SASL LOGIN authentication failed
Posted: 14 Apr 2017 15:31
by BliXem
Can I ignore these errors? Or is there something wrong on the server?
Apr 14 17:29:47 mailscanner postfix/smtpd[24207]: warning: unknown[64.77.233.90]: SASL LOGIN authentication failed: authentication failure
Apr 14 17:29:47 mailscanner postfix/smtpd[24209]: warning: unknown[64.77.233.90]: SASL LOGIN authentication failed: authentication failure
Apr 14 17:29:47 mailscanner postfix/smtpd[24330]: warning: unknown[64.77.233.90]: SASL LOGIN authentication failed: authentication failure
Apr 14 17:29:47 mailscanner postfix/smtpd[25017]: warning: unknown[64.77.233.90]: SASL LOGIN authentication failed: authentication failure
Re: SASL LOGIN authentication failed
Posted: 15 Apr 2017 15:54
Means someone attempted to login using SASL on SMTP is all. If you don't use SASL, you can safely turn off SASL Auth to suppress these.
Posted: 24 Apr 2017 13:23
or better yet, instead of turning off SASL, install fail2ban and block all those spammers who tried authentication
that's what I do as EFA is simply an incoming filter and outgoing relay for my EX so absolutely no authentication happens on EFA.
Posted: 24 Apr 2017 22:49
That is a really good idea
Posted: 25 Apr 2017 04:14
ovizii wrote: 24 Apr 2017 13:23
ovizii,
Have you implemented this? If so, can you write up some notes on how to do this? This will also have the nice side effect of blocking spammers.
Much appreciated!
Posted: 25 Apr 2017 08:46
sure, I'll try from memory:
yum install fail2ban
then cp /etc/fail2ban/jail.conf /etc/fail2ban/jail.local
edit jail.local and adapt to your needs. remove anything you don't change. Mine looks like this:
[INCLUDES]
before = paths-fedora.conf
[DEFAULT]
ignoreip = 127.0.0.1/8
# 86400 = 24h
bantime = 43200
# 43200 = 12h
findtime = 86400
# "maxretry" is the number of failures before a host get banned.
maxretry = 5
usedns = no
enabled = false
destemail = fail2ban@localhost
sender = fail2ban
mta = mail
banaction = iptables-multiport
banaction_allports = iptables-allports
#disabled the action with _MWL as that sends out emails :-/
#action = %(action_mwl)s
action = %(action_)s
[postfix]
enabled = true
port = smtp,465,submission
logpath = %(postfix_log)s
backend = %(postfix_backend)s
[postfix-rbl]
enabled = true
[postfix-sasl]
enabled = true
port = smtp,465,submission,imap3,imaps,pop3,pop3s
#You might want to enable recidive too by changing false to true below?
[recidive]
enabled = false
logpath = /var/log/messages
banaction = %(banaction_allports)s
bantime = 604800 ; 1 week
findtime = 259200 ; 3 days
maxretry = 5
check the results by looking at the iptables:
iptables -nvL --line-numbers | more
or tailing the log live:
tail -f /var/log/messages | grep fail2ban
I also had to edit: /etc/fail2ban/filter.d/postfix-rbl.conf
and add the second line to the failregex:
failregex = ^%(__prefix_line)sNOQUEUE: reject: RCPT from \S+\[<HOST>\]: 454 4\.7\.1 Service unavailable; Client host \[\S+\] blocked using .* from=<\S*> to=<\S+> proto=ESMTP helo=<\S*>$
^%(__prefix_line)sNOQUEUE: reject: RCPT from \S+\[<HOST>\]: 554 5\.7\.1 Service unavailable; Client host \[\S+\] blocked using .* from=<\S*> to=<\S+> proto=ESMTP helo=<\S*>$
please give me feedback if this works for you or if you spot a mistake.
Posted: 25 Apr 2017 19:07
*rubs hands gleefully*
excellent! I'll test this in the morning. yet another customization to challenge the upgrade process.
Posted: 25 Apr 2017 20:31
I'd be really happy to get feedback in general and particularly to the findtime / bantime I chose. Those might not be the best choices and I'll be glad to hear about someone else's logic and values.
Posted: 26 Apr 2017 08:16
by BliXem
pdwalker wrote: 25 Apr 2017 19:07
And, does it works perfectly?
Posted: 26 Apr 2017 08:23
just started working on it... I'll let you know.
Posted: 26 Apr 2017 08:36
btw. in my above configuration, I have set this action globally, unless a more specific action is defined for a jail.
so this is the global action: action = %(action_)s
and for the recidive jail I specified a different one: action = %(action_mwl)s which sends out emails about each blocked IP.
Posted: 26 Apr 2017 08:38
by BliXem
ovizii wrote: 26 Apr 2017 08:36
To make this easy for me and maybe for others, you should copy your configuration for us with your editted rule(s).
Posted: 26 Apr 2017 08:53
by BliXem
Posted: 26 Apr 2017 09:16
BliXem wrote: 26 Apr 2017 08:38
as I said above: copy jail.conf to jail.local then edit jail.local and delete everything you don't change. here is mine:
https://transfer.sh/5XAfY/jail.local or
https://pastebin.com/jn8K6Ztw
Posted: 26 Apr 2017 09:31
by wilbourne
Thank's
To permanently ban an ip you can use this option:
bantime = -1
findtime = 604800
I use a long findtime to prevent some servers for blacklisted
Posted: 26 Apr 2017 10:29
[root@efa mailscanner]# yum install fail2ban
[root@efa mailscanner]# cp jail.conf jail.local
vi jail.local # and edit according to needs.
I disabled the postfix and postfix-rbl jails, but I enabled the postfix-sasl jail (
viewtopic.php?p=7469#p7469)
Seems to be working, all my sasl authentication failures have basically disappeared.
And the reason I disabled the postfix and postfix-rbl fail2ban jails is most of our mail comes through the messagelabs Antivirus/Antispam filtering service. The service still lets some spam through, and the fail2pan postfix/postfix-rbl rules starts blocking it.
Posted: 26 Apr 2017 10:30
wilbourne wrote: 26 Apr 2017 09:31
Thank's
bantime = -1
findtime = 604800
I don't think permanent bans are a good idea.
Posted: 26 Apr 2017 11:06
pdwalker wrote: 26 Apr 2017 10:29
You're right. What I did was use the action which sends emails for every ban and monitored this very closely. After having no false positives I enabled postfix-rbl but as you said, your mileage may vary
Posted: 04 Sep 2017 10:15
by Gate Array
shawniverson wrote: 15 Apr 2017 15:54
which is the best way to do it?
Posted: 05 Dec 2017 13:35
!!!ATTENTION!!!
Whoever copied my sample config from
https://pastebin.com/jn8K6Ztw please go edit your config and replace my email address with yours. I keep receiving emails for someone else's fail2ban installation
I'm not naming the sender here as to not embarrass anyone and I have edited the pastebin sample and removed my email from there too
Posted: 06 Dec 2017 07:19
Good luck!
Posted: 29 Jan 2020 08:41
pdwalker wrote: 06 Dec 2017 07:19
Good luck!
no luck. still getting those pesky emails
Posted: 29 Jan 2020 11:37
Posted: 29 Jan 2020 11:41
Please don't do that.
I learned a very valuable lesson to double check my posted snippets before publicly submitting them.
Posted: 03 Feb 2020 03:41
*facepalm*
I feel your pain.
