New build 3.0.2.2, endless loop releasing from quarantine
Posted: 11 May 2017 07:58
by r31griffo
Hi everyone,
I've had to turn off my newly built eFa :(
One of our users received a newsletter which had a large number of recipients in the TO: field, she released the email and I noticed the recent messages list was populated with this email over and over again. Each time the subject was prepended with {spam not delivered} and the sender was the system's postmaster email address. By the time I turned this off there must have been 20x {spam not delivered} in the subject.
I looked at the reports and external people/domains were the highest recipients of emails, have we just spammed people with a newsletter? Anyway, keen to know your thoughts...
1. I don't think restarting cleared it out (although I could be wrong), how do I clear this email out?
2. How can I find out if the message was sent externally or caught before it was sent?
Re: New build 3.0.2.2, endless loop releasing from quarantine
Posted: 11 May 2017 08:56
It sounds like efa detected the outgoing newsletter as spam. I think you need to resolve that problem first.
Second, what are the settings of the following in /etc/MailScanner.conf?
Spam Actions = ?
High Scoring Spam Actions = ?
Non Spam Actions = ?
Lastly, to delete messages from the mail queue, use the webadmin control panel at https://<your efa box>:10000/ and log in using the root password.
Look under Server, Postfix Mail Server, Mail Queue. You can manipulate the queue from here.
Posted: 11 May 2017 10:24
by r31griffo
Thanks for the tip regarding the message queue.
I logged in using root's password and went to the area you suggested and can see 2 emails (the same newsletter). I've tied selecting both and deleting and also flushing queue but don't appear to work.
Spam Actions = store custom(spam)
High Scoring Spam Actions = store
Non Spam Actions = store deliver header "X-spam-status:No" customer(nonspam)
When she released the email I don't believe it was via the nightly message but an email she received instead of the spam...does that help?
Posted: 11 May 2017 10:33
by r31griffo
I realised that the message ID kept changing when I deleted the 2 stuck in the queue, something was happening but I'm not sure what.
I stopped Postfix, deleted again and now they appear to be gone. I've restarted the server to be sure, I'm pretty sure they're gone.
So the immediate issue is resolved, I just need to find out why and how it happened...given the variables in /etc/Mailscanner/Mailscanner.conf, do you have any suggestions on where I should start looking?
Posted: 14 May 2017 12:39
Did this happen upon initial delivery, or did it start after releasing it from quarantine (as the title suggests)?
Posted: 17 May 2017 02:52
by r31griffo
shawniverson wrote: 14 May 2017 12:39 Did this happen upon initial delivery, or did it start after releasing it from quarantine (as the title suggests)?
G'day Shawn,
I'm sorry for the delayed reply, I usually check in more frequently.
I noticed the original quarantined message in the recent messages list in the webinterface, about 20 minutes later I noticed that the log had filled with the same message...I believe it was just after the user clicked a link in the {spam not delivered} email to release it. The sender in the new quarantined emails had also changed to come from postmaster@mydomain.com.au.
As a side note, I'd prefer to stop the users receiving the {spam not delivered} emails and only the daily summary...is there a setting to change this?
Cheers,
Brad
