Change IP address Postfix transport
Posted: 14 Apr 2017 08:47
by BliXem
Can you add a option to change existed domains in EFA-Configure -> 8 -> 4?
I need only change the destination, but I cant see that option yet.
Re: Change IP address Postfix transport
Posted: 15 Apr 2017 20:55
So you just need an option to change the second field, right?
Posted: 15 Apr 2017 21:15
by BliXem
Yes, edit domains and then only change the destination, can be a hostname or IP address.
Posted: 15 Apr 2017 21:17
