Spam
BliXem
Spam
Post by BliXem »
Can I do something about this? If yes, can you tell me how? It's to much spam :-(
eceived: from bentgen.net (unknown [66.23.212.50])
by scanner (Postfix) with ESMTP id 8A5273F2A1
for <info@mailaddress>; Tue, 11 Apr 2017 01:03:14 +0200 (CEST)
Date: Mon, 10 Apr 2017 17:44:40 -0500
MIME-Version: 1.0
Subject: My Alzheimers is over thanks to these drops
To: <info@email.com>
Message-ID: <ukRivWXHOQwtfUKHOTsQxypsdz_DO7YE5y7f2ujn_mY.XXdXSW09LI-krCoP5_WkNQe-PrNWTEaNF7EZC0glXm8@bentgen.net>
Content-Type: multipart/alternative;
boundary="------------108663623160718996873640"
ovizii
Re: Spam
Post by ovizii »
To be able to give any advice we need to see the spamassassin report and the score it got.
BliXem
Re: Spam
Post by BliXem »
Received on:	11/04/17 01:03:19
Received by:	mailscanner.domain.com
Received from:
66.23.212.50	[Add to Whitelist | Add to Blacklist]
Received Via:
IP Address	Hostname	Country	RBL	Spam	Virus	All
66.23.212.50	(Reverse Lookup Failed)	United States	[  ]	[  ]	[  ]	[  ]
Message Headers:	Received: from bentgen.net (unknown [66.23.212.50])
     by mailscanner.domain (Postfix) with ESMTP id 8A5273F2A1
     for <info@.com>; Tue, 11 Apr 2017 01:03:14 +0200 (CEST)
MIME-Version: 1.0
To: <info@.com>
cbsspecialreport@bentgen.net	[Add to Whitelist | Add to Blacklist]
To:	info@.com
Anti-Virus/Dangerous Content Protection
Virus:	 N
Blocked File:	 N
Other Infection:	 N
SpamAssassin
Spam:	 N   Action(s): store, deliver, header, "X-Spam-Status:No"
High Score Spam:	 N
SpamAssassin Spam:	 N
Listed in RBL:	 N
SPAM Whitelisted:	 N
SPAM Blacklisted:	 N
SpamAssassin Autolearn:	 N
SpamAssassin Score:	2.39
Spam Report:
Score	Matching Rule	Description
1.10	DCC_CHECK
0.00	HTML_FONT_LOW_CONTRAST
0.00	HTML_MESSAGE
1.27	RDNS_NONE
0.01	T_SPF_HELO_PERMERROR
Relay Information:
Date/Time	Relayed by	Relayed to	Delay	Status
11/04/17 01:03:19	mailscanner	web01..nl	00:00:05	sent (250 OK id=1cxiL9-002Xbc-SC)
ovizii
Re: Spam
Post by ovizii »
Is this a default EFA install or VM or did you tinker with spamassassin settings already?
BliXem
Re: Spam
Post by BliXem »
Default install script of yours on a clean CentOS 6 version.
Re: Spam
Did this build correctly? What's interesting with this spam report is that some key spamassassin checks appear to be missing. i.e. pyzor, razor, and rbls.
BliXem
Re: Spam
Post by BliXem »
Yes, I don't see any errors. How can I fix this issue? Can you login to check this?
BliXem
Re: Spam
Post by BliXem »
Looks like RBL doesnt work either.
Also when I select 4 4) DNS Recursion : ENABLED
en enabled it again I see this error:
Stopping unbound: [ OK ]
Starting unbound: Apr 12 12:25:17 unbound[2449:0] warning: increased limit(open files) from 1024 to 8266
[ OK ]
[EFA] Recursion is now ENABLED
Edit 2: Fixed it with: ulimit -n 8290
BliXem
Re: Spam
Post by BliXem »
Another one:
Received on:	12/04/17 11:50:49
Received from:
66.23.212.146	[Add to Whitelist | Add to Blacklist]
Received Via:
66.23.212.146	alert.detilmy.us	United States	[  ]	[  ]	[  ]	[  ]
Message Headers:	Received: from diampics.com (unknown [66.23.212.146])
     by mailscanner (Postfix) with ESMTP id B13083F264
     for <info@.com>; Wed, 12 Apr 2017 11:50:40 +0200 (CEST)
Date: Wed, 12 Apr 2017 04:28:29 -0500
MIME-Version: 1.0
Subject: Drink this & lose 24 LLBs before the end of Year.
To: <info@.com>
Message-ID: <1Q8nGYV-EzVKg9UioZZ7_6ih-yK2Q1kZxuTGs6YwbVM.ahGDD1sW7-0oZd8RXBHzBb1ggZk4vFMLLd4UcQcLuW8@diampics.com>
boundary="------------06545278357732615870673"
grumpy@diampics.com	[Add to Whitelist | Add to Blacklist]
To:	info@.com
Virus:	 N
Blocked File:	 N
Other Infection:	 N
SpamAssassin
High Score Spam:	 N
Listed in RBL:	 N
SPAM Whitelisted:	 N
SPAM Blacklisted:	 N
SpamAssassin Score:	3.96
Spam Report:
1.10	DCC_CHECK
0.00	HTML_MESSAGE
1.27	RDNS_NONE
1.56	SUBJECT_DIET
0.01	T_REMOTE_IMAGE
Before update I did yum update and then your update.
Edit: this is working: [root@mailscanner ~]# host 2.0.0.127.b.barracudacentral.org
2.0.0.127.b.barracudacentral.org has address 127.0.0.2
Don't know how I can test the RBL function or other functions?
Well: RBL is working btw:
Apr 12 12:56:53 mailscanner postfix/smtpd[11127]: NOQUEUE: reject: RCPT from unknown[171.245.197.143]: 554 5.7.1 Service unavailable; Client host [171.245.197.143] blocked using zen.spamhaus.org; https://www.spamhaus.org/sbl/query/SBLCSS / https://www.spamhaus.org/query/ip/171.245.197.143; from=<Cole742@michaelalouisa.com> to=<msn@.nl> proto=ESMTP helo=<[171.245.197.143]>
Apr 12 12:56:54 mailscanner postfix/smtpd[11127]: disconnect from unknown[171.245.197.143] ehlo=1 mail=1 rcpt=0/1 data=0/1 quit=1 commands=3/5
Re: Spam
What do you get when you run a spammassassin and mailscanner lint test?
BliXem
Re: Spam
Post by BliXem »
Can you show me the commands?
BliXem
Re: Spam
Post by BliXem »
[root@mailscanner ~]# spamassassin --lint
[root@mailscanner ~]# MailScanner –-lint
Nothing to show? Is this a good sign?
Re: Spam
What if you run them in the MailWatch GUI under tools?
BliXem
Re: Spam
Post by BliXem »
Mailscanner Lint:
Trying to setlogsock(unix)	0
Reading configuration file /etc/MailScanner/MailScanner.conf	0.13632
Reading configuration file /etc/MailScanner/conf.d/README	0.01701
Read 1501 hostnames from the phishing whitelist	0.04419
Read 15235 hostnames from the phishing blacklists	0.1257
Config: calling custom init function SQLBlacklist	0.01838
MailWatch: Starting up MailWatch SQL Blacklist	0.00043
MailWatch: Read 3 blacklist entries	0.02788
Config: calling custom init function MailWatchLogging	6.0E-5
MailWatch: Started MailWatch SQL Logging child	0.02731
Config: calling custom init function SQLWhitelist	6.0E-5
MailWatch: Starting up MailWatch SQL Whitelist	2.0E-5
MailWatch: Read 1 whitelist entries	0.00515
Checking version numbers...	4.0E-5
Version number in MailScanner.conf (5.0.3) is correct.	2.0E-5
ERROR: The "envelope_sender_header" in your spamassassin.conf	0.00051
ERROR: is not correct, it should match X--MailScanner-From	2.0E-5
MailScanner setting GID to (89)	2.0E-5
MailScanner setting UID to (89)	1.0E-5
Checking for SpamAssassin errors (if you use it)...	1.0E-5
Using SpamAssassin results cache	0.17872
Connected to SpamAssassin cache database	0.00153
SpamAssassin reported no errors.	3.86275
Connected to Processing Attempts Database	0.00221
Created Processing Attempts Database successfully	0.00076
There are 0 messages in the Processing Attempts Database	0.00031
Using locktype = posix	0.00086
MailScanner.conf says "Virus Scanners = clamd"	0.00032
Found these virus scanners installed: clamavmodule, clamd	0.20573
===========================================================================	0.00021
Filename Checks: Windows/DOS Executable (1 eicar.com)	0.01666
Other Checks: Found 1 problems	0.01368
Virus and Content Scanning: Starting	6.0E-5
Clamd::INFECTED:: Eicar-Test-Signature :: ./1/eicar.com	0.02919
Virus Scanning: Clamd found 1 infections	0.10037
Infected message 1 came from 10.1.1.1	8.0E-5
Virus Scanning: Found 1 viruses	1.0E-5
===========================================================================	1.0E-5
Virus Scanner test reports:	0.00012
Clamd said "eicar.com was infected: Eicar-Test-Signature"	2.0E-5
If any of your virus scanners (clamavmodule,clamd)	5.0E-5
are not listed there, you should check that they are installed correctly	4.0E-5
and that MailScanner is finding them correctly via its virus.scanners.conf.	3.0E-5
Config: calling custom end function SQLBlacklist	1.0E-5
MailWatch: Closing down MailWatch SQL Blacklist	2.0E-5
Config: calling custom end function MailWatchLogging	1.0E-5
Config: calling custom end function SQLWhitelist	0.00018
MailWatch: Closing down MailWatch SQL Whitelist	0.00013
Finish - Total Time	5.57334
BliXem
Re: Spam
Post by BliXem »
Spamassassin comes in 3 times. To much letters :-)
Apr 12 16:44:53.925 [10443] dbg: logger: adding facilities: all	0
Apr 12 16:44:53.926 [10443] dbg: logger: logging level is DBG	0.00019
Apr 12 16:44:53.926 [10443] dbg: generic: SpamAssassin version 3.4.1	0.00016
Apr 12 16:44:53.926 [10443] dbg: generic: Perl 5.010001, PREFIX=/usr, DEF_RULES_DIR=/usr/share/spamassassin, LOCAL_RULES_DIR=/etc/mail/spamassassin, LOCAL_STATE_DIR=/var/lib/spamassassin	0.00015
Apr 12 16:44:53.926 [10443] dbg: config: timing enabled	0.00015
Apr 12 16:44:53.929 [10443] dbg: config: score set 0 chosen.	0.00316
Apr 12 16:44:53.932 [10443] dbg: util: running in taint mode? yes	0.00266
Apr 12 16:44:53.932 [10443] dbg: util: taint mode: deleting unsafe environment variables, resetting PATH	0.00012
Apr 12 16:44:53.932 [10443] dbg: util: PATH included '/sbin', keeping	0.00023
Apr 12 16:44:53.932 [10443] dbg: util: PATH included '/usr/sbin', keeping	0.00016
Apr 12 16:44:53.933 [10443] dbg: util: PATH included '/bin', keeping	0.00015
Apr 12 16:44:53.933 [10443] dbg: util: PATH included '/usr/bin', keeping	0.00018
Apr 12 16:44:53.933 [10443] dbg: util: final PATH set to: /sbin:/usr/sbin:/bin:/usr/bin	0.00061
Apr 12 16:44:54.351 [10443] dbg: diag: perl platform: 5.010001 linux	0.4181
Apr 12 16:44:54.352 [10443] dbg: diag: [...] module installed: Digest::SHA1, version 2.12	0.00032
Apr 12 16:44:54.352 [10443] dbg: diag: [...] module installed: HTML::Parser, version 3.64	0.00023
Apr 12 16:44:54.352 [10443] dbg: diag: [...] module installed: Net::DNS, version 0.65	0.0002
Apr 12 16:44:54.352 [10443] dbg: diag: [...] module installed: NetAddr::IP, version 4.078	0.00025
Apr 12 16:44:54.353 [10443] dbg: diag: [...] module installed: Time::HiRes, version 1.9721	0.00021
Apr 12 16:44:54.353 [10443] dbg: diag: [...] module installed: Archive::Tar, version 1.58	0.00023
Apr 12 16:44:54.353 [10443] dbg: diag: [...] module installed: IO::Zlib, version 1.09	0.00018
Apr 12 16:44:54.353 [10443] dbg: diag: [...] module installed: Digest::SHA1, version 2.12	0.0002
Apr 12 16:44:54.353 [10443] dbg: diag: [...] module installed: MIME::Base64, version 3.08	0.00025
Apr 12 16:44:54.354 [10443] dbg: diag: [...] module installed: DB_File, version 1.835	0.00025
Apr 12 16:44:54.354 [10443] dbg: diag: [...] module installed: Net::SMTP, version 3.08	0.00023
Apr 12 16:44:54.354 [10443] dbg: diag: [...] module installed: Mail::SPF, version v2.009	0.00019
Apr 12 16:44:54.354 [10443] dbg: diag: [...] module installed: Geo::IP, version 1.45	0.0002
Apr 12 16:44:54.355 [10443] dbg: diag: [...] module installed: Net::CIDR::Lite, version 0.21	0.0002
Apr 12 16:44:54.355 [10443] dbg: diag: [...] module installed: Razor2::Client::Agent, version 2.84	0.00025
Apr 12 16:44:54.355 [10443] dbg: diag: [...] module installed: IO::Socket::IP, version 0.37	0.0002
Apr 12 16:44:54.355 [10443] dbg: diag: [...] module installed: IO::Socket::INET6, version 2.72	0.00017
Apr 12 16:44:54.355 [10443] dbg: diag: [...] module installed: IO::Socket::SSL, version 1.31	0.00023
Apr 12 16:44:54.356 [10443] dbg: diag: [...] module installed: Compress::Zlib, version 2.021	0.00018
Apr 12 16:44:54.356 [10443] dbg: diag: [...] module installed: Mail::DKIM, version 0.37	0.00021
Apr 12 16:44:54.356 [10443] dbg: diag: [...] module installed: DBI, version 1.609	0.00017
Apr 12 16:44:54.356 [10443] dbg: diag: [...] module installed: Getopt::Long, version 2.38	0.00017
Apr 12 16:44:54.356 [10443] dbg: diag: [...] module installed: LWP::UserAgent, version 5.833	0.00017
Apr 12 16:44:54.357 [10443] dbg: diag: [...] module installed: HTTP::Date, version 5.831	0.00017
Apr 12 16:44:54.357 [10443] dbg: diag: [...] module installed: Encode::Detect::Detector, version 1.01	0.00032
Apr 12 16:44:54.357 [10443] dbg: diag: [...] module installed: Net::Patricia, version 1.22	0.00022
Apr 12 16:44:54.357 [10443] dbg: diag: [...] module installed: Net::DNS::Nameserver, version 749	0.00018
Apr 12 16:44:54.358 [10443] dbg: ignore: using a test message to lint rules	0.0003
Apr 12 16:44:54.358 [10443] dbg: config: using "/etc/mail/spamassassin" for site rules pre files	0.00071
Apr 12 16:44:54.359 [10443] dbg: config: read file /etc/mail/spamassassin/init.pre	0.00086
Apr 12 16:44:54.359 [10443] dbg: config: read file /etc/mail/spamassassin/v310.pre	0.00038
Apr 12 16:44:54.360 [10443] dbg: config: read file /etc/mail/spamassassin/v312.pre	0.00047
Apr 12 16:44:54.360 [10443] dbg: config: read file /etc/mail/spamassassin/v320.pre	0.00037
Apr 12 16:44:54.361 [10443] dbg: config: read file /etc/mail/spamassassin/v330.pre	0.0004
Apr 12 16:44:54.361 [10443] dbg: config: read file /etc/mail/spamassassin/v340.pre	0.00036
Apr 12 16:44:54.361 [10443] dbg: config: read file /etc/mail/spamassassin/v341.pre	0.00033
Apr 12 16:44:54.362 [10443] dbg: config: using "/var/lib/spamassassin/3.004001" for sys rules pre files	0.00062
Apr 12 16:44:54.363 [10443] dbg: config: using "/var/lib/spamassassin/3.004001" for default rules dir	0.00053
Apr 12 16:44:54.363 [10443] dbg: config: read file /var/lib/spamassassin/3.004001/updates_spamassassin_org.cf	0.00053
Apr 12 16:44:54.364 [10443] dbg: config: using "/etc/mail/spamassassin" for site rules dir	0.00051
Apr 12 16:44:54.364 [10443] dbg: config: read file /etc/mail/spamassassin/ImageCerberusPLG.cf	0.0007
Apr 12 16:44:54.368 [10443] dbg: config: read file /etc/mail/spamassassin/KAM.cf	0.00396
Apr 12 16:44:54.369 [10443] dbg: config: read file /etc/mail/spamassassin/MailScanner.cf	0.00116
Apr 12 16:44:54.370 [10443] dbg: config: read file /etc/mail/spamassassin/local.cf	0.00043
Apr 12 16:44:54.370 [10443] dbg: config: read file /etc/mail/spamassassin/mailscanner.cf	0.00034
Apr 12 16:44:54.371 [10443] dbg: config: read file /etc/mail/spamassassin/pdfinfo.cf	0.00057
Apr 12 16:44:54.373 [10443] dbg: config: using "/etc/MailScanner/spamassassin.conf" for user prefs file	0.00231
Apr 12 16:44:54.373 [10443] dbg: config: read file /etc/MailScanner/spamassassin.conf	0.00034
Apr 12 16:44:54.393 [10443] dbg: plugin: loading Mail::SpamAssassin::Plugin::URIDNSBL from @INC	0.01991
Apr 12 16:44:54.403 [10443] dbg: plugin: loading Mail::SpamAssassin::Plugin::Hashcash from @INC	0.00971
Apr 12 16:44:54.407 [10443] dbg: plugin: loading Mail::SpamAssassin::Plugin::SPF from @INC	0.00421
Apr 12 16:44:54.415 [10443] dbg: plugin: loading Mail::SpamAssassin::Plugin::DCC from @INC	0.0075
Apr 12 16:44:54.426 [10443] dbg: dcc: local tests only, disabling DCC	0.0112
Apr 12 16:44:54.427 [10443] dbg: plugin: loading Mail::SpamAssassin::Plugin::Pyzor from @INC	0.0006
Apr 12 16:44:54.432 [10443] dbg: pyzor: local tests only, disabling Pyzor	0.00533
Apr 12 16:44:54.432 [10443] dbg: plugin: loading Mail::SpamAssassin::Plugin::Razor2 from @INC	0.00051
Apr 12 16:44:54.437 [10443] dbg: razor2: local tests only, skipping Razor	0.00511
Apr 12 16:44:54.438 [10443] dbg: plugin: loading Mail::SpamAssassin::Plugin::SpamCop from @INC	0.00053
Apr 12 16:44:54.444 [10443] dbg: reporter: local tests only, disabling SpamCop	0.00556
Apr 12 16:44:54.444 [10443] dbg: plugin: loading Mail::SpamAssassin::Plugin::AWL from @INC	0.00055
Apr 12 16:44:54.454 [10443] dbg: plugin: loading Mail::SpamAssassin::Plugin::AutoLearnThreshold from @INC	0.0095
Apr 12 16:44:54.457 [10443] dbg: plugin: loading Mail::SpamAssassin::Plugin::WhiteListSubject from @INC	0.00317
Apr 12 16:44:54.460 [10443] dbg: plugin: loading Mail::SpamAssassin::Plugin::MIMEHeader from @INC	0.00296
Apr 12 16:44:54.463 [10443] dbg: plugin: loading Mail::SpamAssassin::Plugin::ReplaceTags from @INC	0.00299
Apr 12 16:44:54.466 [10443] dbg: plugin: loading Mail::SpamAssassin::Plugin::DKIM from @INC	0.0036
Apr 12 16:44:54.479 [10443] dbg: plugin: loading Mail::SpamAssassin::Plugin::Check from @INC	0.01261
Apr 12 16:44:54.496 [10443] dbg: plugin: loading Mail::SpamAssassin::Plugin::HTTPSMismatch from @INC	0.01682
Apr 12 16:44:54.498 [10443] dbg: plugin: loading Mail::SpamAssassin::Plugin::URIDetail from @INC	0.00215
Apr 12 16:44:54.502 [10443] dbg: plugin: loading Mail::SpamAssassin::Plugin::Bayes from @INC	0.0038
Apr 12 16:44:54.523 [10443] dbg: plugin: loading Mail::SpamAssassin::Plugin::BodyEval from @INC	0.0218
Apr 12 16:44:54.529 [10443] dbg: plugin: loading Mail::SpamAssassin::Plugin::DNSEval from @INC	0.00509
Apr 12 16:44:54.534 [10443] dbg: plugin: loading Mail::SpamAssassin::Plugin::HTMLEval from @INC	0.00578
Apr 12 16:44:54.539 [10443] dbg: plugin: loading Mail::SpamAssassin::Plugin::HeaderEval from @INC	0.00502
Apr 12 16:44:54.555 [10443] dbg: plugin: loading Mail::SpamAssassin::Plugin::MIMEEval from @INC	0.01534
Apr 12 16:44:54.563 [10443] dbg: plugin: loading Mail::SpamAssassin::Plugin::RelayEval from @INC	0.00817
Apr 12 16:44:54.568 [10443] dbg: plugin: loading Mail::SpamAssassin::Plugin::URIEval from @INC	0.00547
Apr 12 16:44:54.570 [10443] dbg: plugin: loading Mail::SpamAssassin::Plugin::WLBLEval from @INC	0.0021
Apr 12 16:44:54.577 [10443] dbg: plugin: loading Mail::SpamAssassin::Plugin::VBounce from @INC	0.00655
Apr 12 16:44:54.580 [10443] dbg: plugin: loading Mail::SpamAssassin::Plugin::Rule2XSBody from @INC	0.00255
Apr 12 16:44:54.586 [10443] dbg: plugin: loading Mail::SpamAssassin::Plugin::ImageInfo from @INC	0.00604
Apr 12 16:44:54.591 [10443] dbg: plugin: loading Mail::SpamAssassin::Plugin::FreeMail from @INC	0.00588
Apr 12 16:44:54.597 [10443] dbg: plugin: loading Mail::SpamAssassin::Plugin::AskDNS from @INC	0.00548
Apr 12 16:44:54.601 [10443] dbg: plugin: loading Mail::SpamAssassin::Plugin::TxRep from @INC	0.00409
Apr 12 16:44:54.609 [10443] dbg: TxRep: new object created	0.0076
Apr 12 16:44:54.609 [10443] dbg: plugin: loading Mail::SpamAssassin::Plugin::PDFInfo from @INC	0.00059
Apr 12 16:44:54.615 [10443] dbg: config: fixed relative path: /var/lib/spamassassin/3.004001/updates_spamassassin_org/10_default_prefs.cf	0.00582
Apr 12 16:44:54.615 [10443] dbg: config: using "/var/lib/spamassassin/3.004001/updates_spamassassin_org/10_default_prefs.cf" for included file	0.00016
Apr 12 16:44:54.616 [10443] dbg: config: read file /var/lib/spamassassin/3.004001/updates_spamassassin_org/10_default_prefs.cf	0.00029
Apr 12 16:44:54.631 [10443] dbg: config: fixed relative path: /var/lib/spamassassin/3.004001/updates_spamassassin_org/10_hasbase.cf	0.01594
Apr 12 16:44:54.632 [10443] dbg: config: using "/var/lib/spamassassin/3.004001/updates_spamassassin_org/10_hasbase.cf" for included file	0.0003
Apr 12 16:44:54.632 [10443] dbg: config: read file /var/lib/spamassassin/3.004001/updates_spamassassin_org/10_hasbase.cf	0.00043
Apr 12 16:44:54.635 [10443] dbg: config: fixed relative path: /var/lib/spamassassin/3.004001/updates_spamassassin_org/20_advance_fee.cf	0.00278
Apr 12 16:44:54.635 [10443] dbg: config: using "/var/lib/spamassassin/3.004001/updates_spamassassin_org/20_advance_fee.cf" for included file	0.00015
Apr 12 16:44:54.635 [10443] dbg: config: read file /var/lib/spamassassin/3.004001/updates_spamassassin_org/20_advance_fee.cf	0.00026
Apr 12 16:44:54.640 [10443] dbg: config: fixed relative path: /var/lib/spamassassin/3.004001/updates_spamassassin_org/20_aux_tlds.cf	0.00412
Apr 12 16:44:54.640 [10443] dbg: config: using "/var/lib/spamassassin/3.004001/updates_spamassassin_org/20_aux_tlds.cf" for included file	0.00015
Apr 12 16:44:54.640 [10443] dbg: config: read file /var/lib/spamassassin/3.004001/updates_spamassassin_org/20_aux_tlds.cf	0.00053
Apr 12 16:44:54.643 [10443] dbg: config: cleared tld lists	0.00281
Apr 12 16:44:54.644 [10443] dbg: config: added tld list - xn--11b4c3d xn--1qqw23a xn--30rr7y xn--3bst00m xn--3ds443g xn--3e0b707e	0.00049
Apr 12 16:44:54.644 [10443] dbg: config: added tld list - xn--3pxu8k xn--42c2d9a xn--45brj9c xn--45q11c xn--4gbrim xn--55qw42g xn--55qx5d	0.00018
Apr 12 16:44:54.644 [10443] dbg: config: added tld list - xn--6frz82g xn--6qq986b3xl xn--80adxhks xn--80ao21a xn--80asehdb xn--80aswg	0.00016
Apr 12 16:44:54.644 [10443] dbg: config: added tld list - xn--90a3ac xn--90ais xn--9dbq2a xn--9et52u xn--b4w605ferd xn--c1avg xn--c2br7g	0.00019
Apr 12 16:44:54.644 [10443] dbg: config: added tld list - xn--cg4bki xn--clchc0ea0b2g2a9gcd xn--czr694b xn--czrs0t xn--czru2d xn--d1acj3b	0.00016
Apr 12 16:44:54.644 [10443] dbg: config: added tld list - xn--d1alf xn--eckvdtc9d xn--efvy88h xn--estv75g xn--fhbei xn--fiq228c5hs	0.00016
Apr 12 16:44:54.645 [10443] dbg: config: added tld list - xn--fiq64b xn--fiqs8s xn--fiqz9s xn--fjq720a xn--flw351e xn--fpcrj9c3d	0.00023
Apr 12 16:44:54.645 [10443] dbg: config: added tld list - xn--fzc2c9e2c xn--gecrj9c xn--h2brj9c xn--hxt814e xn--i1b6b1a6a2e xn--imr513n	0.00018
Apr 12 16:44:54.645 [10443] dbg: config: added tld list - xn--io0a7i xn--j1aef xn--j1amh xn--j6w193g xn--jlq61u9w7b xn--kcrx77d1x4a	0.00018
Apr 12 16:44:54.645 [10443] dbg: config: added tld list - xn--kprw13d xn--kpry57d xn--kpu716f xn--kput3i xn--l1acc xn--lgbbat1ad8j	0.00031
Apr 12 16:44:54.645 [10443] dbg: config: added tld list - xn--mgb9awbf xn--mgba3a3ejt xn--mgba3a4f16a xn--mgbaam7a8h xn--mgbab2bd	0.00016
Apr 12 16:44:54.646 [10443] dbg: config: added tld list - xn--mgbayh7gpa xn--mgbb9fbpob xn--mgbbh1a71e xn--mgbc0a9azcg xn--mgberp4a5d4ar	0.00015
Apr 12 16:44:54.646 [10443] dbg: config: added tld list - xn--mgbpl2fh xn--mgbt3dhd xn--mgbtx2b xn--mgbx4cd0ab xn--mk1bu44c xn--mxtq1m	0.00015
Apr 12 16:44:54.646 [10443] dbg: config: added tld list - xn--ngbc5azd xn--ngbe9e0a xn--node xn--nqv7f xn--nqv7fs00ema xn--nyqy26a	0.00015
Apr 12 16:44:54.646 [10443] dbg: config: added tld list - xn--o3cw4h xn--ogbpf8fl xn--p1acf xn--p1ai xn--pbt977c xn--pgbs0dh xn--pssy2u	0.00024
Apr 12 16:44:54.646 [10443] dbg: config: added tld list - xn--q9jyb4c xn--qcka1pmc xn--qxam xn--rhqv96g xn--s9brj9c xn--ses554g	0.00017
Apr 12 16:44:54.647 [10443] dbg: config: added tld list - xn--t60b56a xn--tckwe xn--unup4y xn--vermgensberater-ctb	0.00016
Apr 12 16:44:54.647 [10443] dbg: config: added tld list - xn--vermgensberatung-pwb xn--vhquv xn--vuq861b xn--wgbh1c xn--wgbl6a	0.00016
Apr 12 16:44:54.647 [10443] dbg: config: added tld list - xn--xhq521b xn--xkc2al3hye2a xn--xkc2dl3a5ee0h xn--y9a3aq xn--yfro4i67o	0.00018
Apr 12 16:44:54.647 [10443] dbg: config: added tld list - xn--ygbi2ammx xn--zfr164b	0.00017
Apr 12 16:44:54.647 [10443] dbg: config: added tld list - aaa aarp abarth abb abbott abbvie abc able abogado abudhabi ac academy	0.0002
Apr 12 16:44:54.647 [10443] dbg: config: added tld list - accenture accountant accountants aco active actor ad adac ads adult ae aeg aero	0.00017
Apr 12 16:44:54.648 [10443] dbg: config: added tld list - aetna af afamilycompany afl ag agakhan agency ai aig aigo airbus airforce	0.00021
Apr 12 16:44:54.648 [10443] dbg: config: added tld list - airtel akdn al alfaromeo alibaba alipay allfinanz allstate ally alsace alstom	0.00018
Apr 12 16:44:54.648 [10443] dbg: config: added tld list - am americanexpress americanfamily amex amfam amica amsterdam analytics android	0.00016
Apr 12 16:44:54.648 [10443] dbg: config: added tld list - anquan anz ao aol apartments app apple aq aquarelle ar aramco archi army arpa	0.0002
Apr 12 16:44:54.648 [10443] dbg: config: added tld list - art arte as asda asia associates at athleta attorney au auction audi audible	0.00016
Apr 12 16:44:54.648 [10443] dbg: config: added tld list - audio auspost author auto autos avianca aw aws ax axa az azure ba baby baidu	0.00017
Apr 12 16:44:54.649 [10443] dbg: config: added tld list - banamex bananarepublic band bank bar barcelona barclaycard barclays barefoot	0.0002
Apr 12 16:44:54.649 [10443] dbg: config: added tld list - bargains baseball basketball bauhaus bayern bb bbc bbt bbva bcg bcn bd be beats	0.00017
Apr 12 16:44:54.649 [10443] dbg: config: added tld list - beauty beer bentley berlin best bestbuy bet bf bg bh bharti bi bible bid bike	0.00019
Apr 12 16:44:54.649 [10443] dbg: config: added tld list - bing bingo bio biz bj black blackfriday blanco blockbuster blog bloomberg blue	0.00018
Apr 12 16:44:54.649 [10443] dbg: config: added tld list - bm bms bmw bn bnl bnpparibas bo boats boehringer bofa bom bond boo book booking	0.00017
Apr 12 16:44:54.650 [10443] dbg: config: added tld list - boots bosch bostik bot boutique br bradesco bridgestone broadway broker brother	0.00016
Apr 12 16:44:54.650 [10443] dbg: config: added tld list - brussels bs bt budapest bugatti build builders business buy buzz bv bw by bz	0.00017
Apr 12 16:44:54.650 [10443] dbg: config: added tld list - bzh ca cab cafe cal call calvinklein cam camera camp cancerresearch canon	0.00017
Apr 12 16:44:54.650 [10443] dbg: config: added tld list - capetown capital capitalone car caravan cards care career careers cars cartier	0.00021
Apr 12 16:44:54.650 [10443] dbg: config: added tld list - casa case caseih cash casino cat catering cba cbn cbre cbs cc cd ceb center ceo	0.00019
Apr 12 16:44:54.650 [10443] dbg: config: added tld list - cern cf cfa cfd cg ch chanel channel chase chat cheap chintai chloe christmas	0.00017
Apr 12 16:44:54.651 [10443] dbg: config: added tld list - chrome chrysler church ci cipriani circle cisco citadel citi citic city	0.00016
Apr 12 16:44:54.651 [10443] dbg: config: added tld list - cityeats ck cl claims cleaning click clinic clinique clothing cloud club	0.00028
Apr 12 16:44:54.651 [10443] dbg: config: added tld list - clubmed cm cn co coach codes coffee college cologne com comcast commbank	0.00019
Apr 12 16:44:54.651 [10443] dbg: config: added tld list - community company compare computer comsec condos construction consulting	0.00016
Apr 12 16:44:54.651 [10443] dbg: config: added tld list - contact contractors cooking cookingchannel cool coop corsica country coupon	0.00017
Apr 12 16:44:54.652 [10443] dbg: config: added tld list - coupons courses cr credit creditcard creditunion cricket crown crs cruises csc	0.00016
Apr 12 16:44:54.652 [10443] dbg: config: added tld list - cu cuisinella cv cw cx cy cymru cyou cz dabur dad dance date dating datsun day	0.00017
Apr 12 16:44:54.652 [10443] dbg: config: added tld list - dclk dds de deal dealer deals degree delivery dell deloitte delta democrat	0.00016
Apr 12 16:44:54.652 [10443] dbg: config: added tld list - dental dentist desi design dev dhl diamonds diet digital direct directory	0.00019
Apr 12 16:44:54.652 [10443] dbg: config: added tld list - discount discover dish diy dj dk dm dnp do docs doctor dodge dog doha domains	0.00017
Apr 12 16:44:54.652 [10443] dbg: config: added tld list - dot download drive dtv dubai duck dunlop duns dupont durban dvag dvr dz earth	0.00018
Apr 12 16:44:54.653 [10443] dbg: config: added tld list - eat ec eco edeka edu education ee eg email emerck energy engineer engineering	0.00016
Apr 12 16:44:54.653 [10443] dbg: config: added tld list - enterprises epost epson equipment er ericsson erni es esq estate esurance et eu	0.00016
Apr 12 16:44:54.653 [10443] dbg: config: added tld list - eurovision eus events everbank exchange expert exposed express extraspace fage	0.00022
Apr 12 16:44:54.653 [10443] dbg: config: added tld list - fail fairwinds faith family fan fans farm farmers fashion fast fedex feedback	0.00017
Apr 12 16:44:54.653 [10443] dbg: config: added tld list - ferrari ferrero fi fiat fidelity fido film final finance financial fire	0.00016
Apr 12 16:44:54.653 [10443] dbg: config: added tld list - firestone firmdale fish fishing fit fitness fj fk flickr flights flir florist	0.00016
Apr 12 16:44:54.654 [10443] dbg: config: added tld list - flowers fly fm fo foo foodnetwork football ford forex forsale forum foundation	0.00018
Apr 12 16:44:54.654 [10443] dbg: config: added tld list - fox fr free fresenius frl frogans frontdoor frontier ftr fujitsu fujixerox fund	0.00016
Apr 12 16:44:54.654 [10443] dbg: config: added tld list - furniture futbol fyi ga gal gallery gallo gallup game games gap garden gb gbiz	0.00019
Apr 12 16:44:54.654 [10443] dbg: config: added tld list - gd gdn ge gea gent genting george gf gg ggee gh gi gift gifts gives giving gl	0.00025
Apr 12 16:44:54.654 [10443] dbg: config: added tld list - glade glass gle global globo gm gmail gmbh gmo gmx gn godaddy gold goldpoint	0.00019
Apr 12 16:44:54.655 [10443] dbg: config: added tld list - golf goo goodhands goodyear goog google gop got gov gp gq gr grainger graphics	0.00016
Apr 12 16:44:54.655 [10443] dbg: config: added tld list - gratis green gripe group gs gt gu guardian gucci guge guide guitars guru gw gy	0.00017
Apr 12 16:44:54.655 [10443] dbg: config: added tld list - hamburg hangout haus hbo hdfc hdfcbank health healthcare help helsinki here	0.00016
Apr 12 16:44:54.655 [10443] dbg: config: added tld list - hermes hgtv hiphop hisamitsu hitachi hiv hk hkt hm hn hockey holdings holiday	0.00031
Apr 12 16:44:54.655 [10443] dbg: config: added tld list - homedepot homegoods homes homesense honda honeywell horse host hosting hot	0.00023
Apr 12 16:44:54.656 [10443] dbg: config: added tld list - hoteles hotmail house how hr hsbc ht htc hu hughes hyatt hyundai ibm icbc ice	0.00026
Apr 12 16:44:54.656 [10443] dbg: config: added tld list - icu id ie ieee ifm iinet ikano il im imamat imdb immo immobilien in industries	0.00024
Apr 12 16:44:54.656 [10443] dbg: config: added tld list - infiniti info ing ink institute insurance insure int intel international intuit	0.00023
Apr 12 16:44:54.656 [10443] dbg: config: added tld list - investments io ipiranga iq ir irish is iselect ismaili ist istanbul it itau itv	0.00022
Apr 12 16:44:54.657 [10443] dbg: config: added tld list - iveco iwc jaguar java jcb jcp je jeep jetzt jewelry jlc jll jm jmp jnj jo jobs	0.00021
Apr 12 16:44:54.657 [10443] dbg: config: added tld list - joburg jot joy jp jpmorgan jprs juegos juniper kaufen kddi ke kerryhotels	0.00022
Apr 12 16:44:54.657 [10443] dbg: config: added tld list - kerrylogistics kerryproperties kfh kg kh ki kia kim kinder kindle kitchen kiwi	0.01184
Apr 12 16:44:54.657 [10443] dbg: config: added tld list - km kn koeln komatsu kosher kp kpmg kpn kr krd kred kuokgroup kw ky kyoto kz la	2.0E-5
Apr 12 16:44:54.657 [10443] dbg: config: added tld list - lacaixa ladbrokes lamborghini lamer lancaster lancia lancome land landrover	2.0E-5
Apr 12 16:44:54.658 [10443] dbg: config: added tld list - lanxess lasalle lat latino latrobe law lawyer lb lc lds lease leclerc lefrak	1.0E-5
Apr 12 16:44:54.658 [10443] dbg: config: added tld list - legal lego lexus lgbt li liaison lidl life lifeinsurance lifestyle lighting	1.0E-5
Apr 12 16:44:54.658 [10443] dbg: config: added tld list - like lilly limited limo lincoln linde link lipsy live living lixil lk loan	1.0E-5
Apr 12 16:44:54.658 [10443] dbg: config: added tld list - loans locker locus loft lol london lotte lotto love lpl lplfinancial lr ls lt	1.0E-5
Apr 12 16:44:54.658 [10443] dbg: config: added tld list - ltd ltda lu lundbeck lupin luxe luxury lv ly ma macys madrid maif maison makeup	1.0E-5
Apr 12 16:44:54.658 [10443] dbg: config: added tld list - man management mango market marketing markets marriott marshalls maserati	2.0E-5
Apr 12 16:44:54.658 [10443] dbg: config: added tld list - mattel mba mc mcd mcdonalds mckinsey md me med media meet melbourne meme	1.0E-5
Apr 12 16:44:54.658 [10443] dbg: config: added tld list - memorial men menu meo metlife mg mh miami microsoft mil mini mint mit	1.0E-5
Apr 12 16:44:54.658 [10443] dbg: config: added tld list - mitsubishi mk ml mlb mls mm mma mn mo mobi mobily moda moe moi mom monash money	1.0E-5
Apr 12 16:44:54.659 [10443] dbg: config: added tld list - monster montblanc mopar mormon mortgage moscow motorcycles mov movie movistar	1.0E-5
Apr 12 16:44:54.659 [10443] dbg: config: added tld list - mp mq mr ms msd mt mtn mtpc mtr mu museum mutual mutuelle mv mw mx my mz na nab	1.0E-5
Apr 12 16:44:54.659 [10443] dbg: config: added tld list - nadex nagoya name nationwide natura navy nba nc ne nec net netbank netflix	1.0E-5
Apr 12 16:44:54.659 [10443] dbg: config: added tld list - network neustar new newholland news next nextdirect nexus nf nfl ng ngo nhk ni	2.0E-5
Apr 12 16:44:54.659 [10443] dbg: config: added tld list - nico nike nikon ninja nissan nissay nl no nokia northwesternmutual norton now	1.0E-5
Apr 12 16:44:54.659 [10443] dbg: config: added tld list - nowruz nowtv np nr nra nrw ntt nu nyc nz obi observer off office okinawa olayan	1.0E-5
Apr 12 16:44:54.659 [10443] dbg: config: added tld list - olayangroup oldnavy ollo om omega one ong onl online onyourside ooo open oracle	1.0E-5
Apr 12 16:44:54.659 [10443] dbg: config: added tld list - orange org organic orientexpress origins osaka otsuka ott ovh pa page	1.0E-5
Apr 12 16:44:54.660 [10443] dbg: config: added tld list - pamperedchef panasonic panerai paris pars partners parts party passagens pay	4.0E-5
Apr 12 16:44:54.660 [10443] dbg: config: added tld list - pccw pe pet pf pfizer pg ph pharmacy philips photo photography photos physio	2.0E-5
Apr 12 16:44:54.660 [10443] dbg: config: added tld list - piaget pics pictet pictures pid pin ping pink pioneer pizza pk pl place play	1.0E-5
Apr 12 16:44:54.660 [10443] dbg: config: added tld list - playstation plumbing plus pm pn pnc pohl poker politie porn post pr pramerica	1.0E-5
Apr 12 16:44:54.660 [10443] dbg: config: added tld list - praxi press prime pro prod productions prof progressive promo properties	1.0E-5
Apr 12 16:44:54.660 [10443] dbg: config: added tld list - property protection pru prudential ps pt pub pw pwc py qa qpon quebec quest qvc	1.0E-5
Apr 12 16:44:54.660 [10443] dbg: config: added tld list - racing radio raid re read realestate realtor realty recipes red redstone	1.0E-5
Apr 12 16:44:54.661 [10443] dbg: config: added tld list - redumbrella rehab reise reisen reit ren rent rentals repair report republican	1.0E-5
Apr 12 16:44:54.661 [10443] dbg: config: added tld list - rest restaurant review reviews rexroth rich richardli ricoh rightathome rio rip	1.0E-5
Apr 12 16:44:54.661 [10443] dbg: config: added tld list - ro rocher rocks rodeo rogers room rs rsvp ru ruhr run rw rwe ryukyu sa saarland	1.0E-5
Apr 12 16:44:54.661 [10443] dbg: config: added tld list - safe safety sakura sale salon samsclub samsung sandvik sandvikcoromant sanofi	1.0E-5
Apr 12 16:44:54.661 [10443] dbg: config: added tld list - sap sapo sarl sas save saxo sb sbi sbs sc sca scb schaeffler schmidt	6.0E-5
Apr 12 16:44:54.661 [10443] dbg: config: added tld list - scholarships school schule schwarz science scjohnson scor scot sd se seat	1.0E-5
Apr 12 16:44:54.661 [10443] dbg: config: added tld list - secure security seek select sener services ses seven sew sex sexy sfr sg sh	1.0E-5
Apr 12 16:44:54.662 [10443] dbg: config: added tld list - shangrila sharp shaw shell shia shiksha shoes shop shopping shouji show	1.0E-5
Apr 12 16:44:54.662 [10443] dbg: config: added tld list - showtime shriram si silk sina singles site sj sk ski skin sky skype sl sling sm	1.0E-5
Apr 12 16:44:54.662 [10443] dbg: config: added tld list - smart smile sn sncf so soccer social softbank software sohu solar solutions	1.0E-5
Apr 12 16:44:54.662 [10443] dbg: config: added tld list - song sony soy space spiegel spot spreadbetting sr srl srt st stada staples star	1.0E-5
Apr 12 16:44:54.662 [10443] dbg: config: added tld list - starhub statebank statefarm statoil stc stcgroup stockholm storage store stream	1.0E-5
Apr 12 16:44:54.662 [10443] dbg: config: added tld list - studio study style su sucks supplies supply support surf surgery suzuki sv	1.0E-5
Apr 12 16:44:54.662 [10443] dbg: config: added tld list - swatch swiftcover swiss sx sy sydney symantec systems sz tab taipei talk taobao	1.0E-5
Apr 12 16:44:54.662 [10443] dbg: config: added tld list - target tatamotors tatar tattoo tax taxi tc tci td tdk team tech technology tel	2.0E-5
Apr 12 16:44:54.662 [10443] dbg: config: added tld list - telecity telefonica temasek tennis teva tf tg th thd theater theatre tiaa	2.0E-5
Apr 12 16:44:54.663 [10443] dbg: config: added tld list - tickets tienda tiffany tips tires tirol tj tjmaxx tjx tk tkmaxx tl tm tmall tn	2.0E-5
Apr 12 16:44:54.663 [10443] dbg: config: added tld list - to today tokyo tools top toray toshiba total tours town toyota toys tr trade	2.0E-5
Apr 12 16:44:54.663 [10443] dbg: config: added tld list - trading training travel travelchannel travelers travelersinsurance trust trv tt	2.0E-5
Apr 12 16:44:54.663 [10443] dbg: config: added tld list - tube tui tunes tushu tv tvs tw tz ua ubank ubs uconnect ug uk unicom university	1.0E-5
Apr 12 16:44:54.663 [10443] dbg: config: added tld list - uno uol ups us uy uz va vacations vana vanguard vc ve vegas ventures verisign	1.0E-5
Apr 12 16:44:54.663 [10443] dbg: config: added tld list - versicherung vet vg vi viajes video vig viking villas vin vip virgin visa	1.0E-5
Apr 12 16:44:54.663 [10443] dbg: config: added tld list - vision vista vistaprint viva vivo vlaanderen vn vodka volkswagen volvo vote	2.0E-5
Apr 12 16:44:54.663 [10443] dbg: config: added tld list - voting voto voyage vu vuelos wales walmart walter wang wanggou warman watch	1.0E-5
Apr 12 16:44:54.663 [10443] dbg: config: added tld list - watches weather weatherchannel webcam weber website wed wedding weibo weir wf	1.0E-5
Apr 12 16:44:54.664 [10443] dbg: config: added tld list - whoswho wien wiki williamhill win windows wine winners wme wolterskluwer	1.0E-5
Apr 12 16:44:54.664 [10443] dbg: config: added tld list - woodside work works world wow ws wtc wtf xbox xerox xfinity xihuan xin xperia	1.0E-5
Apr 12 16:44:54.664 [10443] dbg: config: added tld list - xxx xyz yachts yahoo yamaxun yandex ye yodobashi yoga yokohama you youtube yt	1.0E-5
Apr 12 16:44:54.664 [10443] dbg: config: added tld list - yun za zappos zara zero zip zippo zm zone zuerich zw	1.0E-5
Apr 12 16:44:54.676 [10443] dbg: config: fixed relative path: /var/lib/spamassassin/3.004001/updates_spamassassin_org/20_body_tests.cf	0.00634
Apr 12 16:44:54.676 [10443] dbg: config: using "/var/lib/spamassassin/3.004001/updates_spamassassin_org/20_body_tests.cf" for included file	0.00016
Apr 12 16:44:54.676 [10443] dbg: config: read file /var/lib/spamassassin/3.004001/updates_spamassassin_org/20_body_tests.cf	0.00024
Apr 12 16:44:54.680 [10443] dbg: config: fixed relative path: /var/lib/spamassassin/3.004001/updates_spamassassin_org/20_compensate.cf	0.00419
Apr 12 16:44:54.681 [10443] dbg: config: using "/var/lib/spamassassin/3.004001/updates_spamassassin_org/20_compensate.cf" for included file	0.00013
Apr 12 16:44:54.681 [10443] dbg: config: read file /var/lib/spamassassin/3.004001/updates_spamassassin_org/20_compensate.cf	0.00024
Apr 12 16:44:54.682 [10443] dbg: config: fixed relative path: /var/lib/spamassassin/3.004001/updates_spamassassin_org/20_dnsbl_tests.cf	0.001
Apr 12 16:44:54.682 [10443] dbg: config: using "/var/lib/spamassassin/3.004001/updates_spamassassin_org/20_dnsbl_tests.cf" for included file	0.00025
Apr 12 16:44:54.682 [10443] dbg: config: read file /var/lib/spamassassin/3.004001/updates_spamassassin_org/20_dnsbl_tests.cf	0.00023
Apr 12 16:44:54.688 [10443] dbg: config: fixed relative path: /var/lib/spamassassin/3.004001/updates_spamassassin_org/20_drugs.cf	0.00542
Apr 12 16:44:54.688 [10443] dbg: config: using "/var/lib/spamassassin/3.004001/updates_spamassassin_org/20_drugs.cf" for included file	0.00021
Apr 12 16:44:54.688 [10443] dbg: config: read file /var/lib/spamassassin/3.004001/updates_spamassassin_org/20_drugs.cf	0.00037
Apr 12 16:44:54.699 [10443] dbg: config: fixed relative path: /var/lib/spamassassin/3.004001/updates_spamassassin_org/20_dynrdns.cf	0.01085
Apr 12 16:44:54.699 [10443] dbg: config: using "/var/lib/spamassassin/3.004001/updates_spamassassin_org/20_dynrdns.cf" for included file	0.00019
Apr 12 16:44:54.700 [10443] dbg: config: read file /var/lib/spamassassin/3.004001/updates_spamassassin_org/20_dynrdns.cf	0.00037
Apr 12 16:44:54.706 [10443] dbg: config: fixed relative path: /var/lib/spamassassin/3.004001/updates_spamassassin_org/20_fake_helo_tests.cf	0.00617
Apr 12 16:44:54.706 [10443] dbg: config: using "/var/lib/spamassassin/3.004001/updates_spamassassin_org/20_fake_helo_tests.cf" for included file	0.00017
Apr 12 16:44:54.706 [10443] dbg: config: read file /var/lib/spamassassin/3.004001/updates_spamassassin_org/20_fake_helo_tests.cf	0.00036
Apr 12 16:44:54.710 [10443] dbg: config: fixed relative path: /var/lib/spamassassin/3.004001/updates_spamassassin_org/20_freemail.cf	0.00342
Apr 12 16:44:54.710 [10443] dbg: config: using "/var/lib/spamassassin/3.004001/updates_spamassassin_org/20_freemail.cf" for included file	0.00016
Apr 12 16:44:54.710 [10443] dbg: config: read file /var/lib/spamassassin/3.004001/updates_spamassassin_org/20_freemail.cf	0.00022
Apr 12 16:44:54.712 [10443] dbg: config: fixed relative path: /var/lib/spamassassin/3.004001/updates_spamassassin_org/20_freemail_domains.cf	0.00211
Apr 12 16:44:54.712 [10443] dbg: config: using "/var/lib/spamassassin/3.004001/updates_spamassassin_org/20_freemail_domains.cf" for included file	0.00013
Apr 12 16:44:54.713 [10443] dbg: config: read file /var/lib/spamassassin/3.004001/updates_spamassassin_org/20_freemail_domains.cf	0.0005
Apr 12 16:44:54.714 [10443] dbg: plugin: Mail::SpamAssassin::Plugin::FreeMail=HASH(0x3cea828) implements 'parse_config', priority 0	0.0012
Apr 12 16:44:54.739 [10443] dbg: config: fixed relative path: /var/lib/spamassassin/3.004001/updates_spamassassin_org/20_freemail_mailcom_domains.cf	0.02476
Apr 12 16:44:54.739 [10443] dbg: config: using "/var/lib/spamassassin/3.004001/updates_spamassassin_org/20_freemail_mailcom_domains.cf" for included file	0.0002
Apr 12 16:44:54.739 [10443] dbg: config: read file /var/lib/spamassassin/3.004001/updates_spamassassin_org/20_freemail_mailcom_domains.cf	0.00033
Apr 12 16:44:54.741 [10443] dbg: config: fixed relative path: /var/lib/spamassassin/3.004001/updates_spamassassin_org/20_head_tests.cf	0.00196
Apr 12 16:44:54.742 [10443] dbg: config: using "/var/lib/spamassassin/3.004001/updates_spamassassin_org/20_head_tests.cf" for included file	0.00013
Apr 12 16:44:54.742 [10443] dbg: config: read file /var/lib/spamassassin/3.004001/updates_spamassassin_org/20_head_tests.cf	0.00057
Apr 12 16:44:54.764 [10443] dbg: config: fixed relative path: /var/lib/spamassassin/3.004001/updates_spamassassin_org/20_html_tests.cf	0.02182
Apr 12 16:44:54.764 [10443] dbg: config: using "/var/lib/spamassassin/3.004001/updates_spamassassin_org/20_html_tests.cf" for included file	0.00018
Apr 12 16:44:54.764 [10443] dbg: config: read file /var/lib/spamassassin/3.004001/updates_spamassassin_org/20_html_tests.cf	0.00035
Apr 12 16:44:54.773 [10443] dbg: config: fixed relative path: /var/lib/spamassassin/3.004001/updates_spamassassin_org/20_imageinfo.cf	0.00831
Apr 12 16:44:54.773 [10443] dbg: config: using "/var/lib/spamassassin/3.004001/updates_spamassassin_org/20_imageinfo.cf" for included file	0.00018
Apr 12 16:44:54.773 [10443] dbg: config: read file /var/lib/spamassassin/3.004001/updates_spamassassin_org/20_imageinfo.cf	0.00027
Apr 12 16:44:54.776 [10443] dbg: config: fixed relative path: /var/lib/spamassassin/3.004001/updates_spamassassin_org/20_mailspike.cf	0.00281
Apr 12 16:44:54.776 [10443] dbg: config: using "/var/lib/spamassassin/3.004001/updates_spamassassin_org/20_mailspike.cf" for included file	0.00016
Apr 12 16:44:54.777 [10443] dbg: config: read file /var/lib/spamassassin/3.004001/updates_spamassassin_org/20_mailspike.cf	0.00042
Apr 12 16:44:54.779 [10443] dbg: config: fixed relative path: /var/lib/spamassassin/3.004001/updates_spamassassin_org/20_meta_tests.cf	0.00265
Apr 12 16:44:54.779 [10443] dbg: config: using "/var/lib/spamassassin/3.004001/updates_spamassassin_org/20_meta_tests.cf" for included file	0.00016
Apr 12 16:44:54.780 [10443] dbg: config: read file /var/lib/spamassassin/3.004001/updates_spamassassin_org/20_meta_tests.cf	0.00027
Apr 12 16:44:54.782 [10443] dbg: config: fixed relative path: /var/lib/spamassassin/3.004001/updates_spamassassin_org/20_net_tests.cf	0.00277
Apr 12 16:44:54.783 [10443] dbg: config: using "/var/lib/spamassassin/3.004001/updates_spamassassin_org/20_net_tests.cf" for included file	0.00017
Apr 12 16:44:54.783 [10443] dbg: config: read file /var/lib/spamassassin/3.004001/updates_spamassassin_org/20_net_tests.cf	0.00027
Apr 12 16:44:54.784 [10443] dbg: config: fixed relative path: /var/lib/spamassassin/3.004001/updates_spamassassin_org/20_pdfinfo.cf	0.00098
Apr 12 16:44:54.784 [10443] dbg: config: using "/var/lib/spamassassin/3.004001/updates_spamassassin_org/20_pdfinfo.cf" for included file	0.00014
Apr 12 16:44:54.784 [10443] dbg: config: read file /var/lib/spamassassin/3.004001/updates_spamassassin_org/20_pdfinfo.cf	0.00022
Apr 12 16:44:54.788 [10443] dbg: config: fixed relative path: /var/lib/spamassassin/3.004001/updates_spamassassin_org/20_phrases.cf	0.00333
Apr 12 16:44:54.788 [10443] dbg: config: using "/var/lib/spamassassin/3.004001/updates_spamassassin_org/20_phrases.cf" for included file	0.00016
Apr 12 16:44:54.788 [10443] dbg: config: read file /var/lib/spamassassin/3.004001/updates_spamassassin_org/20_phrases.cf	0.00032
Apr 12 16:44:54.795 [10443] dbg: config: fixed relative path: /var/lib/spamassassin/3.004001/updates_spamassassin_org/20_porn.cf	0.00726
Apr 12 16:44:54.795 [10443] dbg: config: using "/var/lib/spamassassin/3.004001/updates_spamassassin_org/20_porn.cf" for included file	0.00017
Apr 12 16:44:54.796 [10443] dbg: config: read file /var/lib/spamassassin/3.004001/updates_spamassassin_org/20_porn.cf	0.00031
Apr 12 16:44:54.797 [10443] dbg: config: fixed relative path: /var/lib/spamassassin/3.004001/updates_spamassassin_org/20_ratware.cf	0.00115
Apr 12 16:44:54.797 [10443] dbg: config: using "/var/lib/spamassassin/3.004001/updates_spamassassin_org/20_ratware.cf" for included file	0.00013
Apr 12 16:44:54.797 [10443] dbg: config: read file /var/lib/spamassassin/3.004001/updates_spamassassin_org/20_ratware.cf	0.00025
Apr 12 16:44:54.810 [10443] dbg: config: fixed relative path: /var/lib/spamassassin/3.004001/updates_spamassassin_org/20_uri_tests.cf	0.01298
Apr 12 16:44:54.810 [10443] dbg: config: using "/var/lib/spamassassin/3.004001/updates_spamassassin_org/20_uri_tests.cf" for included file	0.00019
Apr 12 16:44:54.811 [10443] dbg: config: read file /var/lib/spamassassin/3.004001/updates_spamassassin_org/20_uri_tests.cf	0.00026
Apr 12 16:44:54.815 [10443] dbg: config: fixed relative path: /var/lib/spamassassin/3.004001/updates_spamassassin_org/20_vbounce.cf	0.00406
Apr 12 16:44:54.815 [10443] dbg: config: using "/var/lib/spamassassin/3.004001/updates_spamassassin_org/20_vbounce.cf" for included file	0.00014
Apr 12 16:44:54.815 [10443] dbg: config: read file /var/lib/spamassassin/3.004001/updates_spamassassin_org/20_vbounce.cf	0.00022
Apr 12 16:44:54.830 [10443] dbg: config: fixed relative path: /var/lib/spamassassin/3.004001/updates_spamassassin_org/23_bayes.cf	0.0145
Apr 12 16:44:54.830 [10443] dbg: config: using "/var/lib/spamassassin/3.004001/updates_spamassassin_org/23_bayes.cf" for included file	0.00019
Apr 12 16:44:54.830 [10443] dbg: config: read file /var/lib/spamassassin/3.004001/updates_spamassassin_org/23_bayes.cf	0.00023
Apr 12 16:44:54.832 [10443] dbg: config: fixed relative path: /var/lib/spamassassin/3.004001/updates_spamassassin_org/25_accessdb.cf	0.00193
Apr 12 16:44:54.832 [10443] dbg: config: using "/var/lib/spamassassin/3.004001/updates_spamassassin_org/25_accessdb.cf" for included file	0.00013
Apr 12 16:44:54.832 [10443] dbg: config: read file /var/lib/spamassassin/3.004001/updates_spamassassin_org/25_accessdb.cf	0.00019
Apr 12 16:44:54.833 [10443] dbg: config: fixed relative path: /var/lib/spamassassin/3.004001/updates_spamassassin_org/25_antivirus.cf	0.0007
Apr 12 16:44:54.833 [10443] dbg: config: using "/var/lib/spamassassin/3.004001/updates_spamassassin_org/25_antivirus.cf" for included file	0.00013
Apr 12 16:44:54.833 [10443] dbg: config: read file /var/lib/spamassassin/3.004001/updates_spamassassin_org/25_antivirus.cf	0.00018
Apr 12 16:44:54.834 [10443] dbg: config: fixed relative path: /var/lib/spamassassin/3.004001/updates_spamassassin_org/25_asn.cf	0.00064
Apr 12 16:44:54.834 [10443] dbg: config: using "/var/lib/spamassassin/3.004001/updates_spamassassin_org/25_asn.cf" for included file	0.00013
Apr 12 16:44:54.834 [10443] dbg: config: read file /var/lib/spamassassin/3.004001/updates_spamassassin_org/25_asn.cf	0.0002
Apr 12 16:44:54.835 [10443] dbg: config: fixed relative path: /var/lib/spamassassin/3.004001/updates_spamassassin_org/25_dcc.cf	0.00052
Apr 12 16:44:54.835 [10443] dbg: config: using "/var/lib/spamassassin/3.004001/updates_spamassassin_org/25_dcc.cf" for included file	0.00016
Apr 12 16:44:54.835 [10443] dbg: config: read file /var/lib/spamassassin/3.004001/updates_spamassassin_org/25_dcc.cf	0.00021
Apr 12 16:44:54.837 [10443] dbg: config: fixed relative path: /var/lib/spamassassin/3.004001/updates_spamassassin_org/25_dkim.cf	0.00145
Apr 12 16:44:54.837 [10443] dbg: config: using "/var/lib/spamassassin/3.004001/updates_spamassassin_org/25_dkim.cf" for included file	0.00016
Apr 12 16:44:54.837 [10443] dbg: config: read file /var/lib/spamassassin/3.004001/updates_spamassassin_org/25_dkim.cf	0.0002
Apr 12 16:44:54.840 [10443] dbg: config: fixed relative path: /var/lib/spamassassin/3.004001/updates_spamassassin_org/25_hashcash.cf	0.0032
Apr 12 16:44:54.840 [10443] dbg: config: using "/var/lib/spamassassin/3.004001/updates_spamassassin_org/25_hashcash.cf" for included file	0.00014
Apr 12 16:44:54.841 [10443] dbg: config: read file /var/lib/spamassassin/3.004001/updates_spamassassin_org/25_hashcash.cf	0.00019
Apr 12 16:44:54.842 [10443] dbg: config: fixed relative path: /var/lib/spamassassin/3.004001/updates_spamassassin_org/25_pyzor.cf	0.00162
Apr 12 16:44:54.842 [10443] dbg: config: using "/var/lib/spamassassin/3.004001/updates_spamassassin_org/25_pyzor.cf" for included file	0.00015
Apr 12 16:44:54.842 [10443] dbg: config: read file /var/lib/spamassassin/3.004001/updates_spamassassin_org/25_pyzor.cf	0.00019
Apr 12 16:44:54.843 [10443] dbg: config: fixed relative path: /var/lib/spamassassin/3.004001/updates_spamassassin_org/25_razor2.cf	0.00066
Apr 12 16:44:54.843 [10443] dbg: config: using "/var/lib/spamassassin/3.004001/updates_spamassassin_org/25_razor2.cf" for included file	0.00013
Apr 12 16:44:54.843 [10443] dbg: config: read file /var/lib/spamassassin/3.004001/updates_spamassassin_org/25_razor2.cf	0.00019
Apr 12 16:44:54.845 [10443] dbg: config: fixed relative path: /var/lib/spamassassin/3.004001/updates_spamassassin_org/25_replace.cf	0.00133
Apr 12 16:44:54.845 [10443] dbg: config: using "/var/lib/spamassassin/3.004001/updates_spamassassin_org/25_replace.cf" for included file	0.00013
Apr 12 16:44:54.845 [10443] dbg: config: read file /var/lib/spamassassin/3.004001/updates_spamassassin_org/25_replace.cf	0.0002
Apr 12 16:44:54.852 [10443] dbg: config: fixed relative path: /var/lib/spamassassin/3.004001/updates_spamassassin_org/25_spf.cf	0.00724
Apr 12 16:44:54.853 [10443] dbg: config: using "/var/lib/spamassassin/3.004001/updates_spamassassin_org/25_spf.cf" for included file	0.00014
Apr 12 16:44:54.853 [10443] dbg: config: read file /var/lib/spamassassin/3.004001/updates_spamassassin_org/25_spf.cf	0.00022
Apr 12 16:44:54.856 [10443] dbg: config: fixed relative path: /var/lib/spamassassin/3.004001/updates_spamassassin_org/25_textcat.cf	0.00349
Apr 12 16:44:54.856 [10443] dbg: config: using "/var/lib/spamassassin/3.004001/updates_spamassassin_org/25_textcat.cf" for included file	0.00014
Apr 12 16:44:54.857 [10443] dbg: config: read file /var/lib/spamassassin/3.004001/updates_spamassassin_org/25_textcat.cf	0.00019
Apr 12 16:44:54.857 [10443] dbg: config: fixed relative path: /var/lib/spamassassin/3.004001/updates_spamassassin_org/25_uribl.cf	0.0006
Apr 12 16:44:54.857 [10443] dbg: config: using "/var/lib/spamassassin/3.004001/updates_spamassassin_org/25_uribl.cf" for included file	0.00013
Apr 12 16:44:54.858 [10443] dbg: config: read file /var/lib/spamassassin/3.004001/updates_spamassassin_org/25_uribl.cf	0.00037
Apr 12 16:44:54.865 [10443] dbg: config: fixed relative path: /var/lib/spamassassin/3.004001/updates_spamassassin_org/30_text_de.cf	0.00726
Apr 12 16:44:54.865 [10443] dbg: config: using "/var/lib/spamassassin/3.004001/updates_spamassassin_org/30_text_de.cf" for included file	0.00014
Apr 12 16:44:54.865 [10443] dbg: config: read file /var/lib/spamassassin/3.004001/updates_spamassassin_org/30_text_de.cf	0.00035
Apr 12 16:44:54.869 [10443] dbg: config: fixed relative path: /var/lib/spamassassin/3.004001/updates_spamassassin_org/30_text_fr.cf	0.00387
Apr 12 16:44:54.869 [10443] dbg: config: using "/var/lib/spamassassin/3.004001/updates_spamassassin_org/30_text_fr.cf" for included file	0.00013
Apr 12 16:44:54.870 [10443] dbg: config: read file /var/lib/spamassassin/3.004001/updates_spamassassin_org/30_text_fr.cf	0.00023
Apr 12 16:44:54.872 [10443] dbg: config: fixed relative path: /var/lib/spamassassin/3.004001/updates_spamassassin_org/30_text_it.cf	0.00276
Apr 12 16:44:54.873 [10443] dbg: config: using "/var/lib/spamassassin/3.004001/updates_spamassassin_org/30_text_it.cf" for included file	0.00013
Apr 12 16:44:54.873 [10443] dbg: config: read file /var/lib/spamassassin/3.004001/updates_spamassassin_org/30_text_it.cf	0.00021
Apr 12 16:44:54.873 [10443] dbg: config: fixed relative path: /var/lib/spamassassin/3.004001/updates_spamassassin_org/30_text_nl.cf	0.00039
Apr 12 16:44:54.873 [10443] dbg: config: using "/var/lib/spamassassin/3.004001/updates_spamassassin_org/30_text_nl.cf" for included file	0.00013
Apr 12 16:44:54.873 [10443] dbg: config: read file /var/lib/spamassassin/3.004001/updates_spamassassin_org/30_text_nl.cf	0.00023
Apr 12 16:44:54.876 [10443] dbg: config: fixed relative path: /var/lib/spamassassin/3.004001/updates_spamassassin_org/30_text_pl.cf	0.00269
Apr 12 16:44:54.876 [10443] dbg: config: using "/var/lib/spamassassin/3.004001/updates_spamassassin_org/30_text_pl.cf" for included file	0.00013
Apr 12 16:44:54.877 [10443] dbg: config: read file /var/lib/spamassassin/3.004001/updates_spamassassin_org/30_text_pl.cf	0.00022
Apr 12 16:44:54.880 [10443] dbg: config: fixed relative path: /var/lib/spamassassin/3.004001/updates_spamassassin_org/30_text_pt_br.cf	0.00369
Apr 12 16:44:54.880 [10443] dbg: config: using "/var/lib/spamassassin/3.004001/updates_spamassassin_org/30_text_pt_br.cf" for included file	0.00017
Apr 12 16:44:54.881 [10443] dbg: config: read file /var/lib/spamassassin/3.004001/updates_spamassassin_org/30_text_pt_br.cf	0.00079
Apr 12 16:44:54.887 [10443] dbg: config: fixed relative path: /var/lib/spamassassin/3.004001/updates_spamassassin_org/50_scores.cf	0.00609
Apr 12 16:44:54.887 [10443] dbg: config: using "/var/lib/spamassassin/3.004001/updates_spamassassin_org/50_scores.cf" for included file	0.00017
Apr 12 16:44:54.888 [10443] dbg: config: read file /var/lib/spamassassin/3.004001/updates_spamassassin_org/50_scores.cf	0.00061
Apr 12 16:44:54.928 [10443] dbg: config: fixed relative path: /var/lib/spamassassin/3.004001/updates_spamassassin_org/60_adsp_override_dkim.cf	0.0402
Apr 12 16:44:54.928 [10443] dbg: config: using "/var/lib/spamassassin/3.004001/updates_spamassassin_org/60_adsp_override_dkim.cf" for included file	0.00018
Apr 12 16:44:54.929 [10443] dbg: config: read file /var/lib/spamassassin/3.004001/updates_spamassassin_org/60_adsp_override_dkim.cf	0.00047
Apr 12 16:44:54.932 [10443] dbg: config: fixed relative path: /var/lib/spamassassin/3.004001/updates_spamassassin_org/60_awl.cf	0.00344
Apr 12 16:44:54.932 [10443] dbg: config: using "/var/lib/spamassassin/3.004001/updates_spamassassin_org/60_awl.cf" for included file	0.00014
Apr 12 16:44:54.933 [10443] dbg: config: read file /var/lib/spamassassin/3.004001/updates_spamassassin_org/60_awl.cf	0.00033
Apr 12 16:44:54.934 [10443] dbg: config: fixed relative path: /var/lib/spamassassin/3.004001/updates_spamassassin_org/60_shortcircuit.cf	0.00103
Apr 12 16:44:54.934 [10443] dbg: config: using "/var/lib/spamassassin/3.004001/updates_spamassassin_org/60_shortcircuit.cf" for included file	0.00013
Apr 12 16:44:54.934 [10443] dbg: config: read file /var/lib/spamassassin/3.004001/updates_spamassassin_org/60_shortcircuit.cf	0.0002
Apr 12 16:44:54.935 [10443] dbg: config: fixed relative path: /var/lib/spamassassin/3.004001/updates_spamassassin_org/60_txrep.cf	0.00084
Apr 12 16:44:54.935 [10443] dbg: config: using "/var/lib/spamassassin/3.004001/updates_spamassassin_org/60_txrep.cf" for included file	0.0003
Apr 12 16:44:54.936 [10443] dbg: config: read file /var/lib/spamassassin/3.004001/updates_spamassassin_org/60_txrep.cf	0.0002
Apr 12 16:44:54.936 [10443] dbg: config: fixed relative path: /var/lib/spamassassin/3.004001/updates_spamassassin_org/60_whitelist.cf	0.0008
Apr 12 16:44:54.936 [10443] dbg: config: using "/var/lib/spamassassin/3.004001/updates_spamassassin_org/60_whitelist.cf" for included file	0.00013
Apr 12 16:44:54.937 [10443] dbg: config: read file /var/lib/spamassassin/3.004001/updates_spamassassin_org/60_whitelist.cf	0.00022
Apr 12 16:44:54.940 [10443] dbg: config: fixed relative path: /var/lib/spamassassin/3.004001/updates_spamassassin_org/60_whitelist_dkim.cf	0.00377
Apr 12 16:44:54.941 [10443] dbg: config: using "/var/lib/spamassassin/3.004001/updates_spamassassin_org/60_whitelist_dkim.cf" for included file	0.00013
Apr 12 16:44:54.941 [10443] dbg: config: read file /var/lib/spamassassin/3.004001/updates_spamassassin_org/60_whitelist_dkim.cf	0.00026
Apr 12 16:44:54.945 [10443] dbg: config: fixed relative path: /var/lib/spamassassin/3.004001/updates_spamassassin_org/60_whitelist_spf.cf	0.00439
Apr 12 16:44:54.945 [10443] dbg: config: using "/var/lib/spamassassin/3.004001/updates_spamassassin_org/60_whitelist_spf.cf" for included file	0.00014
Apr 12 16:44:54.946 [10443] dbg: config: read file /var/lib/spamassassin/3.004001/updates_spamassassin_org/60_whitelist_spf.cf	0.00023
Apr 12 16:44:54.948 [10443] dbg: config: fixed relative path: /var/lib/spamassassin/3.004001/updates_spamassassin_org/60_whitelist_subject.cf	0.00199
Apr 12 16:44:54.948 [10443] dbg: config: using "/var/lib/spamassassin/3.004001/updates_spamassassin_org/60_whitelist_subject.cf" for included file	0.00015
Apr 12 16:44:54.948 [10443] dbg: config: read file /var/lib/spamassassin/3.004001/updates_spamassassin_org/60_whitelist_subject.cf	0.0002
Apr 12 16:44:54.949 [10443] dbg: config: fixed relative path: /var/lib/spamassassin/3.004001/updates_spamassassin_org/72_active.cf	0.0008
Apr 12 16:44:54.949 [10443] dbg: config: using "/var/lib/spamassassin/3.004001/updates_spamassassin_org/72_active.cf" for included file	0.00013
Apr 12 16:44:54.951 [10443] dbg: config: read file /var/lib/spamassassin/3.004001/updates_spamassassin_org/72_active.cf	0.0024
Apr 12 16:44:55.179 [10443] dbg: config: fixed relative path: /var/lib/spamassassin/3.004001/updates_spamassassin_org/72_scores.cf	0.22806
BliXem
Re: Spam
Post by BliXem »
2:
Apr 12 16:44:55.180 [10443] dbg: config: using "/var/lib/spamassassin/3.004001/updates_spamassassin_org/72_scores.cf" for included file	0.00019
Apr 12 16:44:55.180 [10443] dbg: config: read file /var/lib/spamassassin/3.004001/updates_spamassassin_org/72_scores.cf	0.0003
Apr 12 16:44:55.186 [10443] dbg: config: fixed relative path: /var/lib/spamassassin/3.004001/updates_spamassassin_org/73_sandbox_manual_scores.cf	0.0065
Apr 12 16:44:55.186 [10443] dbg: config: using "/var/lib/spamassassin/3.004001/updates_spamassassin_org/73_sandbox_manual_scores.cf" for included file	0.00016
Apr 12 16:44:55.187 [10443] dbg: config: read file /var/lib/spamassassin/3.004001/updates_spamassassin_org/73_sandbox_manual_scores.cf	0.00021
Apr 12 16:44:55.187 [10443] dbg: config: fixed relative path: /var/lib/spamassassin/3.004001/updates_spamassassin_org/local.cf	0.00079
Apr 12 16:44:55.188 [10443] dbg: config: using "/var/lib/spamassassin/3.004001/updates_spamassassin_org/local.cf" for included file	0.00013
Apr 12 16:44:55.188 [10443] dbg: config: read file /var/lib/spamassassin/3.004001/updates_spamassassin_org/local.cf	0.00022
Apr 12 16:44:55.189 [10443] dbg: config: fixed relative path: /var/lib/spamassassin/3.004001/updates_spamassassin_org/regression_tests.cf	0.00077
Apr 12 16:44:55.189 [10443] dbg: config: using "/var/lib/spamassassin/3.004001/updates_spamassassin_org/regression_tests.cf" for included file	0.00015
Apr 12 16:44:55.189 [10443] dbg: config: read file /var/lib/spamassassin/3.004001/updates_spamassassin_org/regression_tests.cf	0.0002
Apr 12 16:44:55.190 [10443] dbg: plugin: loading ImageCerberusPLG from /usr/share/perl5/vendor_perl/Mail/SpamAssassin/Plugin/ImageCerberusPLG.pm	0.00105
Apr 12 16:44:55.192 [10443] dbg: PLG-ImageCerberus: : new:: register_eval_rule	0.00164
Apr 12 16:44:55.585 [10443] dbg: config: warning: score set for non-existent rule HELO_LH_HOME	0.39336
Apr 12 16:44:55.585 [10443] dbg: config: warning: score set for non-existent rule FILL_THIS_FORM_FRAUD_PHISH	0.00048
Apr 12 16:44:55.586 [10443] dbg: config: warning: score set for non-existent rule FILL_THIS_FORM_LONG	0.00055
Apr 12 16:44:55.586 [10443] dbg: config: warning: score set for non-existent rule FILL_THIS_FORM_LOAN	0.00014
Apr 12 16:44:55.587 [10443] dbg: config: warning: score set for non-existent rule URI_OBFU_WWW	0.00112
Apr 12 16:44:55.606 [10443] dbg: config: warning: no description set for RCVD_FORGED_WROTE2	0.01919
Apr 12 16:44:55.607 [10443] dbg: config: warning: no description set for FSL_FAKE_HOTMAIL_RVCD	0.00082
Apr 12 16:44:55.609 [10443] dbg: config: warning: no description set for FROM_MISSP_SPF_FAIL	0.00149
Apr 12 16:44:55.610 [10443] dbg: config: warning: no description set for FAKE_REPLY_C	0.00144
Apr 12 16:44:55.610 [10443] dbg: config: warning: no description set for MID_DEGREES	0.0003
Apr 12 16:44:55.612 [10443] dbg: config: warning: no description set for FSL_INTERIA_ABUSE	0.00191
Apr 12 16:44:55.614 [10443] dbg: config: warning: no description set for STOX_AND_PRICE	0.00144
Apr 12 16:44:55.614 [10443] dbg: config: warning: no description set for LONG_TERM_PRICE	0.00017
Apr 12 16:44:55.617 [10443] dbg: config: warning: no description set for DKIM_POLICY_SIGNSOME	0.0027
Apr 12 16:44:55.618 [10443] dbg: config: warning: no description set for MSGID_DOLLARS_RANDOM	0.00101
Apr 12 16:44:55.618 [10443] dbg: config: warning: no description set for DKIM_POLICY_SIGNALL	0.00066
Apr 12 16:44:55.620 [10443] dbg: config: warning: no description set for RCVD_IN_MSPIKE_ZBI	0.00111
Apr 12 16:44:55.620 [10443] dbg: config: warning: no description set for HTTPS_HTTP_MISMATCH	0.0003
Apr 12 16:44:55.621 [10443] dbg: config: warning: no description set for ImageCerberusPLG2	0.00074
Apr 12 16:44:55.621 [10443] dbg: config: warning: no description set for HTML_TITLE_SUBJ_DIFF	0.00031
Apr 12 16:44:55.621 [10443] dbg: config: warning: no description set for DKIM_POLICY_TESTING	0.00023
Apr 12 16:44:55.623 [10443] dbg: config: warning: no description set for FSL_HELO_DEVICE	0.00193
Apr 12 16:44:55.624 [10443] dbg: config: warning: no description set for GEO_QUERY_STRING	0.00128
Apr 12 16:44:55.626 [10443] dbg: config: warning: no description set for THEBAT_UNREG	0.00177
Apr 12 16:44:55.627 [10443] dbg: config: warning: no description set for HELO_OEM	0.00123
Apr 12 16:44:55.628 [10443] dbg: config: warning: no description set for KB_RATWARE_OUTLOOK_16	0.00059
Apr 12 16:44:55.628 [10443] dbg: config: warning: no description set for X_MAILER_CME_6543_MSN	0.00036
Apr 12 16:44:55.629 [10443] dbg: config: warning: no description set for ImageCerberusPLG3	0.00057
Apr 12 16:44:55.629 [10443] dbg: config: warning: no description set for CTYPE_001C_A	0.00023
Apr 12 16:44:55.631 [10443] dbg: config: warning: no description set for KB_DATE_CONTAINS_TAB	0.00154
Apr 12 16:44:55.631 [10443] dbg: config: warning: no description set for CBJ_GiveMeABreak	0.00065
Apr 12 16:44:55.631 [10443] dbg: config: warning: no description set for HK_SCAM_N2	0.00019
Apr 12 16:44:55.632 [10443] dbg: config: warning: no description set for HELO_LOCALHOST	0.00032
Apr 12 16:44:55.633 [10443] dbg: config: warning: no description set for JM_I_FEEL_LUCKY	0.00116
Apr 12 16:44:55.634 [10443] dbg: config: warning: no description set for JM_TORA_XM	0.00102
Apr 12 16:44:55.635 [10443] dbg: config: warning: no description set for JM_RCVD_QMAILV1	0.00065
Apr 12 16:44:55.635 [10443] dbg: config: warning: no description set for KAM_IFRAME	0.0005
Apr 12 16:44:55.635 [10443] dbg: config: warning: no description set for STOX_REPLY_TYPE	0.00034
Apr 12 16:44:55.637 [10443] dbg: config: warning: no description set for BUG6152_INVALID_DATE_TZ_ABSURD	0.0013
Apr 12 16:44:55.637 [10443] dbg: config: warning: no description set for ImageCerberusPLG4	0.00022
Apr 12 16:44:55.638 [10443] dbg: config: warning: no description set for LOTTERY_PH_004470	0.00146
Apr 12 16:44:55.641 [10443] dbg: config: warning: no description set for DCC_REPUT_13_19	0.00285
Apr 12 16:44:55.645 [10443] dbg: config: warning: no description set for KAM_RPTR_SUSPECT	0.00355
Apr 12 16:44:55.645 [10443] dbg: config: warning: no description set for KB_RATWARE_MSGID	0.00042
Apr 12 16:44:55.646 [10443] dbg: config: warning: no description set for ImageCerberusPLG5	0.0004
Apr 12 16:44:55.646 [10443] dbg: config: warning: no description set for KAM_RAPTOR	0.00089
Apr 12 16:44:55.647 [10443] dbg: config: warning: no description set for MIME_BOUND_EQ_REL	0.00056
Apr 12 16:44:55.649 [10443] dbg: config: warning: no description set for L_SPAM_TOOL_13	0.00251
Apr 12 16:44:55.650 [10443] dbg: config: warning: no description set for KAM_RPTR_FAILED	0.00031
Apr 12 16:44:55.650 [10443] dbg: config: warning: no description set for STOCK_PRICES	0.00054
Apr 12 16:44:55.651 [10443] dbg: config: warning: no description set for SHORT_TERM_PRICE	0.00031
Apr 12 16:44:55.651 [10443] dbg: config: warning: no description set for MULTIPART_ALT_NON_TEXT	0.00068
Apr 12 16:44:55.652 [10443] dbg: config: warning: no description set for KAM_RPTR_PASSED	0.00017
Apr 12 16:44:55.652 [10443] dbg: config: warning: no description set for SB_GIF_AND_NO_URIS	0.00027
Apr 12 16:44:55.652 [10443] dbg: config: warning: no description set for STOX_REPLY_TYPE_WITHOUT_QUOTES	0.00062
Apr 12 16:44:55.653 [10443] dbg: config: warning: no description set for HIGH_CODEPAGE_URI	0.0002
Apr 12 16:44:55.653 [10443] dbg: config: warning: no description set for TVD_SPACE_RATIO	0.00068
Apr 12 16:44:55.654 [10443] dbg: config: warning: no description set for RCVD_IN_BRBL_LASTEXT	0.00104
Apr 12 16:44:55.655 [10443] dbg: config: warning: no description set for FSL_HELO_BARE_IP_2	0.00021
Apr 12 16:44:55.655 [10443] dbg: config: warning: no description set for KB_RATWARE_OUTLOOK_08	0.0003
Apr 12 16:44:55.656 [10443] dbg: config: warning: no description set for HK_LOTTO	0.00113
Apr 12 16:44:55.657 [10443] dbg: config: warning: no description set for KB_RATWARE_OUTLOOK_MID	0.00049
Apr 12 16:44:55.657 [10443] dbg: config: warning: no description set for TVD_PP_PHISH	0.0002
Apr 12 16:44:55.659 [10443] dbg: config: warning: no description set for KB_FAKED_THE_BAT	0.00268
Apr 12 16:44:55.660 [10443] dbg: config: warning: no description set for CTYPE_001C_B	0.00105
Apr 12 16:44:55.661 [10443] dbg: config: warning: no description set for HELO_LH_LD	0.0007
Apr 12 16:44:55.662 [10443] dbg: config: warning: no description set for BASE64_LENGTH_78_79	0.00071
Apr 12 16:44:55.662 [10443] dbg: config: warning: no description set for DOS_STOCK_BAT2	0.00062
Apr 12 16:44:55.663 [10443] dbg: config: warning: no description set for TVD_RCVD_SPACE_BRACKET	0.00074
Apr 12 16:44:55.666 [10443] dbg: config: warning: no description set for FSL_HELO_BARE_IP_1	0.00276
Apr 12 16:44:55.669 [10443] dbg: config: warning: no description set for LOTTERY_1	0.00276
Apr 12 16:44:55.670 [10443] dbg: config: warning: no description set for DKIM_VERIFIED	0.00111
Apr 12 16:44:55.670 [10443] dbg: config: warning: no description set for FSL_HELO_SETUP	0.00055
Apr 12 16:44:55.671 [10443] dbg: config: warning: no description set for KB_RATWARE_OUTLOOK_12	0.00016
Apr 12 16:44:55.671 [10443] dbg: config: warning: no description set for KB_RATWARE_BOUNDARY	0.00062
Apr 12 16:44:55.672 [10443] dbg: config: warning: no description set for HK_SCAM_N15	0.00099
Apr 12 16:44:55.673 [10443] dbg: config: warning: no description set for ImageCerberusPLG0	0.00041
Apr 12 16:44:55.676 [10443] dbg: config: warning: no description set for FSL_HELO_NON_FQDN_1	0.00299
Apr 12 16:44:55.676 [10443] dbg: config: warning: no description set for TVD_EB_PHISH	0.00021
Apr 12 16:44:55.676 [10443] dbg: config: warning: no description set for MSOE_MID_WRONG_CASE	0.00067
Apr 12 16:44:55.677 [10443] dbg: config: warning: no description set for CURR_PRICE	0.00033
Apr 12 16:44:55.677 [10443] dbg: config: warning: no description set for IMG_DIRECT_TO_MX	0.00017
Apr 12 16:44:55.677 [10443] dbg: config: warning: no description set for HELO_FRIEND	0.00036
Apr 12 16:44:55.679 [10443] dbg: config: warning: no description set for ImageCerberusPLG1	0.00158
Apr 12 16:44:55.679 [10443] dbg: config: warning: no description set for TVD_FINGER_02	0.00024
Apr 12 16:44:55.680 [10443] dbg: config: warning: no description set for REPLYTO_WITHOUT_TO_CC	0.00103
Apr 12 16:44:55.682 [10443] dbg: config: warning: no description set for LIVEFILESTORE	0.00196
Apr 12 16:44:56.667 [10443] dbg: rules: __HAS_LIST_ID merged duplicates: __ML2	0.98488
Apr 12 16:44:56.667 [10443] dbg: rules: __DOS_HAS_MAILING_LIST merged duplicates: __ML4	0.0002
Apr 12 16:44:56.667 [10443] dbg: rules: __AXB_XM_OL_024C2 merged duplicates: __AXB_XM_OL_2600	0.00015
Apr 12 16:44:56.668 [10443] dbg: rules: __JM_REACTOR_DATE merged duplicates: __RATWARE_0_TZ_DATE	0.00014
Apr 12 16:44:56.668 [10443] dbg: rules: __DOS_HAS_ANY_URI merged duplicates: __HAS_ANY_URI __HAS_URI __KAM_SEO7	0.00016
Apr 12 16:44:56.668 [10443] dbg: rules: __HAS_REPLY_TO merged duplicates: __REPLYTO_EXISTS	0.00016
Apr 12 16:44:56.668 [10443] dbg: rules: CTYPE_001C_A merged duplicates: DATE_IN_FUTURE_96_XX	0.00014
Apr 12 16:44:56.668 [10443] dbg: rules: __HAS_XMAIL merged duplicates: __HAS_X_MAILER	0.00014
Apr 12 16:44:56.668 [10443] dbg: rules: __THEBAT_MUA merged duplicates: __XM_THEBAT	0.00015
Apr 12 16:44:56.668 [10443] dbg: rules: __AXB_MO_OL_024C2 merged duplicates: __AXB_MO_OL_2600	0.00014
Apr 12 16:44:56.669 [10443] dbg: rules: CBJ_GiveMeABreak merged duplicates: KAM_IFRAME KAM_RAPTOR KAM_RPTR_FAILED KAM_RPTR_PASSED KAM_RPTR_SUSPECT	0.00017
Apr 12 16:44:56.670 [10443] dbg: config: finish parsing	0.00134
Apr 12 16:44:56.703 [10443] dbg: plugin: Mail::SpamAssassin::Plugin::ReplaceTags=HASH(0x385c0b8) implements 'finish_parsing_end', priority 0	0.03344
Apr 12 16:44:56.704 [10443] dbg: plugin: Mail::SpamAssassin::Plugin::Rule2XSBody=HASH(0x3c7cdd8) implements 'finish_parsing_end', priority 0	0.00031
Apr 12 16:44:56.704 [10443] dbg: plugin: Mail::SpamAssassin::Plugin::FreeMail=HASH(0x3cea828) implements 'finish_parsing_end', priority 0	0.00016
Apr 12 16:44:56.704 [10443] dbg: replacetags: replacing tags	0.00019
Apr 12 16:44:56.726 [10443] dbg: replacetags: done replacing tags	0.02187
Apr 12 16:44:56.726 [10443] dbg: zoom: loading compiled ruleset from /var/lib/spamassassin/compiled/5.010/3.004001	0.0003
Apr 12 16:44:56.742 [10443] dbg: zoom: using compiled ruleset in /var/lib/spamassassin/compiled/5.010/3.004001/Mail/SpamAssassin/CompiledRegexps/body_0.pm for Mail::SpamAssassin::CompiledRegexps::body_0	0.01578
Apr 12 16:44:56.747 [10443] dbg: zoom: skipping rule __KAM_COMPROMISED3, code differs in compiled ruleset	0.00562
Apr 12 16:44:56.751 [10443] dbg: zoom: able to use 1032/1033 'body_0' compiled rules (99.903%)	0.00375
Apr 12 16:44:56.752 [10443] dbg: FreeMail: loaded freemail_domains entries: 2537 normal, 31 wildcard	0.001
Apr 12 16:44:56.759 [10443] dbg: plugin: Mail::SpamAssassin::Plugin::Bayes=HASH(0x39ca788) implements 'learner_new', priority 0	0.00704
Apr 12 16:44:56.760 [10443] dbg: plugin: Mail::SpamAssassin::Plugin::TxRep=HASH(0x3dc8e08) implements 'learner_new', priority 0	0.00039
Apr 12 16:44:56.760 [10443] dbg: bayes: learner_new self=Mail::SpamAssassin::Plugin::Bayes=HASH(0x39ca788), bayes_store_module=Mail::SpamAssassin::BayesStore::SQL	0.00024
Apr 12 16:44:56.771 [10443] dbg: bayes: using username: mailwatch	0.01082
Apr 12 16:44:56.771 [10443] dbg: bayes: learner_new: got store=Mail::SpamAssassin::BayesStore::SQL=HASH(0x400e958)	0.0002
Apr 12 16:44:56.771 [10443] dbg: plugin: Mail::SpamAssassin::Plugin::Bayes=HASH(0x39ca788) implements 'learner_is_scan_available', priority 0	0.00035
Apr 12 16:44:56.789 [10443] dbg: bayes: database connection established	0.01802
Apr 12 16:44:56.790 [10443] dbg: bayes: found bayes db version 3	0.00101
Apr 12 16:44:56.791 [10443] dbg: bayes: Using userid: 1	0.0005
Apr 12 16:44:56.792 [10443] dbg: bayes: not available for scanning, only 99 spam(s) in bayes DB < 200	0.00109
Apr 12 16:44:56.792 [10443] dbg: config: score set 0 chosen.	0.00036
Apr 12 16:44:56.794 [10443] dbg: dns: socket module IO::Socket::IP is available, but no host support for IPv6	0.00134
Apr 12 16:44:56.795 [10443] dbg: dns: EDNS, UDP payload size 4096	0.00091
Apr 12 16:44:56.795 [10443] dbg: dns: servers obtained from Net::DNS : [127.0.0.1]:53	0.00041
Apr 12 16:44:56.795 [10443] dbg: dns: nameservers set to 127.0.0.1	0.00045
Apr 12 16:44:56.796 [10443] dbg: dns: using socket module: IO::Socket::IP version 0.37, forced IPv4	0.00032
Apr 12 16:44:56.796 [10443] dbg: dns: is Net::DNS::Resolver available? yes	0.00014
Apr 12 16:44:56.796 [10443] dbg: dns: Net::DNS version: 0.65	0.00015
Apr 12 16:44:56.796 [10443] dbg: config: time limit 300.0 s	0.00029
Apr 12 16:44:56.797 [10443] dbg: message: main message type: text/plain	0.00079
Apr 12 16:44:56.797 [10443] dbg: message: ---- MIME PARSER START ----	0.0002
Apr 12 16:44:56.798 [10443] dbg: message: parsing normal part	0.0002
Apr 12 16:44:56.798 [10443] dbg: message: storing a body to memory	0.00021
Apr 12 16:44:56.798 [10443] dbg: message: ---- MIME PARSER END ----	0.00012
Apr 12 16:44:56.799 [10443] dbg: check: pms new, time limit in 299.998 s	0.00083
Apr 12 16:44:56.800 [10443] dbg: plugin: Mail::SpamAssassin::Plugin::DNSEval=HASH(0x3ac7638) implements 'check_start', priority 0	0.00088
Apr 12 16:44:56.800 [10443] dbg: plugin: Mail::SpamAssassin::Plugin::Rule2XSBody=HASH(0x3c7cdd8) implements 'check_start', priority 0	0.00029
Apr 12 16:44:56.800 [10443] dbg: plugin: ImageCerberusPLG=HASH(0x4024060) implements 'check_start', priority 0	0.00021
Apr 12 16:44:56.807 [10443] dbg: PLG-ImageCerberus: : check_start:: init score	0.00703
Apr 12 16:44:56.809 [10443] dbg: bayes: database connection established	0.00159
Apr 12 16:44:56.809 [10443] dbg: bayes: found bayes db version 3	0.00017
Apr 12 16:44:56.810 [10443] dbg: bayes: Using userid: 1	0.00086
Apr 12 16:44:56.811 [10443] dbg: bayes: not available for scanning, only 99 spam(s) in bayes DB < 200	0.00126
Apr 12 16:44:56.811 [10443] dbg: plugin: Mail::SpamAssassin::Plugin::Check=HASH(0x398bb68) implements 'check_main', priority 0	0.00048
Apr 12 16:44:56.812 [10443] dbg: config: trusted_networks are not configured; it is recommended that you configure trusted_networks manually	0.00229
Apr 12 16:44:56.814 [10443] dbg: metadata: X-Spam-Relays-Trusted:	0.00065
Apr 12 16:44:56.815 [10443] dbg: metadata: X-Spam-Relays-Untrusted:	0.00019
Apr 12 16:44:56.815 [10443] dbg: metadata: X-Spam-Relays-Internal:	0.00015
Apr 12 16:44:56.815 [10443] dbg: metadata: X-Spam-Relays-External:	0.00012
Apr 12 16:44:56.815 [10443] dbg: plugin: Mail::SpamAssassin::Plugin::AskDNS=HASH(0x3cfbb20) implements 'extract_metadata', priority 0	0.0004
Apr 12 16:44:56.816 [10443] dbg: dns: is DNS available? 0	0.00043
Apr 12 16:44:56.816 [10443] dbg: message: envelope_sender_header 'X-MailScanner-EFA-From' not found in message	0.0004
Apr 12 16:44:56.816 [10443] dbg: check: tagrun - tag AUTHORDOMAIN is now ready, value: compiling.spamassassin.taint.org	0.00024
Apr 12 16:44:56.816 [10443] dbg: check: tagrun - tag RELAYSTRUSTED is now ready, value:	0.00017
Apr 12 16:44:56.817 [10443] dbg: check: tagrun - tag RELAYSUNTRUSTED is now ready, value:	0.00013
Apr 12 16:44:56.817 [10443] dbg: check: tagrun - tag RELAYSINTERNAL is now ready, value:	0.00015
Apr 12 16:44:56.817 [10443] dbg: check: tagrun - tag RELAYSEXTERNAL is now ready, value:	0.00012
Apr 12 16:44:56.817 [10443] dbg: check: tagrun - tag LANGUAGES is now ready, value: <UNDEF>	0.00013
Apr 12 16:44:56.817 [10443] dbg: message: no encoding detected	0.00036
Apr 12 16:44:56.818 [10443] dbg: plugin: Mail::SpamAssassin::Plugin::URIDNSBL=HASH(0x349ece8) implements 'parsed_metadata', priority 0	0.00031
Apr 12 16:44:56.818 [10443] dbg: rules: local tests only, ignoring RBL eval	0.00041
Apr 12 16:44:56.818 [10443] dbg: check: check_main, time limit in 299.978 s	0.00025
Apr 12 16:44:56.821 [10443] dbg: check: running tests for priority: -1000	0.0025
Apr 12 16:44:56.821 [10443] dbg: plugin: Mail::SpamAssassin::Plugin::Rule2XSBody=HASH(0x3c7cdd8) implements 'check_rules_at_priority', priority 0	0.00051
Apr 12 16:44:56.822 [10443] dbg: rules: running one_line_body tests; score so far=0	0.00027
Apr 12 16:44:56.822 [10443] dbg: rules: flush_evalstr (run_generic_tests) compiling 524 chars of Mail::SpamAssassin::Plugin::Check::_one_line_body_tests_neg1000_1	0.00057
Apr 12 16:44:56.823 [10443] dbg: rules: run_generic_tests - compiling eval code: one_line_body, priority -1000	0.00049
Apr 12 16:44:56.823 [10443] dbg: rules: compiled one_line_body tests	0.00026
Apr 12 16:44:56.823 [10443] dbg: plugin: Mail::SpamAssassin::Plugin::Rule2XSBody=HASH(0x3c7cdd8) implements 'run_body_fast_scan', priority 0	0.00053
Apr 12 16:44:56.824 [10443] dbg: rules: running head tests; score so far=0	0.00054
Apr 12 16:44:56.824 [10443] dbg: rules: flush_evalstr (run_generic_tests) compiling 304 chars of Mail::SpamAssassin::Plugin::Check::_head_tests_neg1000_1	0.00036
Apr 12 16:44:56.825 [10443] dbg: rules: run_generic_tests - compiling eval code: head, priority -1000	0.00049
Apr 12 16:44:56.825 [10443] dbg: rules: compiled head tests	0.00023
Apr 12 16:44:56.825 [10443] dbg: rules: running head_eval tests; score so far=0	0.00036
Apr 12 16:44:56.826 [10443] dbg: rules: run_eval_tests - compiling eval code: 9, priority -1000	0.0006
Apr 12 16:44:56.828 [10443] dbg: eval: all '*From' addrs: ignore@compiling.spamassassin.taint.org	0.00152
Apr 12 16:44:56.828 [10443] dbg: eval: all '*To' addrs:	0.00077
Apr 12 16:44:56.829 [10443] dbg: rules: running body tests; score so far=0	0.00066
Apr 12 16:44:56.829 [10443] dbg: rules: flush_evalstr (run_generic_tests) compiling 247 chars of Mail::SpamAssassin::Plugin::Check::_body_tests_neg1000_1	0.00024
Apr 12 16:44:56.830 [10443] dbg: rules: run_generic_tests - compiling eval code: body, priority -1000	0.00032
Apr 12 16:44:56.830 [10443] dbg: rules: compiled body tests	0.00025
Apr 12 16:44:56.830 [10443] dbg: rules: running uri tests; score so far=0	0.00033
Apr 12 16:44:56.830 [10443] dbg: rules: flush_evalstr (run_generic_tests) compiling 245 chars of Mail::SpamAssassin::Plugin::Check::_uri_tests_neg1000_1	0.00024
Apr 12 16:44:56.831 [10443] dbg: rules: run_generic_tests - compiling eval code: uri, priority -1000	0.0003
Apr 12 16:44:56.831 [10443] dbg: rules: compiled uri tests	0.00023
Apr 12 16:44:56.831 [10443] dbg: rules: running rawbody tests; score so far=0	0.00042
Apr 12 16:44:56.832 [10443] dbg: rules: flush_evalstr (run_generic_tests) compiling 253 chars of Mail::SpamAssassin::Plugin::Check::_rawbody_tests_neg1000_1	0.00021
Apr 12 16:44:56.832 [10443] dbg: rules: run_generic_tests - compiling eval code: rawbody, priority -1000	0.00048
Apr 12 16:44:56.832 [10443] dbg: rules: compiled rawbody tests	0.00022
Apr 12 16:44:56.833 [10443] dbg: rules: running full tests; score so far=0	0.0003
Apr 12 16:44:56.833 [10443] dbg: rules: flush_evalstr (run_generic_tests) compiling 282 chars of Mail::SpamAssassin::Plugin::Check::_full_tests_neg1000_1	0.00029
Apr 12 16:44:56.833 [10443] dbg: rules: run_generic_tests - compiling eval code: full, priority -1000	0.00038
Apr 12 16:44:56.833 [10443] dbg: rules: compiled full tests	0.00028
Apr 12 16:44:56.834 [10443] dbg: rules: running meta tests; score so far=0	0.00048
Apr 12 16:44:56.834 [10443] dbg: rules: flush_evalstr (run_generic_tests) compiling 307 chars of Mail::SpamAssassin::Plugin::Check::_meta_tests_neg1000_1	0.00036
Apr 12 16:44:56.835 [10443] dbg: rules: run_generic_tests - compiling eval code: meta, priority -1000	0.00064
Apr 12 16:44:56.835 [10443] dbg: rules: compiled meta tests	0.0003
Apr 12 16:44:56.836 [10443] dbg: check: running tests for priority: -950	0.00083
Apr 12 16:44:56.836 [10443] dbg: rules: running one_line_body tests; score so far=0	0.00027
Apr 12 16:44:56.837 [10443] dbg: rules: flush_evalstr (run_generic_tests) compiling 521 chars of Mail::SpamAssassin::Plugin::Check::_one_line_body_tests_neg950_1	0.00031
Apr 12 16:44:56.837 [10443] dbg: rules: run_generic_tests - compiling eval code: one_line_body, priority -950	0.00052
Apr 12 16:44:56.837 [10443] dbg: rules: compiled one_line_body tests	0.00031
Apr 12 16:44:56.838 [10443] dbg: rules: running head tests; score so far=0	0.00044
Apr 12 16:44:56.838 [10443] dbg: rules: flush_evalstr (run_generic_tests) compiling 302 chars of Mail::SpamAssassin::Plugin::Check::_head_tests_neg950_1	0.00026
Apr 12 16:44:56.839 [10443] dbg: rules: run_generic_tests - compiling eval code: head, priority -950	0.00047
Apr 12 16:44:56.839 [10443] dbg: rules: compiled head tests	0.00025
Apr 12 16:44:56.839 [10443] dbg: rules: running head_eval tests; score so far=0	0.00028
Apr 12 16:44:56.839 [10443] dbg: rules: run_eval_tests - compiling eval code: 9, priority -950	0.00025
Apr 12 16:44:56.840 [10443] dbg: rules: running body tests; score so far=0	0.00079
Apr 12 16:44:56.841 [10443] dbg: rules: flush_evalstr (run_generic_tests) compiling 245 chars of Mail::SpamAssassin::Plugin::Check::_body_tests_neg950_1	0.00028
Apr 12 16:44:56.841 [10443] dbg: rules: run_generic_tests - compiling eval code: body, priority -950	0.00046
Apr 12 16:44:56.841 [10443] dbg: rules: compiled body tests	0.00032
Apr 12 16:44:56.842 [10443] dbg: rules: running uri tests; score so far=0	0.00042
Apr 12 16:44:56.842 [10443] dbg: rules: flush_evalstr (run_generic_tests) compiling 243 chars of Mail::SpamAssassin::Plugin::Check::_uri_tests_neg950_1	0.00025
Apr 12 16:44:56.842 [10443] dbg: rules: run_generic_tests - compiling eval code: uri, priority -950	0.00027
Apr 12 16:44:56.843 [10443] dbg: rules: compiled uri tests	0.00031
Apr 12 16:44:56.843 [10443] dbg: rules: running rawbody tests; score so far=0	0.00033
Apr 12 16:44:56.843 [10443] dbg: rules: flush_evalstr (run_generic_tests) compiling 251 chars of Mail::SpamAssassin::Plugin::Check::_rawbody_tests_neg950_1	0.00019
Apr 12 16:44:56.843 [10443] dbg: rules: run_generic_tests - compiling eval code: rawbody, priority -950	0.00027
Apr 12 16:44:56.844 [10443] dbg: rules: compiled rawbody tests	0.00025
Apr 12 16:44:56.844 [10443] dbg: rules: running full tests; score so far=0	0.00031
Apr 12 16:44:56.844 [10443] dbg: rules: flush_evalstr (run_generic_tests) compiling 280 chars of Mail::SpamAssassin::Plugin::Check::_full_tests_neg950_1	0.00019
Apr 12 16:44:56.845 [10443] dbg: rules: run_generic_tests - compiling eval code: full, priority -950	0.00045
Apr 12 16:44:56.845 [10443] dbg: rules: compiled full tests	0.00023
Apr 12 16:44:56.845 [10443] dbg: rules: running meta tests; score so far=0	0.00035
Apr 12 16:44:56.845 [10443] dbg: rules: flush_evalstr (run_generic_tests) compiling 305 chars of Mail::SpamAssassin::Plugin::Check::_meta_tests_neg950_1	0.00032
Apr 12 16:44:56.846 [10443] dbg: rules: run_generic_tests - compiling eval code: meta, priority -950	0.00032
Apr 12 16:44:56.846 [10443] dbg: rules: compiled meta tests	0.00022
Apr 12 16:44:56.846 [10443] dbg: check: running tests for priority: -900	0.00042
Apr 12 16:44:56.847 [10443] dbg: rules: running one_line_body tests; score so far=0	0.00021
Apr 12 16:44:56.847 [10443] dbg: rules: flush_evalstr (run_generic_tests) compiling 521 chars of Mail::SpamAssassin::Plugin::Check::_one_line_body_tests_neg900_1	0.00023
Apr 12 16:44:56.847 [10443] dbg: rules: run_generic_tests - compiling eval code: one_line_body, priority -900	0.00029
Apr 12 16:44:56.847 [10443] dbg: rules: compiled one_line_body tests	0.0002
Apr 12 16:44:56.848 [10443] dbg: rules: running head tests; score so far=0	0.00029
Apr 12 16:44:56.848 [10443] dbg: rules: flush_evalstr (run_generic_tests) compiling 302 chars of Mail::SpamAssassin::Plugin::Check::_head_tests_neg900_1	0.00022
Apr 12 16:44:56.848 [10443] dbg: rules: run_generic_tests - compiling eval code: head, priority -900	0.00043
Apr 12 16:44:56.849 [10443] dbg: rules: compiled head tests	0.00033
Apr 12 16:44:56.849 [10443] dbg: rules: running head_eval tests; score so far=0	0.00039
Apr 12 16:44:56.849 [10443] dbg: rules: run_eval_tests - compiling eval code: 9, priority -900	0.00032
Apr 12 16:44:56.851 [10443] dbg: rules: running body tests; score so far=0	0.00134
Apr 12 16:44:56.851 [10443] dbg: rules: flush_evalstr (run_generic_tests) compiling 245 chars of Mail::SpamAssassin::Plugin::Check::_body_tests_neg900_1	0.00022
Apr 12 16:44:56.851 [10443] dbg: rules: run_generic_tests - compiling eval code: body, priority -900	0.00032
Apr 12 16:44:56.852 [10443] dbg: rules: compiled body tests	0.00032
Apr 12 16:44:56.852 [10443] dbg: rules: running uri tests; score so far=0	0.00041
Apr 12 16:44:56.852 [10443] dbg: rules: flush_evalstr (run_generic_tests) compiling 243 chars of Mail::SpamAssassin::Plugin::Check::_uri_tests_neg900_1	0.0002
Apr 12 16:44:56.852 [10443] dbg: rules: run_generic_tests - compiling eval code: uri, priority -900	0.00033
Apr 12 16:44:56.853 [10443] dbg: rules: compiled uri tests	0.0002
Apr 12 16:44:56.853 [10443] dbg: rules: running rawbody tests; score so far=0	0.00037
Apr 12 16:44:56.853 [10443] dbg: rules: flush_evalstr (run_generic_tests) compiling 251 chars of Mail::SpamAssassin::Plugin::Check::_rawbody_tests_neg900_1	0.00019
Apr 12 16:44:56.854 [10443] dbg: rules: run_generic_tests - compiling eval code: rawbody, priority -900	0.00028
Apr 12 16:44:56.854 [10443] dbg: rules: compiled rawbody tests	0.00024
Apr 12 16:44:56.854 [10443] dbg: rules: running full tests; score so far=0	0.00027
Apr 12 16:44:56.854 [10443] dbg: rules: flush_evalstr (run_generic_tests) compiling 280 chars of Mail::SpamAssassin::Plugin::Check::_full_tests_neg900_1	0.00019
Apr 12 16:44:56.855 [10443] dbg: rules: run_generic_tests - compiling eval code: full, priority -900	0.00037
Apr 12 16:44:56.855 [10443] dbg: rules: compiled full tests	0.00025
Apr 12 16:44:56.855 [10443] dbg: rules: running meta tests; score so far=0	0.00027
Apr 12 16:44:56.855 [10443] dbg: rules: flush_evalstr (run_generic_tests) compiling 305 chars of Mail::SpamAssassin::Plugin::Check::_meta_tests_neg900_1	0.00022
Apr 12 16:44:56.856 [10443] dbg: rules: run_generic_tests - compiling eval code: meta, priority -900	0.00027
Apr 12 16:44:56.856 [10443] dbg: rules: compiled meta tests	0.00047
Apr 12 16:44:56.856 [10443] dbg: check: running tests for priority: -400	0.00032
Apr 12 16:44:56.857 [10443] dbg: rules: running one_line_body tests; score so far=0	0.00017
Apr 12 16:44:56.857 [10443] dbg: rules: flush_evalstr (run_generic_tests) compiling 521 chars of Mail::SpamAssassin::Plugin::Check::_one_line_body_tests_neg400_1	0.00022
Apr 12 16:44:56.857 [10443] dbg: rules: run_generic_tests - compiling eval code: one_line_body, priority -400	0.00028
Apr 12 16:44:56.857 [10443] dbg: rules: compiled one_line_body tests	0.00019
Apr 12 16:44:56.858 [10443] dbg: rules: running head tests; score so far=0	0.00031
Apr 12 16:44:56.858 [10443] dbg: rules: flush_evalstr (run_generic_tests) compiling 302 chars of Mail::SpamAssassin::Plugin::Check::_head_tests_neg400_1	0.00022
Apr 12 16:44:56.858 [10443] dbg: rules: run_generic_tests - compiling eval code: head, priority -400	0.00034
Apr 12 16:44:56.858 [10443] dbg: rules: compiled head tests	0.00024
Apr 12 16:44:56.859 [10443] dbg: rules: running body tests; score so far=0	0.00038
Apr 12 16:44:56.859 [10443] dbg: rules: flush_evalstr (run_generic_tests) compiling 245 chars of Mail::SpamAssassin::Plugin::Check::_body_tests_neg400_1	0.00018
Apr 12 16:44:56.859 [10443] dbg: rules: run_generic_tests - compiling eval code: body, priority -400	0.00026
Apr 12 16:44:56.859 [10443] dbg: rules: compiled body tests	0.00021
Apr 12 16:44:56.860 [10443] dbg: rules: running uri tests; score so far=0	0.00027
Apr 12 16:44:56.860 [10443] dbg: rules: flush_evalstr (run_generic_tests) compiling 243 chars of Mail::SpamAssassin::Plugin::Check::_uri_tests_neg400_1	0.00021
Apr 12 16:44:56.860 [10443] dbg: rules: run_generic_tests - compiling eval code: uri, priority -400	0.00024
Apr 12 16:44:56.860 [10443] dbg: rules: compiled uri tests	0.00021
BliXem
Re: Spam
Post by BliXem »
3:
Apr 12 16:44:56.861 [10443] dbg: rules: running body_eval tests; score so far=0	0.00023
Apr 12 16:44:56.861 [10443] dbg: rules: run_eval_tests - compiling eval code: 11, priority -400	0.00025
Apr 12 16:44:56.861 [10443] dbg: rules: running rawbody tests; score so far=0	0.00035
Apr 12 16:44:56.861 [10443] dbg: rules: flush_evalstr (run_generic_tests) compiling 251 chars of Mail::SpamAssassin::Plugin::Check::_rawbody_tests_neg400_1	0.00018
Apr 12 16:44:56.862 [10443] dbg: rules: run_generic_tests - compiling eval code: rawbody, priority -400	0.00028
Apr 12 16:44:56.862 [10443] dbg: rules: compiled rawbody tests	0.00028
Apr 12 16:44:56.862 [10443] dbg: rules: running full tests; score so far=0	0.00026
Apr 12 16:44:56.862 [10443] dbg: rules: flush_evalstr (run_generic_tests) compiling 280 chars of Mail::SpamAssassin::Plugin::Check::_full_tests_neg400_1	0.00028
Apr 12 16:44:56.863 [10443] dbg: rules: run_generic_tests - compiling eval code: full, priority -400	0.00032
Apr 12 16:44:56.863 [10443] dbg: rules: compiled full tests	0.0002
Apr 12 16:44:56.863 [10443] dbg: rules: running meta tests; score so far=0	0.00026
Apr 12 16:44:56.863 [10443] dbg: rules: flush_evalstr (run_generic_tests) compiling 305 chars of Mail::SpamAssassin::Plugin::Check::_meta_tests_neg400_1	0.00023
Apr 12 16:44:56.864 [10443] dbg: rules: run_generic_tests - compiling eval code: meta, priority -400	0.00031
Apr 12 16:44:56.864 [10443] dbg: rules: compiled meta tests	0.00023
Apr 12 16:44:56.864 [10443] dbg: check: running tests for priority: 0	0.00031
Apr 12 16:44:56.864 [10443] dbg: rules: running one_line_body tests; score so far=0	0.00017
Apr 12 16:44:56.910 [10443] dbg: rules: flush_evalstr (run_generic_tests) compiling 510 chars of Mail::SpamAssassin::Plugin::Check::_one_line_body_tests_0_1	0.04615
Apr 12 16:44:56.915 [10443] dbg: rules: run_generic_tests - compiling eval code: one_line_body, priority 0	0.00469
Apr 12 16:44:57.022 [10443] dbg: rules: compiled one_line_body tests	0.1068
Apr 12 16:44:57.023 [10443] dbg: zoom: run_body_fast_scan for body_0 start	0.00088
Apr 12 16:44:57.030 [10443] dbg: zoom: run_body_fast_scan for body_0 done	0.00738
Apr 12 16:44:57.031 [10443] dbg: rules: running head tests; score so far=0	0.00034
Apr 12 16:44:57.065 [10443] dbg: rules: flush_evalstr (add_evalstr) compiling 60112 chars of Mail::SpamAssassin::Plugin::Check::_head_tests_0_1	0.03439
Apr 12 16:44:57.077 [10443] dbg: rules: flush_evalstr (add_evalstr) compiling 60220 chars of Mail::SpamAssassin::Plugin::Check::_head_tests_0_2	0.01175
Apr 12 16:44:57.088 [10443] dbg: rules: flush_evalstr (add_evalstr) compiling 60131 chars of Mail::SpamAssassin::Plugin::Check::_head_tests_0_3	0.01108
Apr 12 16:44:57.099 [10443] dbg: rules: flush_evalstr (add_evalstr) compiling 60586 chars of Mail::SpamAssassin::Plugin::Check::_head_tests_0_4	0.01105
Apr 12 16:44:57.109 [10443] dbg: rules: flush_evalstr (add_evalstr) compiling 60041 chars of Mail::SpamAssassin::Plugin::Check::_head_tests_0_5	0.01055
Apr 12 16:44:57.120 [10443] dbg: rules: flush_evalstr (add_evalstr) compiling 60242 chars of Mail::SpamAssassin::Plugin::Check::_head_tests_0_6	0.01073
Apr 12 16:44:57.131 [10443] dbg: rules: flush_evalstr (add_evalstr) compiling 60184 chars of Mail::SpamAssassin::Plugin::Check::_head_tests_0_7	0.0104
Apr 12 16:44:57.141 [10443] dbg: rules: flush_evalstr (add_evalstr) compiling 60346 chars of Mail::SpamAssassin::Plugin::Check::_head_tests_0_8	0.01086
Apr 12 16:44:57.153 [10443] dbg: rules: flush_evalstr (add_evalstr) compiling 60165 chars of Mail::SpamAssassin::Plugin::Check::_head_tests_0_9	0.01121
Apr 12 16:44:57.164 [10443] dbg: rules: flush_evalstr (add_evalstr) compiling 60410 chars of Mail::SpamAssassin::Plugin::Check::_head_tests_0_10	0.01125
Apr 12 16:44:57.173 [10443] dbg: rules: flush_evalstr (run_generic_tests) compiling 22613 chars of Mail::SpamAssassin::Plugin::Check::_head_tests_0_11	0.00869
Apr 12 16:44:57.176 [10443] dbg: rules: run_generic_tests - compiling eval code: head, priority 0	0.00377
Apr 12 16:44:57.177 [10443] dbg: rules: compiled head tests	0.00042
Apr 12 16:44:57.178 [10443] dbg: rules: ran header rule __MISSING_REF ======> got hit: "UNSET"	0.00132
Apr 12 16:44:57.178 [10443] dbg: rules: ran header rule __MISSING_REPLY ======> got hit: "UNSET"	0.0003
Apr 12 16:44:57.179 [10443] dbg: rules: ran header rule __MSGID_OK_HOST ======> got hit: "@lint_rules>"	0.00077
Apr 12 16:44:57.180 [10443] dbg: rules: ran header rule __MSGID_OK_DIGITS ======> got hit: "1492008294"	0.00027
Apr 12 16:44:57.180 [10443] dbg: rules: ran header rule __HAS_MESSAGE_ID ======> got hit: "<YES>"	0.00044
Apr 12 16:44:57.181 [10443] dbg: rules: ran header rule __MSOE_MID_WRONG_CASE ======> got hit: "	0.00103
Apr 12 16:44:57.181 [10443] dbg: rules: [...] Message-Id: "	0.00012
Apr 12 16:44:57.182 [10443] dbg: rules: ran header rule __HAS_SUBJECT ======> got hit: "<YES>"	0.00064
Apr 12 16:44:57.182 [10443] dbg: rules: ran header rule __SUBJ_SHORT ======> got hit: "negative match"	0.00046
Apr 12 16:44:57.183 [10443] dbg: rules: ran header rule __HAS_MSGID ======> got hit: "<"	0.00083
Apr 12 16:44:57.183 [10443] dbg: rules: ran header rule __SANE_MSGID ======> got hit: "<1492008294@lint_rules>	0.00023
Apr 12 16:44:57.183 [10443] dbg: rules: [...] "	0.0001
Apr 12 16:44:57.184 [10443] dbg: rules: ran header rule __TO_NO_ARROWS_R ======> got hit: "negative match"	0.00028
Apr 12 16:44:57.184 [10443] dbg: message: envelope_sender_header 'X-MailScanner-EFA-From' not found in message	0.00044
Apr 12 16:44:57.185 [10443] dbg: rules: ran header rule __HAS_FROM ======> got hit: "<YES>"	0.00049
Apr 12 16:44:57.185 [10443] dbg: rules: ran header rule __KAM_PAYPAL3B ======> got hit: "negative match"	0.00031
Apr 12 16:44:57.185 [10443] dbg: rules: ran header rule __KAM_FAKEDELIVER6 ======> got hit: "negative match"	0.00025
Apr 12 16:44:57.185 [10443] dbg: rules: ran header rule __KAM_MULTIPLE_FROM ======> got hit: "i"	0.00035
Apr 12 16:44:57.186 [10443] dbg: rules: ran header rule __KAM_FAKEDELIVER12 ======> got hit: "negative match"	0.00045
Apr 12 16:44:57.187 [10443] dbg: rules: ran header rule __KAM_HARP3 ======> got hit: "negative match"	0.00062
Apr 12 16:44:57.187 [10443] dbg: rules: ran header rule __KAM_FAKEDELIVER4 ======> got hit: "negative match"	0.00043
Apr 12 16:44:57.187 [10443] dbg: rules: ran header rule __KAM_FAKEDELIVER8 ======> got hit: "negative match"	0.00041
Apr 12 16:44:57.188 [10443] dbg: rules: ran header rule __KAM_JURY3 ======> got hit: "negative match"	0.0006
Apr 12 16:44:57.188 [10443] dbg: rules: ran header rule __KAM_DROPBOX2 ======> got hit: "negative match"	0.00026
Apr 12 16:44:57.189 [10443] dbg: rules: ran header rule __KAM_UPS2 ======> got hit: "negative match"	0.00029
Apr 12 16:44:57.189 [10443] dbg: rules: ran header rule __KAM_GOOGLE2_2 ======> got hit: "negative match"	0.00056
Apr 12 16:44:57.191 [10443] dbg: rules: running head_eval tests; score so far=0	0.00169
Apr 12 16:44:57.193 [10443] dbg: rules: run_eval_tests - compiling eval code: 9, priority 0	0.00179
Apr 12 16:44:57.202 [10443] dbg: FreeMail: RULE (FREEMAIL_FROM) check_freemail_from	0.00929
Apr 12 16:44:57.202 [10443] dbg: FreeMail: all from-addresses: ignore@compiling.spamassassin.taint.org	0.00016
Apr 12 16:44:57.203 [10443] dbg: FreeMail: RULE (__freemail_reply) check_freemail_replyto	0.00116
Apr 12 16:44:57.203 [10443] dbg: FreeMail: From address: ignore@compiling.spamassassin.taint.org	0.00023
Apr 12 16:44:57.204 [10443] dbg: FreeMail: No Reply-To and From is not freemail, skipping check	0.00012
Apr 12 16:44:57.205 [10443] dbg: rules: ran eval rule NO_RELAYS ======> got hit (1)	0.00107
Apr 12 16:44:57.206 [10443] dbg: rules: ran eval rule __GATED_THROUGH_RCVD_REMOVER ======> got hit (1)	0.00093
Apr 12 16:44:57.206 [10443] dbg: FreeMail: RULE (__smf_freemail_hdr_replyto) check_freemail_header	0.00028
Apr 12 16:44:57.206 [10443] dbg: FreeMail: header Reply-To:addr not found from mail	0.00014
Apr 12 16:44:57.207 [10443] dbg: FreeMail: RULE (FREEMAIL_REPLYTO_END_DIGIT) check_freemail_header regex:\d@	0.00053
Apr 12 16:44:57.207 [10443] dbg: FreeMail: header Reply-To not found from mail	0.00015
Apr 12 16:44:57.207 [10443] dbg: FreeMail: RULE (__freemail_replyto) check_freemail_replyto	0.00043
Apr 12 16:44:57.207 [10443] dbg: FreeMail: From address: ignore@compiling.spamassassin.taint.org	0.00015
Apr 12 16:44:57.207 [10443] dbg: FreeMail: Reply-To is not freemail, skipping check	0.00012
Apr 12 16:44:57.208 [10443] dbg: FreeMail: RULE (__freemail_hdr_replyto) check_freemail_header	0.00061
Apr 12 16:44:57.208 [10443] dbg: FreeMail: header Reply-To not found from mail	0.00012
Apr 12 16:44:57.208 [10443] dbg: spf: cannot get Envelope-From, cannot use SPF	0.00028
Apr 12 16:44:57.209 [10443] dbg: spf: def_spf_whitelist_from: could not find useable envelope sender	0.00016
Apr 12 16:44:57.209 [10443] dbg: spf: checking to see if the message has a Received-SPF header that we can use	0.00041
Apr 12 16:44:57.209 [10443] dbg: FreeMail: RULE (FREEMAIL_ENVFROM_END_DIGIT) check_freemail_header regex:\d@	0.00031
Apr 12 16:44:57.209 [10443] dbg: FreeMail: header EnvelopeFrom not found from mail	0.00017
Apr 12 16:44:57.211 [10443] dbg: rules: ran eval rule MISSING_HEADERS ======> got hit (1)	0.00161
Apr 12 16:44:57.211 [10443] dbg: spf: spf_whitelist_from: could not find useable envelope sender	0.00036
Apr 12 16:44:57.212 [10443] dbg: rules: running body tests; score so far=0.914	0.00042
Apr 12 16:44:57.217 [10443] dbg: rules: flush_evalstr (add_evalstr) compiling 60240 chars of Mail::SpamAssassin::Plugin::Check::_body_tests_0_1	0.00533
Apr 12 16:44:57.239 [10443] dbg: rules: flush_evalstr (add_evalstr) compiling 62441 chars of Mail::SpamAssassin::Plugin::Check::_body_tests_0_2	0.02164
Apr 12 16:44:57.253 [10443] dbg: rules: flush_evalstr (add_evalstr) compiling 63103 chars of Mail::SpamAssassin::Plugin::Check::_body_tests_0_3	0.01417
Apr 12 16:44:57.265 [10443] dbg: rules: flush_evalstr (run_generic_tests) compiling 21123 chars of Mail::SpamAssassin::Plugin::Check::_body_tests_0_4	0.01165
Apr 12 16:44:57.268 [10443] dbg: rules: run_generic_tests - compiling eval code: body, priority 0	0.00396
Apr 12 16:44:57.269 [10443] dbg: rules: compiled body tests	0.00032
Apr 12 16:44:57.293 [10443] dbg: rules: ran body rule __BODY_TEXT_LINE ======> got hit: "I"	0.0247
Apr 12 16:44:57.320 [10443] dbg: rules: ran body rule __NONEMPTY_BODY ======> got hit: "I"	0.0265
Apr 12 16:44:57.350 [10443] dbg: rules: running uri tests; score so far=0.914	0.03034
Apr 12 16:44:57.355 [10443] dbg: rules: flush_evalstr (run_generic_tests) compiling 49522 chars of Mail::SpamAssassin::Plugin::Check::_uri_tests_0_1	0.00483
Apr 12 16:44:57.363 [10443] dbg: rules: run_generic_tests - compiling eval code: uri, priority 0	0.00813
Apr 12 16:44:57.364 [10443] dbg: rules: compiled uri tests	0.0003
Apr 12 16:44:57.364 [10443] dbg: rules: running body_eval tests; score so far=0.914	0.00063
Apr 12 16:44:57.368 [10443] dbg: rules: run_eval_tests - compiling eval code: 11, priority 0	0.00402
Apr 12 16:44:57.403 [10443] dbg: pdfinfo: Identified 0 possible mime parts that need checked for PDF content	0.03465
Apr 12 16:44:57.403 [10443] dbg: pdfinfo: set_tag called for PDFCOUNT 0	0.00019
Apr 12 16:44:57.403 [10443] dbg: pdfinfo: set_tag called for PDFIMGCOUNT 0	0.00016
Apr 12 16:44:57.404 [10443] dbg: https_http_mismatch: anchors 0	0.00081
Apr 12 16:44:57.405 [10443] dbg: eval: body_length - 1340 - check for min of 256	0.0005
Apr 12 16:44:57.408 [10443] dbg: eval: body_length - 1340 - check for min of 128	0.00327
Apr 12 16:44:57.408 [10443] dbg: eval: body_length - 1340 - check for min of 1024	0.00041
Apr 12 16:44:57.409 [10443] dbg: eval: body_length - 1340 - check for min of 512	0.0003
Apr 12 16:44:57.413 [10443] dbg: eval: tvd_vertical_words value: 21 / min: 0 / max: 10 - value must be >= min and < max	0.00423
Apr 12 16:44:57.417 [10443] dbg: rules: running rawbody tests; score so far=0.914	0.00456
Apr 12 16:44:57.422 [10443] dbg: rules: flush_evalstr (run_generic_tests) compiling 54432 chars of Mail::SpamAssassin::Plugin::Check::_rawbody_tests_0_1	0.00475
Apr 12 16:44:57.431 [10443] dbg: rules: run_generic_tests - compiling eval code: rawbody, priority 0	0.00927
Apr 12 16:44:57.432 [10443] dbg: rules: compiled rawbody tests	0.00029
Apr 12 16:44:57.439 [10443] dbg: rules: ran rawbody rule __RB_GT_200 ======> got hit: "I need to make this message body somewhat long so TextCat preloads	0.00726
Apr 12 16:44:57.439 [10443] dbg: rules: [...] I need to make this message body somewhat long so TextCat preloads	0.00015
Apr 12 16:44:57.439 [10443] dbg: rules: [...] "	0.0001
Apr 12 16:44:57.446 [10443] dbg: rules: running rawbody_eval tests; score so far=0.914	0.00676
Apr 12 16:44:57.446 [10443] dbg: rules: run_eval_tests - compiling eval code: 15, priority 0	0.0004
Apr 12 16:44:57.448 [10443] dbg: rules: running full tests; score so far=0.914	0.00155
Apr 12 16:44:57.448 [10443] dbg: rules: flush_evalstr (run_generic_tests) compiling 1998 chars of Mail::SpamAssassin::Plugin::Check::_full_tests_0_1	0.0004
Apr 12 16:44:57.449 [10443] dbg: rules: run_generic_tests - compiling eval code: full, priority 0	0.00056
Apr 12 16:44:57.449 [10443] dbg: rules: compiled full tests	0.00021
Apr 12 16:44:57.449 [10443] dbg: rules-all: running full rule __BASE64_MDAW	0.00021
Apr 12 16:44:57.450 [10443] dbg: rules-all: running full rule __RW_BAD_UTF8_3	0.00012
Apr 12 16:44:57.450 [10443] dbg: rules-all: running full rule NULL_IN_BODY	0.00034
Apr 12 16:44:57.450 [10443] dbg: rules: running full_eval tests; score so far=0.914	0.00019
Apr 12 16:44:57.450 [10443] dbg: rules: run_eval_tests - compiling eval code: 13, priority 0	0.00034
Apr 12 16:44:57.451 [10443] dbg: dkim: signature verification disabled, DNS resolving not available	0.00076
Apr 12 16:44:57.451 [10443] dbg: rules: running meta tests; score so far=0.914	0.00023
Apr 12 16:44:57.452 [10443] dbg: rules: flush_evalstr (run_generic_tests) compiling 297 chars of Mail::SpamAssassin::Plugin::Check::_meta_tests_0_1	0.00022
Apr 12 16:44:57.452 [10443] dbg: rules: run_generic_tests - compiling eval code: meta, priority 0	0.00031
Apr 12 16:44:57.452 [10443] dbg: rules: compiled meta tests	0.00023
Apr 12 16:44:57.452 [10443] dbg: check: running tests for priority: 500	0.00032
Apr 12 16:44:57.453 [10443] dbg: dns: harvest_dnsbl_queries	0.00014
Apr 12 16:44:57.453 [10443] dbg: rules: running one_line_body tests; score so far=0.914	0.00059
Apr 12 16:44:57.453 [10443] dbg: rules: flush_evalstr (run_generic_tests) compiling 516 chars of Mail::SpamAssassin::Plugin::Check::_one_line_body_tests_500_1	0.00024
Apr 12 16:44:57.454 [10443] dbg: rules: run_generic_tests - compiling eval code: one_line_body, priority 500	0.00033
Apr 12 16:44:57.454 [10443] dbg: rules: compiled one_line_body tests	0.0002
Apr 12 16:44:57.454 [10443] dbg: rules: running head tests; score so far=0.914	0.00037
Apr 12 16:44:57.455 [10443] dbg: rules: flush_evalstr (run_generic_tests) compiling 298 chars of Mail::SpamAssassin::Plugin::Check::_head_tests_500_1	0.00021
Apr 12 16:44:57.455 [10443] dbg: rules: run_generic_tests - compiling eval code: head, priority 500	0.00042
Apr 12 16:44:57.455 [10443] dbg: rules: compiled head tests	0.00022
Apr 12 16:44:57.456 [10443] dbg: rules: running body tests; score so far=0.914	0.00033
Apr 12 16:44:57.456 [10443] dbg: rules: flush_evalstr (run_generic_tests) compiling 241 chars of Mail::SpamAssassin::Plugin::Check::_body_tests_500_1	0.00022
Apr 12 16:44:57.456 [10443] dbg: rules: run_generic_tests - compiling eval code: body, priority 500	0.00057
Apr 12 16:44:57.457 [10443] dbg: rules: compiled body tests	0.00027
Apr 12 16:44:57.457 [10443] dbg: rules: running uri tests; score so far=0.914	0.00049
Apr 12 16:44:57.457 [10443] dbg: rules: flush_evalstr (run_generic_tests) compiling 239 chars of Mail::SpamAssassin::Plugin::Check::_uri_tests_500_1	0.00031
Apr 12 16:44:57.458 [10443] dbg: rules: run_generic_tests - compiling eval code: uri, priority 500	0.00035
Apr 12 16:44:57.458 [10443] dbg: rules: compiled uri tests	0.00036
Apr 12 16:44:57.459 [10443] dbg: rules: running rawbody tests; score so far=0.914	0.00048
Apr 12 16:44:57.459 [10443] dbg: rules: flush_evalstr (run_generic_tests) compiling 247 chars of Mail::SpamAssassin::Plugin::Check::_rawbody_tests_500_1	0.0003
Apr 12 16:44:57.459 [10443] dbg: rules: run_generic_tests - compiling eval code: rawbody, priority 500	0.00045
Apr 12 16:44:57.460 [10443] dbg: rules: compiled rawbody tests	0.00028
Apr 12 16:44:57.460 [10443] dbg: rules: running full tests; score so far=0.914	0.00085
Apr 12 16:44:57.461 [10443] dbg: rules: flush_evalstr (run_generic_tests) compiling 276 chars of Mail::SpamAssassin::Plugin::Check::_full_tests_500_1	0.00031
Apr 12 16:44:57.461 [10443] dbg: rules: run_generic_tests - compiling eval code: full, priority 500	0.00038
Apr 12 16:44:57.461 [10443] dbg: rules: compiled full tests	0.00022
Apr 12 16:44:57.462 [10443] dbg: rules: running meta tests; score so far=0.914	0.00035
Apr 12 16:44:57.463 [10443] info: rules: meta test KAM_AMAZON has dependency 'KAM_RAPTOR' with a zero score	0.00118
Apr 12 16:44:57.464 [10443] info: rules: meta test KAM_VOICEMAIL has dependency 'KAM_RAPTOR' with a zero score	0.0012
Apr 12 16:44:57.465 [10443] info: rules: meta test KAM_BBB has dependency 'KAM_RAPTOR' with a zero score	0.00061
Apr 12 16:44:57.466 [10443] info: rules: meta test KAM_INSURE2 has dependency 'CBJ_GiveMeABreak' with a zero score	0.0008
Apr 12 16:44:57.467 [10443] dbg: rules: meta test KAM_CREDIT2 has undefined dependency '__KAM_URIBL_PCCC'	0.00199
Apr 12 16:44:57.473 [10443] info: rules: meta test JMQ_CONGRAT has dependency 'KAM_RAPTOR' with a zero score	0.0052
Apr 12 16:44:57.473 [10443] dbg: rules: meta test JMQ_CONGRAT has undefined dependency 'HK_SPAMMY_FILENAME'	0.00017
Apr 12 16:44:57.475 [10443] dbg: rules: meta test KAM_SALE has undefined dependency 'BODY_8BITS'	0.00251
Apr 12 16:44:57.476 [10443] dbg: rules: meta test KAM_GOOGLE2 has undefined dependency 'HK_SPAMMY_FILENAME'	0.00038
Apr 12 16:44:57.476 [10443] info: rules: meta test KAM_EVICTION has dependency 'KAM_RAPTOR' with a zero score	0.00044
Apr 12 16:44:57.478 [10443] info: rules: meta test KAM_REALLY_FAKE_DELIVER has dependency 'KAM_RPTR_PASSED' with a zero score	0.00179
Apr 12 16:44:57.481 [10443] info: rules: meta test KAM_INSURE has dependency 'CBJ_GiveMeABreak' with a zero score	0.00257
Apr 12 16:44:57.488 [10443] info: rules: meta test KAM_AUTO has dependency 'CBJ_GiveMeABreak' with a zero score	0.00794
Apr 12 16:44:57.489 [10443] info: rules: meta test KAM_PHISHY_DOLLARS has dependency 'KAM_RAPTOR' with a zero score	0.00089
Apr 12 16:44:57.493 [10443] info: rules: meta test KAM_JURY has dependency 'KAM_RAPTOR' with a zero score	0.00335
Apr 12 16:44:57.497 [10443] info: rules: meta test KAM_CARD has dependency 'KAM_RPTR_SUSPECT' with a zero score	0.00406
Apr 12 16:44:57.499 [10443] info: rules: meta test KAM_NOTIFY2 has dependency 'KAM_IFRAME' with a zero score	0.00172
Apr 12 16:44:57.502 [10443] info: rules: meta test KAM_FAKE_DELIVER has dependency 'KAM_RAPTOR' with a zero score	0.00387
Apr 12 16:44:57.503 [10443] dbg: rules: meta test KAM_BAD_DNSWL has undefined dependency 'IN_BRBL'	0.00037
Apr 12 16:44:57.503 [10443] dbg: rules: meta test KAM_BAD_DNSWL has undefined dependency 'RCVD_IN_BRBL_RELAY'	0.00014
Apr 12 16:44:57.503 [10443] dbg: rules: meta test KAM_BAD_DNSWL has undefined dependency '__KAM_URIBL_PCCC'	0.00017
Apr 12 16:44:57.503 [10443] dbg: rules: meta test KAM_BAD_DNSWL has undefined dependency 'KAM_MESSAGE_EMAILBL_PCCC'	0.00012
Apr 12 16:44:57.503 [10443] dbg: rules: meta test KAM_BAD_DNSWL has undefined dependency 'RCVD_IN_HOSTKARMA_W'	0.00014
Apr 12 16:44:57.504 [10443] info: rules: meta test KAM_FORGED_ATTACHED has dependency 'KAM_RAPTOR' with a zero score	0.00104
Apr 12 16:44:57.505 [10443] dbg: rules: meta test KAM_GRABBAG9 has undefined dependency 'MALFORMED_FREEMAIL'	0.00047
Apr 12 16:44:57.511 [10443] info: rules: meta test KAM_WARRANTY has dependency 'CBJ_GiveMeABreak' with a zero score	0.00642
Apr 12 16:44:57.514 [10443] info: rules: meta test KAM_BADPDF2 has dependency 'KAM_RPTR_SUSPECT' with a zero score	0.00264
Apr 12 16:44:57.517 [10443] info: rules: meta test KAM_VERY_MALWARE has dependency 'KAM_RAPTOR' with a zero score	0.003
Apr 12 16:44:57.521 [10443] dbg: rules: meta test KAM_COLLEGE has undefined dependency '__KAM_URIBL_PCCC'	0.00397
Apr 12 16:44:57.524 [10443] info: rules: meta test KAM_PAYPAL2 has dependency 'KAM_RAPTOR' with a zero score	0.00369
Apr 12 16:44:57.531 [10443] dbg: rules: meta test KAM_PHISH2 has undefined dependency '__KAM_URIBL_PCCC'	0.00611
Apr 12 16:44:57.533 [10443] info: rules: meta test KAM_WARRANTY3 has dependency 'CBJ_GiveMeABreak' with a zero score	0.00217
Apr 12 16:44:57.542 [10443] dbg: rules: flush_evalstr (add_evalstr) compiling 60158 chars of Mail::SpamAssassin::Plugin::Check::_meta_tests_500_1	0.00886
Apr 12 16:44:57.555 [10443] dbg: rules: flush_evalstr (add_evalstr) compiling 60151 chars of Mail::SpamAssassin::Plugin::Check::_meta_tests_500_2	0.01315
Apr 12 16:44:57.569 [10443] dbg: rules: flush_evalstr (add_evalstr) compiling 60164 chars of Mail::SpamAssassin::Plugin::Check::_meta_tests_500_3	0.014
Apr 12 16:44:57.584 [10443] dbg: rules: flush_evalstr (add_evalstr) compiling 60073 chars of Mail::SpamAssassin::Plugin::Check::_meta_tests_500_4	0.01498
Apr 12 16:44:57.600 [10443] dbg: rules: flush_evalstr (run_generic_tests) compiling 53002 chars of Mail::SpamAssassin::Plugin::Check::_meta_tests_500_5	0.01659
Apr 12 16:44:57.610 [10443] dbg: rules: run_generic_tests - compiling eval code: meta, priority 500	0.00945
Apr 12 16:44:57.610 [10443] dbg: rules: compiled meta tests	0.00032
Apr 12 16:44:57.615 [10443] dbg: check: running tests for priority: 1000	0.005
Apr 12 16:44:57.615 [10443] dbg: rules: running one_line_body tests; score so far=3.652	0.00023
Apr 12 16:44:57.616 [10443] dbg: rules: flush_evalstr (run_generic_tests) compiling 519 chars of Mail::SpamAssassin::Plugin::Check::_one_line_body_tests_1000_1	0.00028
Apr 12 16:44:57.616 [10443] dbg: rules: run_generic_tests - compiling eval code: one_line_body, priority 1000	0.00041
Apr 12 16:44:57.616 [10443] dbg: rules: compiled one_line_body tests	0.00022
Apr 12 16:44:57.617 [10443] dbg: rules: running head tests; score so far=3.652	0.00035
Apr 12 16:44:57.617 [10443] dbg: rules: flush_evalstr (run_generic_tests) compiling 300 chars of Mail::SpamAssassin::Plugin::Check::_head_tests_1000_1	0.00021
Apr 12 16:44:57.617 [10443] dbg: rules: run_generic_tests - compiling eval code: head, priority 1000	0.00035
Apr 12 16:44:57.617 [10443] dbg: rules: compiled head tests	0.00024
Apr 12 16:44:57.618 [10443] dbg: rules: running head_eval tests; score so far=3.652	0.00029
Apr 12 16:44:57.618 [10443] dbg: rules: run_eval_tests - compiling eval code: 9, priority 1000	0.00033
Apr 12 16:44:57.619 [10443] dbg: rules: running body tests; score so far=3.652	0.00104
Apr 12 16:44:57.619 [10443] dbg: rules: flush_evalstr (run_generic_tests) compiling 243 chars of Mail::SpamAssassin::Plugin::Check::_body_tests_1000_1	0.0002
Apr 12 16:44:57.620 [10443] dbg: rules: run_generic_tests - compiling eval code: body, priority 1000	0.00029
Apr 12 16:44:57.620 [10443] dbg: rules: compiled body tests	0.00022
Apr 12 16:44:57.620 [10443] dbg: rules: running uri tests; score so far=3.652	0.00034
Apr 12 16:44:57.620 [10443] dbg: rules: flush_evalstr (run_generic_tests) compiling 241 chars of Mail::SpamAssassin::Plugin::Check::_uri_tests_1000_1	0.00021
Apr 12 16:44:57.621 [10443] dbg: rules: run_generic_tests - compiling eval code: uri, priority 1000	0.00026
Apr 12 16:44:57.621 [10443] dbg: rules: compiled uri tests	0.00021
Apr 12 16:44:57.621 [10443] dbg: rules: running body_eval tests; score so far=3.652	0.0003
Apr 12 16:44:57.621 [10443] dbg: rules: run_eval_tests - compiling eval code: 11, priority 1000	0.00028
Apr 12 16:44:57.623 [10443] dbg: PLG-ImageCerberus: : ImageCerberus_check :: Rule: ImageCerberusPLG4 (0.90, 1.20)	0.00122
Apr 12 16:44:57.623 [10443] dbg: PLG-ImageCerberus: : ImageCerberus_check :: path: /etc/spamassassin/imageCerberus	0.00015
Apr 12 16:44:57.623 [10443] dbg: PLG-ImageCerberus: : ImageCerberus_check :: maximgsize: 100	0.00012
Apr 12 16:44:57.623 [10443] dbg: PLG-ImageCerberus: : ImageCerberus_processingMsg:: Begin image's scores estimation	0.00016
Apr 12 16:44:57.623 [10443] dbg: PLG-ImageCerberus: : imageTextExtractionFromMSG:: 0 images extracted	0.00022
Apr 12 16:44:57.623 [10443] dbg: PLG-ImageCerberus: : ImageCerberus_check:: Write Mail Header	0.00014
Apr 12 16:44:57.624 [10443] dbg: check: tagrun - tag PLGIMAGECERBERUSOUT is now ready, value: 0.0 (No images found)	0.00017
Apr 12 16:44:57.624 [10443] dbg: PLG-ImageCerberus: : ImageCerberus_check :: Rule: ImageCerberusPLG5 (1.20, 100.0)	0.00016
Apr 12 16:44:57.624 [10443] dbg: PLG-ImageCerberus: : ImageCerberus_check :: Rule: ImageCerberusPLG1 (0.00, 0.30)	0.00014
Apr 12 16:44:57.624 [10443] dbg: PLG-ImageCerberus: : ImageCerberus_check :: Rule: ImageCerberusPLG3 (0.60, 0.90)	0.00016
Apr 12 16:44:57.624 [10443] dbg: PLG-ImageCerberus: : ImageCerberus_check :: Rule: ImageCerberusPLG2 (0.30, 0.60)	0.00033
Apr 12 16:44:57.625 [10443] dbg: rules: running rawbody tests; score so far=3.652	0.00024
Apr 12 16:44:57.625 [10443] dbg: rules: flush_evalstr (run_generic_tests) compiling 249 chars of Mail::SpamAssassin::Plugin::Check::_rawbody_tests_1000_1	0.00022
Apr 12 16:44:57.625 [10443] dbg: rules: run_generic_tests - compiling eval code: rawbody, priority 1000	0.00031
Apr 12 16:44:57.625 [10443] dbg: rules: compiled rawbody tests	0.0002
Apr 12 16:44:57.626 [10443] dbg: rules: running full tests; score so far=3.652	0.0003
Apr 12 16:44:57.626 [10443] dbg: rules: flush_evalstr (run_generic_tests) compiling 278 chars of Mail::SpamAssassin::Plugin::Check::_full_tests_1000_1	0.0002
Apr 12 16:44:57.626 [10443] dbg: rules: run_generic_tests - compiling eval code: full, priority 1000	0.0003
Apr 12 16:44:57.626 [10443] dbg: rules: compiled full tests	0.00024
Apr 12 16:44:57.627 [10443] dbg: rules: running meta tests; score so far=3.652	0.00029
Apr 12 16:44:57.627 [10443] dbg: rules: flush_evalstr (run_generic_tests) compiling 303 chars of Mail::SpamAssassin::Plugin::Check::_meta_tests_1000_1	0.00022
Apr 12 16:44:57.627 [10443] dbg: rules: run_generic_tests - compiling eval code: meta, priority 1000	0.00031
Apr 12 16:44:57.627 [10443] dbg: rules: compiled meta tests	0.0002
Apr 12 16:44:57.628 [10443] dbg: plugin: Mail::SpamAssassin::Plugin::DCC=HASH(0x3569138) implements 'check_post_learn', priority 0	0.00051
Apr 12 16:44:57.628 [10443] dbg: dcc: DCC learning not enabled by dcc_learn_score	0.00038
Apr 12 16:44:57.629 [10443] dbg: check: is spam? score=3.652 required=5	0.00026
Apr 12 16:44:57.629 [10443] dbg: check: tests=MISSING_DATE,MISSING_HEADERS,NO_RECEIVED,NO_RELAYS	0.00015
Apr 12 16:44:57.629 [10443] dbg: check: subtests=__BODY_TEXT_LINE, __EMPTY_BODY, __GATED_THROUGH_RCVD_REMOVER, __HAS_FROM, __HAS_MESSAGE_ID, __HAS_MSGID, __HAS_SUBJECT, __KAM_DROPBOX2, __KAM_FAKEDELIVER12, __KAM_FAKEDELIVER4, __KAM_FAKEDELIVER6, __KAM_FAKEDELIVER8, __KAM_GOOGLE2_2, __KAM_HARP3, __KAM_HAS_0_URIS, __KAM_JURY3, __KAM_MULTIPLE_FROM, __KAM_PAYPAL3B, __KAM_UPS2, __KHOP_NO_FULL_NAME, __MISSING_REF, __MISSING_REPLY, __MSGID_OK_DIGITS, __MSGID_OK_HOST, __MSOE_MID_WRONG_CASE, __NONEMPTY_BODY, __NOT_SPOOFED, __RB_GT_200, __SANE_MSGID, __SUBJ_SHORT, __TO_NO_ARROWS_R, __UNUSABLE_MSGID	0.00017
Apr 12 16:44:57.630 [10443] dbg: timing: total 3270 ms - init: 2438 (74.6%), b_tie_ro: 22 (0.7%), parse: 2.1 (0.1%), extract_message_metadata: 6 (0.2%), get_uri_detail_list: 1.89 (0.1%), tests_pri_-1000: 15 (0.5%), compile_gen: 292 (8.9%), compile_eval: 46 (1.4%), tests_pri_-950: 10 (0.3%), tests_pri_-900: 10 (0.3%), tests_pri_-400: 8 (0.2%), tests_pri_0: 588 (18.0%), check_spf: 0.32 (0.0%), tests_pri_500: 163 (5.0%), tests_pri_1000: 13 (0.4%)	0.00092
Finish - Total Time	4.30977
Re: Spam
Your lint tests look pretty good. Only thing is this...
ERROR: The "envelope_sender_header" in your spamassassin.conf	0.00051
ERROR: is not correct, it should match X-orgname-MailScanner-From
You need to change that. Timing looks good too. I think your system appears to be functioning properly, and you happen to be getting spam that is not triggering a whole lot of things. :think:
I think we need to try tuning your system. Training the bayesian filter will eventually help too.
BliXem
Re: Spam
Post by BliXem »
How can I change that?
Re: Spam
/etc/MailScanner/spamassassin.conf
BliXem
Re: Spam
Post by BliXem »
I changed that, but there is a other error then:
Apr 13 13:04:58.494 [2929] dbg: message: envelope_sender_header 'X-orgname-MailScanner-From' not found in message
In mailscanner.conf:
# This is the name of the Envelope From header
# controlled by the option above.
Envelope From Header = X-%org-name%-MailScanner-From:
orgname changed. Can you also modify your message? Don't want to see the company name.
BliXem
Re: Spam
Post by BliXem »
Re: Spam
Do you have 'Add Envelope From Header = yes' in your MailScanner.conf file?
