML.Strict.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/HTML.TargetBlank.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/HTML.TargetNoreferrer.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/HTML.TidyAdd.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/HTML.TidyLevel.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/HTML.TidyRemove.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/HTML.Trusted.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/HTML.XHTML.txt
 extracting: /u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/info.ini
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Output.CommentScriptContents.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Output.FixInnerHTML.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Output.FlashCompat.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Output.Newline.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Output.SortAttr.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Output.TidyFormat.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/Test.ForceNoIconv.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/URI.AllowedSchemes.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/URI.Base.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/URI.DefaultScheme.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/URI.DefinitionID.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/URI.DefinitionRev.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/URI.Disable.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/URI.DisableExternal.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/URI.DisableExternalResources.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/URI.DisableResources.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/URI.Host.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/URI.HostBlacklist.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/URI.MakeAbsolute.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/URI.Munge.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/URI.MungeResources.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/URI.MungeSecretKey.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/URI.OverrideAllowedSchemes.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/schema/URI.SafeIframeRegexp.txt
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/Validator.php
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/ConfigSchema/ValidatorAtom.php
creat: /u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/DefinitionCache/
creat: /u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/DefinitionCache/Serializer/
creat: /u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/DefinitionCache/Serializer/HTML/
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/DefinitionCache/Serializer/HTML/4.8.0,b6889960956c877d241a7e8f87e613efc7a3611d,1.ser
creat: /u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/EntityLookup/
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/EntityLookup/entities.ser
creat: /u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/Filter/
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/Filter/ExtractStyleBlocks.php
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/Filter/YouTube.php
creat: /u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/Language/
creat: /u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/Language/classes/
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/Language/classes/en-x-test.php
creat: /u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/Language/messages/
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/Language/messages/en.php
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/Language/messages/en-x-test.php
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/Language/messages/en-x-testmini.php
creat: /u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/Lexer/
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/Lexer/PH5P.php
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/Printer.php
creat: /u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/Printer/
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/Printer/ConfigForm.css
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/Printer/ConfigForm.js
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/Printer/ConfigForm.php
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/Printer/CSSDefinition.php
inflg:/u/s/E/MW-dev/ms/lib/htmlpurifier/standalone/HTMLPurifier/Printer/HTMLDefinition.php
 extracting: /u/s/E/MW-dev/ms/lib/index.html
inflg:/u/s/E/MW-dev/ms/lib/IPSet.php
creat: /u/s/E/MW-dev/ms/lib/jpgraph/
creat: /u/s/E/MW-dev/ms/lib/jpgraph/src/
creat: /u/s/E/MW-dev/ms/lib/jpgraph/src/barcode/
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/barcode/mkbarcode.php
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/flag_mapping
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/flags.dat
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/flags_thumb100x100.dat
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/flags_thumb35x35.dat
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/flags_thumb60x60.dat
creat: /u/s/E/MW-dev/ms/lib/jpgraph/src/fonts/
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/fonts/DejaVuSans.ttf
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/fonts/DejaVuSans-Bold.ttf
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/fonts/DejaVuSans-BoldOblique.ttf
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/fonts/DejaVuSans-Oblique.ttf
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/fonts/FF_FONT0.gdf
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/fonts/FF_FONT0-Bold.gdf
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/fonts/FF_FONT1.gdf
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/fonts/FF_FONT1-Bold.gdf
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/fonts/FF_FONT2.gdf
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/fonts/FF_FONT2-Bold.gdf
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/gd_image.inc.php
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/imageSmoothArc.php
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/imgdata_balls.inc.php
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/imgdata_bevels.inc.php
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/imgdata_diamonds.inc.php
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/imgdata_pushpins.inc.php
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/imgdata_squares.inc.php
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/imgdata_stars.inc.php
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpg-config.inc.php
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpg-config.inc.php.orig
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph.php
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph_antispam.php
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph_antispam-digits.php
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph_bar.php
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph_canvas.php
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph_canvtools.php
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph_contour.php
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph_date.php
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph_errhandler.inc.php
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph_error.php
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph_flags.php
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph_gantt.php
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph_gb2312.php
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph_gradient.php
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph_iconplot.php
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph_imgtrans.php
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph_led.php
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph_legend.inc.php
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph_line.php
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph_log.php
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph_meshinterpolate.inc.php
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph_mgraph.php
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph_pie.php
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph_pie3d.php
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph_plotband.php
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph_plotline.php
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph_plotmark.inc.php
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph_polar.php
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph_radar.php
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph_regstat.php
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph_rgb.inc.php
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph_scatter.php
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph_stock.php
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph_table.php
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph_text.inc.php
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph_theme.inc.php
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph_ttf.inc.php
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph_utils.inc.php
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/jpgraph_windrose.php
creat: /u/s/E/MW-dev/ms/lib/jpgraph/src/lang/
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/lang/de.inc.php
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/lang/en.inc.php
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/lang/prod.inc.php
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/README
creat: /u/s/E/MW-dev/ms/lib/jpgraph/src/themes/
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/themes/AquaTheme.class.php
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/themes/GreenTheme.class.php
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/themes/OceanTheme.class.php
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/themes/OrangeTheme.class.php
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/themes/PastelTheme.class.php
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/themes/RoseTheme.class.php
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/themes/SoftyTheme.class.php
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/themes/UniversalTheme.class.php
inflg:/u/s/E/MW-dev/ms/lib/jpgraph/src/themes/VividTheme.class.php
 extracting: /u/s/E/MW-dev/ms/lib/jpgraph/VERSION
inflg:/u/s/E/MW-dev/ms/lib/password.php
creat: /u/s/E/MW-dev/ms/lib/pear/
inflg:/u/s/E/MW-dev/ms/lib/pear/LICENSE
inflg:/u/s/E/MW-dev/ms/lib/pear/Mail.php
creat: /u/s/E/MW-dev/ms/lib/pear/Mail/
inflg:/u/s/E/MW-dev/ms/lib/pear/Mail/mail.php
inflg:/u/s/E/MW-dev/ms/lib/pear/Mail/mime.php
inflg:/u/s/E/MW-dev/ms/lib/pear/Mail/mimeDecode.php
inflg:/u/s/E/MW-dev/ms/lib/pear/Mail/mimePart.php
inflg:/u/s/E/MW-dev/ms/lib/pear/Mail/mock.php
inflg:/u/s/E/MW-dev/ms/lib/pear/Mail/null.php
inflg:/u/s/E/MW-dev/ms/lib/pear/Mail/RFC822.php
inflg:/u/s/E/MW-dev/ms/lib/pear/Mail/sendmail.php
inflg:/u/s/E/MW-dev/ms/lib/pear/Mail/smtp.php
inflg:/u/s/E/MW-dev/ms/lib/pear/Mail/smtpmx.php
creat: /u/s/E/MW-dev/ms/lib/pear/Net/
inflg:/u/s/E/MW-dev/ms/lib/pear/Net/SMTP.php
inflg:/u/s/E/MW-dev/ms/lib/pear/Net/Socket.php
creat: /u/s/E/MW-dev/ms/lib/pear/OS/
inflg:/u/s/E/MW-dev/ms/lib/pear/OS/Guess.php
inflg:/u/s/E/MW-dev/ms/lib/pear/Pager.php
creat: /u/s/E/MW-dev/ms/lib/pear/Pager/
inflg:/u/s/E/MW-dev/ms/lib/pear/Pager/Common.php
inflg:/u/s/E/MW-dev/ms/lib/pear/Pager/HtmlWidgets.php
inflg:/u/s/E/MW-dev/ms/lib/pear/Pager/Jumping.php
inflg:/u/s/E/MW-dev/ms/lib/pear/Pager/Pager.php
inflg:/u/s/E/MW-dev/ms/lib/pear/Pager/Sliding.php
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR.php
creat: /u/s/E/MW-dev/ms/lib/pear/PEAR/
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/Autoloader.php
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/Builder.php
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/ChannelFile.php
creat: /u/s/E/MW-dev/ms/lib/pear/PEAR/ChannelFile/
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/ChannelFile/Parser.php
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/Command.php
creat: /u/s/E/MW-dev/ms/lib/pear/PEAR/Command/
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/Command/Auth.php
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/Command/Auth.xml
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/Command/Build.php
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/Command/Build.xml
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/Command/Channels.php
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/Command/Channels.xml
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/Command/Common.php
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/Command/Config.php
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/Command/Config.xml
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/Command/Install.php
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/Command/Install.xml
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/Command/Mirror.php
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/Command/Mirror.xml
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/Command/Pck.php
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/Command/Pck.xml
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/Command/Pickle.php
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/Command/Pickle.xml
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/Command/Registry.php
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/Command/Registry.xml
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/Command/Remote.php
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/Command/Remote.xml
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/Command/Test.php
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/Command/Test.xml
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/Common.php
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/Config.php
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/Dependency2.php
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/DependencyDB.php
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/Downloader.php
creat: /u/s/E/MW-dev/ms/lib/pear/PEAR/Downloader/
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/Downloader/Pck.php
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/ErrorStack.php
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/Exception.php
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/Frontend.php
creat: /u/s/E/MW-dev/ms/lib/pear/PEAR/Frontend/
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/Frontend/CLI.php
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/Installer.php
creat: /u/s/E/MW-dev/ms/lib/pear/PEAR/Installer/
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/Installer/Role.php
creat: /u/s/E/MW-dev/ms/lib/pear/PEAR/Installer/Role/
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/Installer/Role/Cfg.php
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/Installer/Role/Cfg.xml
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/Installer/Role/Common.php
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/Installer/Role/Data.php
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/Installer/Role/Data.xml
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/Installer/Role/Doc.php
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/Installer/Role/Doc.xml
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/Installer/Role/Ext.php
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/Installer/Role/Ext.xml
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/Installer/Role/Man.php
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/Installer/Role/Man.xml
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/Installer/Role/Php.php
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/Installer/Role/Php.xml
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/Installer/Role/Script.php
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/Installer/Role/Script.xml
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/Installer/Role/Src.php
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/Installer/Role/Src.xml
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/Installer/Role/Test.php
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/Installer/Role/Test.xml
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/Installer/Role/Www.php
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/Installer/Role/Www.xml
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/PckFile.php
creat: /u/s/E/MW-dev/ms/lib/pear/PEAR/PckFile/
creat: /u/s/E/MW-dev/ms/lib/pear/PEAR/PckFile/Generator/
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/PckFile/Generator/v1.php
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/PckFile/Generator/v2.php
creat: /u/s/E/MW-dev/ms/lib/pear/PEAR/PckFile/Parser/
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/PckFile/Parser/v1.php
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/PckFile/Parser/v2.php
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/PckFile/v1.php
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/PckFile/v2.php
creat: /u/s/E/MW-dev/ms/lib/pear/PEAR/PckFile/v2/
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/PckFile/v2/rw.php
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/PckFile/v2/Validator.php
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/Pckr.php
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/Registry.php
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/REST.php
creat: /u/s/E/MW-dev/ms/lib/pear/PEAR/REST/
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/REST/10.php
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/REST/11.php
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/REST/13.php
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/RunTest.php
creat: /u/s/E/MW-dev/ms/lib/pear/PEAR/Task/
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/Task/Common.php
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/Task/Postinstallscript.php
creat: /u/s/E/MW-dev/ms/lib/pear/PEAR/Task/Postinstallscript/
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/Task/Postinstallscript/rw.php
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/Task/Replace.php
creat: /u/s/E/MW-dev/ms/lib/pear/PEAR/Task/Replace/
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/Task/Replace/rw.php
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/Task/Unixeol.php
creat: /u/s/E/MW-dev/ms/lib/pear/PEAR/Task/Unixeol/
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/Task/Unixeol/rw.php
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/Task/Windowseol.php
creat: /u/s/E/MW-dev/ms/lib/pear/PEAR/Task/Windowseol/
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/Task/Windowseol/rw.php
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/Validate.php
creat: /u/s/E/MW-dev/ms/lib/pear/PEAR/Validator/
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/Validator/PECL.php
inflg:/u/s/E/MW-dev/ms/lib/pear/PEAR/XMLParser.php
inflg:/u/s/E/MW-dev/ms/lib/pear/System.php
creat: /u/s/E/MW-dev/ms/lib/request/
inflg:/u/s/E/MW-dev/ms/lib/request/Requests.php
creat: /u/s/E/MW-dev/ms/lib/request/Requests/
inflg:/u/s/E/MW-dev/ms/lib/request/Requests/Auth.php
creat: /u/s/E/MW-dev/ms/lib/request/Requests/Auth/
inflg:/u/s/E/MW-dev/ms/lib/request/Requests/Auth/Basic.php
inflg:/u/s/E/MW-dev/ms/lib/request/Requests/Cookie.php
creat: /u/s/E/MW-dev/ms/lib/request/Requests/Cookie/
inflg:/u/s/E/MW-dev/ms/lib/request/Requests/Cookie/Jar.php
inflg:/u/s/E/MW-dev/ms/lib/request/Requests/Exception.php
creat: /u/s/E/MW-dev/ms/lib/request/Requests/Exception/
inflg:/u/s/E/MW-dev/ms/lib/request/Requests/Exception/HTTP.php
creat: /u/s/E/MW-dev/ms/lib/request/Requests/Exception/HTTP/
inflg:/u/s/E/MW-dev/ms/lib/request/Requests/Exception/HTTP/400.php
inflg:/u/s/E/MW-dev/ms/lib/request/Requests/Exception/HTTP/401.php
inflg:/u/s/E/MW-dev/ms/lib/request/Requests/Exception/HTTP/402.php
inflg:/u/s/E/MW-dev/ms/lib/request/Requests/Exception/HTTP/403.php
inflg:/u/s/E/MW-dev/ms/lib/request/Requests/Exception/HTTP/404.php
inflg:/u/s/E/MW-dev/ms/lib/request/Requests/Exception/HTTP/405.php
inflg:/u/s/E/MW-dev/ms/lib/request/Requests/Exception/HTTP/406.php
inflg:/u/s/E/MW-dev/ms/lib/request/Requests/Exception/HTTP/407.php
inflg:/u/s/E/MW-dev/ms/lib/request/Requests/Exception/HTTP/408.php
inflg:/u/s/E/MW-dev/ms/lib/request/Requests/Exception/HTTP/409.php
inflg:/u/s/E/MW-dev/ms/lib/request/Requests/Exception/HTTP/410.php
inflg:/u/s/E/MW-dev/ms/lib/request/Requests/Exception/HTTP/411.php
inflg:/u/s/E/MW-dev/ms/lib/request/Requests/Exception/HTTP/412.php
inflg:/u/s/E/MW-dev/ms/lib/request/Requests/Exception/HTTP/413.php
inflg:/u/s/E/MW-dev/ms/lib/request/Requests/Exception/HTTP/414.php
inflg:/u/s/E/MW-dev/ms/lib/request/Requests/Exception/HTTP/415.php
inflg:/u/s/E/MW-dev/ms/lib/request/Requests/Exception/HTTP/416.php
inflg:/u/s/E/MW-dev/ms/lib/request/Requests/Exception/HTTP/417.php
inflg:/u/s/E/MW-dev/ms/lib/request/Requests/Exception/HTTP/418.php
inflg:/u/s/E/MW-dev/ms/lib/request/Requests/Exception/HTTP/428.php
inflg:/u/s/E/MW-dev/ms/lib/request/Requests/Exception/HTTP/429.php
inflg:/u/s/E/MW-dev/ms/lib/request/Requests/Exception/HTTP/431.php
inflg:/u/s/E/MW-dev/ms/lib/request/Requests/Exception/HTTP/500.php
inflg:/u/s/E/MW-dev/ms/lib/request/Requests/Exception/HTTP/501.php
inflg:/u/s/E/MW-dev/ms/lib/request/Requests/Exception/HTTP/502.php
inflg:/u/s/E/MW-dev/ms/lib/request/Requests/Exception/HTTP/503.php
inflg:/u/s/E/MW-dev/ms/lib/request/Requests/Exception/HTTP/504.php
inflg:/u/s/E/MW-dev/ms/lib/request/Requests/Exception/HTTP/505.php
inflg:/u/s/E/MW-dev/ms/lib/request/Requests/Exception/HTTP/511.php
inflg:/u/s/E/MW-dev/ms/lib/request/Requests/Exception/HTTP/Unknown.php
inflg:/u/s/E/MW-dev/ms/lib/request/Requests/Hooker.php
inflg:/u/s/E/MW-dev/ms/lib/request/Requests/Hooks.php
inflg:/u/s/E/MW-dev/ms/lib/request/Requests/IDNAEncoder.php
inflg:/u/s/E/MW-dev/ms/lib/request/Requests/IPv6.php
inflg:/u/s/E/MW-dev/ms/lib/request/Requests/IRI.php
inflg:/u/s/E/MW-dev/ms/lib/request/Requests/Proxy.php
creat: /u/s/E/MW-dev/ms/lib/request/Requests/Proxy/
inflg:/u/s/E/MW-dev/ms/lib/request/Requests/Proxy/HTTP.php
inflg:/u/s/E/MW-dev/ms/lib/request/Requests/Proxy/SOCKS5.php
inflg:/u/s/E/MW-dev/ms/lib/request/Requests/Response.php
creat: /u/s/E/MW-dev/ms/lib/request/Requests/Response/
inflg:/u/s/E/MW-dev/ms/lib/request/Requests/Response/Headers.php
inflg:/u/s/E/MW-dev/ms/lib/request/Requests/Session.php
inflg:/u/s/E/MW-dev/ms/lib/request/Requests/SSL.php
inflg:/u/s/E/MW-dev/ms/lib/request/Requests/Transport.php
creat: /u/s/E/MW-dev/ms/lib/request/Requests/Transport/
inflg:/u/s/E/MW-dev/ms/lib/request/Requests/Transport/cacert.pem
inflg:/u/s/E/MW-dev/ms/lib/request/Requests/Transport/cURL.php
inflg:/u/s/E/MW-dev/ms/lib/request/Requests/Transport/fsockopen.php
creat: /u/s/E/MW-dev/ms/lib/request/Requests/Utility/
inflg:/u/s/E/MW-dev/ms/lib/request/Requests/Utility/CaseInsensitiveDictionary.php
inflg:/u/s/E/MW-dev/ms/lib/request/Requests/Utility/FilteredIterator.php
creat: /u/s/E/MW-dev/ms/lib/xmlrpc/
inflg:/u/s/E/MW-dev/ms/lib/xmlrpc/xmlrpc.inc
inflg:/u/s/E/MW-dev/ms/lib/xmlrpc/xmlrpc_wrappers.inc
inflg:/u/s/E/MW-dev/ms/lib/xmlrpc/xmlrpcs.inc
inflg:/u/s/E/MW-dev/ms/lists.php
inflg:/u/s/E/MW-dev/ms/login.function.php
inflg:/u/s/E/MW-dev/ms/login.php
inflg:/u/s/E/MW-dev/ms/logout.php
inflg:/u/s/E/MW-dev/ms/mailq.php
inflg:/u/s/E/MW-dev/ms/mcafee.awk
inflg:/u/s/E/MW-dev/ms/mcafee_status.php
inflg:/u/s/E/MW-dev/ms/mcp_rules_update.php
inflg:/u/s/E/MW-dev/ms/ms_lint.php
inflg:/u/s/E/MW-dev/ms/msconfig.php
inflg:/u/s/E/MW-dev/ms/msre_edit.php
inflg:/u/s/E/MW-dev/ms/msre_index.php
inflg:/u/s/E/MW-dev/ms/msre_table_functions.php
inflg:/u/s/E/MW-dev/ms/msrule.php
inflg:/u/s/E/MW-dev/ms/mtalogprocessor.inc.php
inflg:/u/s/E/MW-dev/ms/mysql_status.php
inflg:/u/s/E/MW-dev/ms/other.php
inflg:/u/s/E/MW-dev/ms/password_reset.php
inflg:/u/s/E/MW-dev/ms/postfix.inc.php
inflg:/u/s/E/MW-dev/ms/postfixmailq.php
inflg:/u/s/E/MW-dev/ms/quarantine.php
inflg:/u/s/E/MW-dev/ms/quarantine_action.php
inflg:/u/s/E/MW-dev/ms/quarantine_report.inc.php
inflg:/u/s/E/MW-dev/ms/rep_audit_log.php
inflg:/u/s/E/MW-dev/ms/rep_mcp_rule_hits.php
inflg:/u/s/E/MW-dev/ms/rep_mcp_score_dist.php
inflg:/u/s/E/MW-dev/ms/rep_message_listing.php
inflg:/u/s/E/MW-dev/ms/rep_message_ops.php
inflg:/u/s/E/MW-dev/ms/rep_mrtg_style.php
inflg:/u/s/E/MW-dev/ms/rep_sa_rule_hits.php
inflg:/u/s/E/MW-dev/ms/rep_sa_score_dist.php
inflg:/u/s/E/MW-dev/ms/rep_top_mail_relays.php
inflg:/u/s/E/MW-dev/ms/rep_top_recipient_domains_by_quantity.php
inflg:/u/s/E/MW-dev/ms/rep_top_recipient_domains_by_volume.php
inflg:/u/s/E/MW-dev/ms/rep_top_recipients_by_quantity.php
inflg:/u/s/E/MW-dev/ms/rep_top_recipients_by_volume.php
inflg:/u/s/E/MW-dev/ms/rep_top_sender_domains_by_quantity.php
inflg:/u/s/E/MW-dev/ms/rep_top_sender_domains_by_volume.php
inflg:/u/s/E/MW-dev/ms/rep_top_senders_by_quantity.php
inflg:/u/s/E/MW-dev/ms/rep_top_senders_by_volume.php
inflg:/u/s/E/MW-dev/ms/rep_top_viruses.php
inflg:/u/s/E/MW-dev/ms/rep_total_mail_by_date.php
inflg:/u/s/E/MW-dev/ms/rep_viruses.php
inflg:/u/s/E/MW-dev/ms/reports.php
 extracting: /u/s/E/MW-dev/ms/robots.txt
inflg:/u/s/E/MW-dev/ms/rpcserver.php
inflg:/u/s/E/MW-dev/ms/sa_lint.php
inflg:/u/s/E/MW-dev/ms/sa_rules_update.php
inflg:/u/s/E/MW-dev/ms/sf_version.php
inflg:/u/s/E/MW-dev/ms/sophos.awk
inflg:/u/s/E/MW-dev/ms/sophos_status.php
inflg:/u/s/E/MW-dev/ms/status.php
inflg:/u/s/E/MW-dev/ms/style.css
inflg:/u/s/E/MW-dev/ms/syslog_parser.inc.php
creat: /u/s/E/MW-dev/ms/temp/
inflg:/u/s/E/MW-dev/ms/temp/.gitignore
 extracting: /u/s/E/MW-dev/ms/temp/index.html
inflg:/u/s/E/MW-dev/ms/user_manager.php
inflg:/u/s/E/MW-dev/ms/viewmail.php
inflg:/u/s/E/MW-dev/ms/viewpart.php
creat: /u/s/E/MW-dev/MailScanner_perl_scripts/
inflg:/u/s/E/MW-dev/MailScanner_perl_scripts/INSTALL
inflg:/u/s/E/MW-dev/MailScanner_perl_scripts/MailWatch.pm
inflg:/u/s/E/MW-dev/MailScanner_perl_scripts/MailWatchConf.pm
inflg:/u/s/E/MW-dev/MailScanner_perl_scripts/SQLBlackWhiteList.pm
inflg:/u/s/E/MW-dev/MailScanner_perl_scripts/SQLSpamSettings.pm
inflg:/u/s/E/MW-dev/README.md
inflg:/u/s/E/MW-dev/Remote_DB.txt
inflg:/u/s/E/MW-dev/SECURITY
creat: /u/s/E/MW-dev/tools/
creat: /u/s/E/MW-dev/tools/Cron_jobs/
inflg:/u/s/E/MW-dev/tools/Cron_jobs/INSTALL
inflg:/u/s/E/MW-dev/tools/Cron_jobs/mailwatch
inflg:/u/s/E/MW-dev/tools/Cron_jobs/mailwatch_db_clean.php
inflg:/u/s/E/MW-dev/tools/Cron_jobs/mailwatch_quarantine_maint.php
inflg:/u/s/E/MW-dev/tools/Cron_jobs/mailwatch_quarantine_report.php
creat: /u/s/E/MW-dev/tools/LDAP/
inflg:/u/s/E/MW-dev/tools/LDAP/mailwatch_ldap_sync.sh
creat: /u/s/E/MW-dev/tools/MailScanner_config/
inflg:/u/s/E/MW-dev/tools/MailScanner_config/00_MailWatch.conf
creat: /u/s/E/MW-dev/tools/MailScanner_rule_editor/
inflg:/u/s/E/MW-dev/tools/MailScanner_rule_editor/INSTALL
inflg:/u/s/E/MW-dev/tools/MailScanner_rule_editor/msre_reload.crontab
inflg:/u/s/E/MW-dev/tools/MailScanner_rule_editor/msre_reload.sh
creat: /u/s/E/MW-dev/tools/Postfix_relay/
inflg:/u/s/E/MW-dev/tools/Postfix_relay/INSTALL
inflg:/u/s/E/MW-dev/tools/Postfix_relay/mailwatch_mailscanner_relay.php
inflg:/u/s/E/MW-dev/tools/Postfix_relay/mailwatch_postfix_relay.php
inflg:/u/s/E/MW-dev/tools/Postfix_relay/mailwatch-postfix-relay
creat: /u/s/E/MW-dev/tools/Sendmail_relay/
inflg:/u/s/E/MW-dev/tools/Sendmail_relay/INSTALL
inflg:/u/s/E/MW-dev/tools/Sendmail_relay/mailwatch_sendmail_relay.php
inflg:/u/s/E/MW-dev/tools/Sendmail_relay/mailwatch-sendmail-relay
creat: /u/s/E/MW-dev/tools/Sendmail-Exim_queue/
inflg:/u/s/E/MW-dev/tools/Sendmail-Exim_queue/INSTALL
inflg:/u/s/E/MW-dev/tools/Sendmail-Exim_queue/mailq.crontab
inflg:/u/s/E/MW-dev/tools/Sendmail-Exim_queue/mailwatch_sendmail_queue.php
creat: /u/s/E/MW-dev/tools/sudo/
inflg:/u/s/E/MW-dev/tools/sudo/INSTALL
inflg:/u/s/E/MW-dev/tools/sudo/mailwatch
inflg:/u/s/E/MW-dev/upgrade.php
inflg:/u/s/E/MW-dev/UPGRADING
inflg:/u/s/E/MW-dev/USER_FILTERS
MailWatch for MailScanner Database Upgrade to 1.2.3-dev
Testing connectivity to the database ............OK
Updating database schema:
-Conv database to utf8..........ALRDY DONE
-Drop `geoip_country` table....................ALRDY DROPPED
-Drop `spamscores` table...........ALRDY DROPPED
-Add autorelease tabl to `mailscanner` database............ALRDY EXIST
-Add resetid, resetexpire and lastreset fields in `users` table..... ALRDY EXIST
-Fix schema for username field in `audit_log` table.............OK
-Fix schema for id field in `blacklist` table...............OK
-Fix schema for username field in `users` table.............OK
-Fix schema for spamscore field in `users` table............OK
-Fix schema for highspamscore field in `users` table............OK
-Fix schema for username field in `user_filters` table..........OK
-Fix schema for username field in `whitelist` table.............OK
-Fix schema for password field in `users` table.............OK
-Fix schema for fullname field in `users` table.............OK
-Fix schema for rule_desc field in `mcp_rules` table............OK
-Clean orphaned user_filters.................OK
-Add id field and primary key to `audit_log` table..........ALRDY DONE
-Add inq_id field and primary key to `inq` table............ALRDY DONE
-Add maillog_id field and primary key to `maillog` table............ ALRDY DONE
-Add rblspamreport field to `maillog` table.................ALRDY DONE
-Add token field to `maillog` table............ALRDY DONE
-Check for missing tokens in `maillog` table................DONE
   0 token generated
-Add mtalog_id field and primary key to `mtalog` table..........ALRDY DONE
-Add mtalog_id field and primary key to `outq` table............ALRDY DONE
-Add id field and primary key to `saved_filters` table..........ALRDY DONE
-Add mtalog_id field and primary key to `user_filters` table........ ALRDY DONE
-Dropping too big index `maillog_from_idx` on tabl `maillog`....... ALRDY DONE
-Dropping too big index `maillog_to_idx` on tabl `maillog`......... ALRDY DONE
-Conv database to utf8mb4...................ALRDY DONE
-Conv tabl `audit_log` to utf8mb4..........ALRDY CONVD
-Conv tabl `autorelease` to utf8mb4.....................ALRDY CONVD
-Conv tabl `blacklist` to utf8mb4..........ALRDY CONVD
-Conv tabl `inq` to utf8mb4................ALRDY CONVD
-Conv tabl `maillog` to utf8mb4............ALRDY CONVD
-Conv tabl `mcp_rules` to utf8mb4..........ALRDY CONVD
-Conv tabl `mtalog` to utf8mb4.............ALRDY CONVD
-Conv tabl `mtalog_ids` to utf8mb4..........ALRDY CONVD
-Conv tabl `outq` to utf8mb4...............ALRDY CONVD
-Conv tabl `saved_filters` to utf8mb4...................ALRDY CONVD
-Conv tabl `sa_rules` to utf8mb4...........ALRDY CONVD
-Conv tabl `users` to utf8mb4..............ALRDY CONVD
-Conv tabl `user_filters` to utf8mb4....................ALRDY CONVD
-Conv tabl `whitelist` to utf8mb4..........ALRDY CONVD
-Conv tabl `audit_log` to InnoDB...........ALRDY CONVD
-Conv tabl `autorelease` to InnoDB..........ALRDY CONVD
-Conv tabl `blacklist` to InnoDB...........ALRDY CONVD
-Conv tabl `inq` to InnoDB.................ALRDY CONVD
-Conv tabl `maillog` to InnoDB.............ALRDY CONVD
-Conv tabl `mcp_rules` to InnoDB...........ALRDY CONVD
-Conv tabl `mtalog` to InnoDB..............ALRDY CONVD
-Conv tabl `mtalog_ids` to InnoDB..........ALRDY CONVD
-Conv tabl `outq` to InnoDB................ALRDY CONVD
-Conv tabl `saved_filters` to InnoDB....................ALRDY CONVD
-Conv tabl `sa_rules` to InnoDB............ALRDY CONVD
-Conv tabl `users` to InnoDB...............ALRDY CONVD
-Conv tabl `user_filters` to InnoDB.....................ALRDY CONVD
-Conv tabl `whitelist` to InnoDB...........ALRDY CONVD
-Search for missing indexes on tabl `maillog`..............DONE
-Adding missing index `subject_idx` on tabl `maillog`..........WARNING
Checking MailScanner.conf settings:
-QuarantineWholeMessage ...........OK
-QuarantineWholeMessagesAsQueueFiles ..........OK
-DetailedSpamReport ...............OK
-IncludeScoresInSpamAssassinReport ............OK
-SpamActions ......................OK
-HighScoringSpamActions ...........OK
-AlwaysLookedUpLast ...............OK
Checking conf.php conf entry:
-All mandatory entries are present.............OK
-All obsolete entries are ALRDY removed...................OK
-opt RPC_PORT ................WARNING
-opt RPC_SSL .................WARNING
-opt RPC_REMOTE_SERVER ...................WARNING
-opt LDAP_BIND_PREFIX ....................WARNING
-opt LDAP_BIND_SUFFIX ....................WARNING
-opt EXIM_QUEUE_IN ...........WARNING
-opt EXIM_QUEUE_OUT ..........WARNING
-opt PWD_RESET_FROM_NAME .................WARNING
-opt PWD_RESET_FROM_ADDRESS ..............WARNING
-opt MAIL_SENDER .............WARNING
-opt SESSION_NAME ............WARNING
-opt USER_SELECTABLE_LANG ................WARNING
*** ERROR/WARNING SUMMARY ***
tabl Index: MySQL version unsupported for index `subject_idx` on tabl `maillog`, upgrade to version >= 50604 (you have version 50505)
conf.php: opt conf entry "RPC_PORT" is missing, needed if RPC_ONLY mode is enabled
conf.php: opt conf entry "RPC_SSL" is missing, needed if RPC_ONLY mode is enabled
conf.php: opt conf entry "RPC_REMOTE_SERVER" is missing, needed to show number of mails in postfix queues on remote server (RPC)
conf.php: opt conf entry "LDAP_BIND_PREFIX" is missing, needed when using LDAP authentication
conf.php: opt conf entry "LDAP_BIND_SUFFIX" is missing, needed when using LDAP authentication
conf.php: opt conf entry "EXIM_QUEUE_IN" is missing, needed only if using Exim as MTA
conf.php: opt conf entry "EXIM_QUEUE_OUT" is missing, needed only if using Exim as MTA
conf.php: opt conf entry "PWD_RESET_FROM_NAME" is missing, needed if Password Reset feature is enabled
conf.php: opt conf entry "PWD_RESET_FROM_ADDRESS" is missing, needed if Password Reset feature is enabled
conf.php: opt conf entry "MAIL_SENDER" is missing, needed if you use Exim or Sendmail Queue
conf.php: opt conf entry "SESSION_NAME" is missing, needed if experiencing session conflicts
conf.php: opt conf entry "USER_SELECTABLE_LANG" is missing, comma separated list of codes for languages the users can use eg. "de,en,fr,it,nl,pt_br"
Downloading file, please wait...
GeoIP IPv4 data file successfully downloaded
GeoIP IPv6 data file successfully downloaded
Download complete, unpacking files...
GeoIP IPv4 data file successfully unpacked
GeoIP IPv6 data file successfully unpacked
Process completed!
Starting httpd:  [  OK  ]
MailScanner starting ...
MailScanner started with process id 4327
3.0.2.2 update is complete
All done
Thank you for using E.F.A.
