update from 3.0.1.9 to 3.0.2.2 not possible
frauer
Post by frauer »
Hi together,
on weekend I wanted to make an update to the last version.
Actually we´re on 3.0.1.9...by choosing the point 14 the system is telling to make an update to 3.0.2.2, but after a moment
I get the following error message...
[EFA] : 14
[EFA] Good you are root
[EFA] Starting update to EFA-3.0.2.2
Setting up Update Process
* EFA: dl.efa-project.org
* base: ftp.plusline.de
* epel: mirror.de.leaseweb.net
* extras: centos.mirrors.psw.services
* mariadb: mirror.netcologne.de
* updates: mirror.ratiokontakt.de
Resolving Dependencies
--> Running transaction check
---> Package kernel-firmware.noarch 0:2.6.32-642.15.1.el6 will be updated
---> Package kernel-firmware.noarch 0:2.6.32-696.1.1.el6 will be an update
---> Package kernel-headers.x86_64 0:2.6.32-642.15.1.el6 will be updated
---> Package kernel-headers.x86_64 0:2.6.32-696.1.1.el6 will be an update
Dependencies Resolved
Package Arch Version Repository Size
Updating:
kernel-firmware noarch 2.6.32-696.1.1.el6 updates 29 M
kernel-headers x86_64 2.6.32-696.1.1.el6 updates 4.5 M
Transaction Summary
Upgrade 2 Package(s)
Total size: 33 M
Downloading Packages:
Running rpm_check_debug
Running Transaction Test
Transaction Check Error:
package kernel-headers-2.6.32-696.1.1.el6.x86_64 is already installed
package kernel-firmware-2.6.32-696.1.1.el6.noarch is already installed
Error Summary
Update to Version 3.0.2.0 FAILED. Updates cancelled.
How I could solve this ?
Frank
Re: update from 3.0.1.9 to 3.0.2.2 not possible
Try running a "yum clean all" and giving it another shot.
Worst case, you could remove those two packages and then rerun the update.
frauer
Post by frauer »
yum clean all didn´t help, but I was able to remove the packages.
I will give the update a new try after the office hours..
Thanks for the moment
Frank
frauer
Post by frauer »
still no luck with the update... :(
After removing the kernel-headers I started the next update, went smooth the kernel-headers have been installed successful.
I did a reboot and started the next update...but got the next conflicts...
otal 230 kB/s | 108 MB 08:00
file /usr/lib64/libkadm5clnt_mit.so.8.0 from install of libkadm5-1.10.3-65.el6.x86_64 conflicts with file from package krb5-libs-1.10.3-57.el6.x86_64
file /usr/lib64/libkadm5srv_mit.so.8.0 from install of libkadm5-1.10.3-65.el6.x86_64 conflicts with file from package krb5-libs-1.10.3-57.el6.x86_64
Error Summary
What happend to the system ?...right now I never had any problems with it...
Yeah, something is up with your dependencies, not sure why. You may need to work though them like you did with the kernel one.
frauer
Post by frauer »
will be a nice weekend :D , I keep you informed...
